S550 4Matic Whine and Shudder - DTB P-B-28.00/07a - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 02-02-2010, 06:47 AM Thread Starter
Date registered: Apr 2007
I brought this up once before but I figure there are a few new people on here and a few more miles on everybody elses cars. Here's the deal - ever since the car was pretty much new (like 2000 miles or so), I can often feel a distinct shudder in the driveline under certain acceleration conditions and while driving at various speeds (most notably 62 MPH) there is a distinct whine (very loud, actually) right at throttle tip-in. My '07 never made these sounds or had the shudders.
My question for everybody, especially '09 and '10 owners is this: If you get your car up to operating temperature (at least 20-30 minutes of driving) and then either set the cruise for 62 MPH or get the car up to this speed and then lightly touch and release the accelerator pedal, do you hear a distinct whine right at throttle tip-in? In my car, it can be described as the piercing sound made when one moistens their finger and rubs the rim of a fine glass.
My symptoms have been described exactly in the above referenced DTB, but the dealer still maintains "operating as designed". I am just wondering if anybody else has experienced this - any input would be appreciated.
2009 S550 4Matic
1993 300SD
MercedesCarNut is offline
post #2 of 6 (permalink) Old 02-02-2010, 08:10 AM
konigstiger's Avatar
Date registered: Jan 2007
Vehicle: '71 Pinto
Quoted: 372 Post(s)
Kick it up a notch have the shop foreman test drive the vehicle with you as a passenger if they continue to claim it is normal, request a test drive with a comparable vehicle. If you already did this process, request the service manager put you in touch with the MBUSA Service Parts and Operations Manager (SPOM) that covers the dealership to discuss the matter.
konigstiger is offline
post #3 of 6 (permalink) Old 02-02-2010, 01:43 PM Thread Starter
MBUSA already sent someone from New Jersey to look at the car the 4th time I took it in. At this point, I am really just looking for anybody else that has had problems like this so we can compare notes.
2009 S550 4Matic
1993 300SD
post #4 of 6 (permalink) Old 02-05-2010, 03:20 AM
Outstanding Contributor Always Remembered RIP
eric242340's Avatar
Quoted: 334 Post(s)
Perhaps you would be kind enough to copy and paste the DTB on here for me to read.
ERIC.
This definition tells you all you need to know about 'PC'
PC, aka, Political Correctness, is a doctrine, fostered by a delusional, illogical minority (Liberals/Socialists) and promoted by the mainstream media, which holds forth the proposition that it is possible to pick up faeces by the clean end.
eric242340 is offline
post #5 of 6 (permalink) Old 02-05-2010, 09:11 AM Thread Starter
Here you go:
DTB
Date:
February 4, 2008
Order No.:
P-B-28.00/07a
Supersedes:
P-B-28.00/07 dated January 16, 2007
Group:
28
Revision History
Revision
Date
Purpose
a
2/4/08
Transfer Case Repair Assembly Revised and Parts Information Updated
1/16/07
Initial issue
SUBJECT:
Model 221.186, Equipped with Transmission 722.96 4-Matic
All Model Years
Introduction of 4-Matic Drive
During the launch phase of new 4-Matic all-wheel drive system with transmission NAG2 722.96 (with integrated transfer case) used in Model 221 S550 4-Matic, the workshop must clarify before-hand whether the customer reported drive performance involving the main transmission NAG2 or the below 4-Matic specific components.
• Integrated transmission / transfer case assembly
• Front drive-shaft
• Front axle differential
• Front axle shaft
Possible reported conditions include shuddering/vibrations, howling transfer case and/ or leaks at the front axle differential or transfer case.
Note: To enable you to recognize and forward problems regarding transmission 722.96 with 4-Matic quickly, the 4-Matic diagnosis sheet (refer to page 3) must be filled out completely and accurately. It must be returned with the related part and a copy of the form saved in the customer file.
Repair Concept
Until notified, no repair work should be performed on the following 4-Matic specific components (replacement only).
This bulletin has been created and maintained in accordance with MBUSA-SLP S423QH001, Document and Data Control, and
MBUSA-SLP S424HH001, Control of Quality Records.
© 2008 Mercedes-Benz USA, LLC. All rights reserved. Reproduction or translation in whole
Mercedes-Benz Canada, Inc. or in part is not permitted without authorization from the
Dealer Workshop Services publisher. Printed in U.S.A.
Mercedes-Benz - Home of C, E, S, CLK, CLS, CL, SLK, SL, SLR, R, GLK, M, GL, G Class 1-800-FOR-MERCedes
www.startekinfo.com
• Transfercase assembly - Leaks in the sealing flanges must be resealed.
• Front propeller shaft
• Front axle shaft
Note: In cases of the above mentioned parts, the completed 4-Matic diagnostic form (refer to page 3) must be included with the incoming parts and a copy retained in the customer file. Failure to comply may result in a charge back.
Note: All repair procedures which are authorized for the NAG2 are authorized for the NAG2
4-Matic as well.
Diagnostics can be performed, as outlined in the EDAC diagnostic tree and all standard repairs for the NAG2 may be performed. The axial play between the park pawl gear and grooved ball bearing, described in WIS AR27.50-P-0600-06SYZ, must be measured and recorded before the main transmission NAG2 is disassembled or repaired. During assembly, the axial play must be set again using shims. If the axial play is not set correctly, transmission noises or further transmission damage will occur.
If diagnostic procedures lead the technician to the replacement of a valve body or transmission, a WSG pre-authorization form must be completed as described in DTB P-B 27.00/38d dated November 7, 2006.
Software Update - Flashing
If the transmission control module needs to be programmed, only STAR DIAGNOSIS versions 09/2006 or later should be used in conjunction with all of the related add-ons.
Note: It is important to ensure that only “SDflash Release” CDs as of 9/2006 be used with all of the related add-ons.
Parts Information
Qty.
Part Name
Part Number
1
Transmission 722.961
Refer to EPCnet, Group GA27, Subgroup 015, by VIN to determine correct part number
1
Front differential
A221 330 04 02
1
Propeller shaft, transfer case to front axle
A221 410 17 01
1
Axle shaft Front Left
A221 330 08 01
1
Axle shaft Front Right
A221 330 09 01
P-B-28.00/07a (February 4, 2008)
2
4MATIC Diagnosis Form - MODEL 221 with Transmission 722.96 4MATIC
Branch/Agency Company No.
Customer
Vehicle ID No.
Tester: Name
V
ariant Code Software Object Number Model
Initial Registration Main odometer reading (km/miles):
Gearing noises/howling noise at transfer case Overrun Acceleration
Description of noises
(howling, whistling, singing, grinding, etc.)
Vehicle speed range
Gear stage
Other information
Vibration and roughness Idling vibration in gear range P or N Idling vibrations when stationary with gear range D engaged Vibration/roughness in driving mode
Vehicle speed range
Other information
Vibrations/shuddering in turning circle
Shuddering/vibrations in turning circle Shuddering/vibrations when cornering
Throttle lift-off noises, click-clack
Acceleration – Overrun vehicle speed range
Overrun – Acceleration vehicle speed range
Clacking noise at throttle lift-off Clacking noise when driving off
Oil leakage at transfer case
Radial shaft sealing ring to front axle leakingRadial shaft sealing ring to rear axle leakingSealing surface between aut. trans. and transfer case leaking Sealing surface at transfer case cover leaking
Other complaints
3
2009 S550 4Matic
1993 300SD
post #6 of 6 (permalink) Old 02-06-2010, 12:58 AM
eric242340's Avatar
Quoted: 334 Post(s)
Thanks for the DSB, your cars does appear to fit the bill on this one. We have a lot of customers with 4 matic but they go to the dealers for warranty stuff. Hence I have not seen or heard of this particular problem as yet.
ERIC.
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W221 S-Class
S550 Driveline Shudder, Transfer Case Howl MercedesCarNut W221 S-Class 14 10-05-2011 03:55 PM
4matic light help- shudder noise in reverse sach W124 E,CE,D,TD Class 3 02-08-2006 04:31 PM
4matic gear whine 1990 300E milhan W124 E,CE,D,TD Class 0 11-08-2004 02:38 PM
Drivetrain whine from 4Matic ? bob01 W210 E-Class 1 03-12-2003 04:46 PM
