W221 - 2007 S600 Seat Belt Warning Error - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-31-2017, 07:39 PM Thread Starter
Tifosi1's Avatar
Date registered: May 2010
Vehicle: 2007 S600, 2011 GL550, 1989 560SEC, 2003 G500
Recently my 2007 S600 seat belt warning light and chime started going off even though I was wearing my belt - I was/am the only one in the car when this happens. I cleaned the buckle latch thinking it was a bit dirty, whatever - no luck, through some trial and error I've found I can make it go off if I also buckle the empty passenger belt... weird huh? The passenger seat airbag occupancy sensor seems to work - the dash light goes on and off as it should, and I get informed of passenger airbag enabled/disabled via the dash messages. So I'm confused the car seems to think there is someone in passenger seat concerning the belts, but not the airbags... Anyway it's quite frustrating, so any ideas or experiences or solutions would be appreciated. Thanks - Nick
Tifosi1
1980 Ferrari 308 GTSi
2007 Mercedes-Benz S600
2011 Mercedes-Benz GL 550
2003 Mercedes-Benz G500
1989 Mercedes-Benz 560SEC
2004 Triumph Bonneville - Cafe Racer
2002 Mercedes-Benz C32 AMG (sold, can't keep them all I guess)
1996 Mercedes-Benz C36 AMG (sold, wish I hadn't)
Tifosi1 is offline
post #2 of 5 (permalink) Old 11-01-2017, 06:41 AM
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2013 S550
Quoted: 447 Post(s)
Check and clean the seat belt wiring connector that is below the seat. At least in the W220, that was often the cause of such indications.
Other than that, it may be the seat occupancy sensor, as you probably suspect.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #3 of 5 (permalink) Old 11-03-2017, 09:01 AM Thread Starter
Tifosi1's Avatar
Yes I do suspect the WSS sensor - also seems like there are a couple of types of those. One mounted to the seat frame and one integrated to the seat cushion. I believe mine is the older frame mounted version (but I have yet to confirm) - and unfortunately seems as if those might be NLA and are to be upgraded to the cushion type. Easy enough, except that requires DAS/STAR/Xentry PC and software, which I don't have.
The second option appears to be using a WSS emulator which fakes the CPU into thinking all is well - except that the airbag is always active - which for me is not big deal. Just curious if anyone has experience with these emulators.
Like this:
http://airbag360.com/usa-mercedes-s-...only-496-p.asp
Thanks again - Nick
Tifosi1
Tifosi1 is offline
post #4 of 5 (permalink) Old 11-04-2017, 04:49 PM
Skylaw's Avatar
Vehicle: 2013 S550
Quoted: 447 Post(s)
It is not much of a problem for you, because you are aware of it - but a subsequent owner may not be, and lack of such knowledge could cause a fatality under some circumstances.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #5 of 5 (permalink) Old 06-09-2019, 05:09 AM
Date registered: Dec 2017
Vehicle: 2001 210.082 +494, 2008 221.176 +494
Quoted: 8 Post(s)
This is not normal. It sounds benign, but it should not inform you when it has enabled safety features. This indicates the WSS is out of calibration. This will need to be done at the dealer using specific weights and their diagnostic tool.
TiffanyTwisted is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W221 S-Class
