Power Trunk Would Not Open Fully - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 08-14-2019, 02:40 PM Thread Starter
Date registered: Aug 2017
Vehicle: 2002 S500V
Quoted: 7 Post(s)
Thumbs up Power Trunk Would Not Open Fully
Hi all. My 2002 S500 power trunk would not open fully. Sometimes if opens halfway and now it opens like three quarter of the way. My old mechanic told me it is just the two shocks that is attached to the power trunk. Is he right? If so, where could I get those shocks in a fairly reasonable price? Is there a good online parts store you would recommend? Thank you very much in advance.
sengr is offline
post #2 of 11 (permalink) Old 08-14-2019, 08:05 PM
4DGeorge's Avatar
Date registered: Jan 2018
Vehicle: 2006 S500 (W220, Designo Espresso, AMG Sport, LWB)
Quoted: 42 Post(s)
MaxPow is a decent brand for trunk struts.
https://www.amazon.com/Maxpow-Compat.../dp/B01J1NP5IS
Or you can buy genuine MB ones from FCPEuro.com that have a lifetime warranty.
https://www.fcpeuro.com/Mercedes~Ben...keywords=trunk
Also, be sure to check your settings within the dash console to see if the trunk lid is set to restricted (only opens half way).
Dave2302 likes this.
4DGeorge is offline
post #3 of 11 (permalink) Old 08-15-2019, 12:02 AM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 763 Post(s)
Hi,
If we are talking PTL, (Power Trunk Lifter) here, that is the one with the red illuminated button on the lower edge of trunk lid, visible when trunk open, then ......................
Your mechanic is talking pure bull ............
Struts have no effect on PTL.
I'd start by checking the setting like @4DGeorge said, and after that I'd be using SDS to check out the hall sensors that control it's opening limits .................
PTL is found in PSE because PSE is what controls it
HTH,
Dave
Dave2302 is offline
post #4 of 11 (permalink) Old 08-15-2019, 07:02 PM Thread Starter
Vehicle: 2002 S500V
Quoted: 7 Post(s)
4DGeorge, where do you check the setting on the dash console? Can you attach a picture of the place where you can change the settings? Thank you in advance.
sengr is offline
post #5 of 11 (permalink) Old 08-16-2019, 12:20 AM
Dave2302's Avatar
Quoted: 763 Post(s)
Hi,
My Car doesn't have PTL, and sadly nor does the Parts donor Car , I was hoping it would so I could retrofit my Car
Been a while since I played with one, but I'm "educated guessing" it should be in Dash Cluster either Vehicle Menu or Convenience Menu ..................
If it is not there and the Car has PTL then there is likely a problem, such as Cluster has been replaced or worked upon and the "Version Codings" in Cluster are incorrect.
SDS would confirm all this
HTH,
Dave
Dave2302 is offline
post #6 of 11 (permalink) Old 08-16-2019, 04:13 PM
4DGeorge's Avatar
Quoted: 42 Post(s)
You're looking for this:
Dave2302 and sengr like this.
4DGeorge is offline
post #7 of 11 (permalink) Old 08-17-2019, 10:13 AM Thread Starter
Vehicle: 2002 S500V
Quoted: 7 Post(s)
Sad to report back, it is in the "Off" position but the trunk still opens 3/4 way.
sengr is offline
post #8 of 11 (permalink) Old 08-17-2019, 10:21 AM Thread Starter
Vehicle: 2002 S500V
Quoted: 7 Post(s)
Once again, Dave2302 is correct, the instrument cluster was indeed replaced by the dealer under warranty (I do have the dealer maintenance record, as well as the Carfax report)
sengr is offline
post #9 of 11 (permalink) Old 08-17-2019, 10:54 AM
4DGeorge's Avatar
Quoted: 42 Post(s)
BTW, just as the windows\sunroof can be reprogrammed after having the battery disconnected, the trunk also has a similar reset procedure using the switch on the driver's door panel. Instead of listening for the click sound, continue to hold the switch for an additional 15 seconds. Do this with the trunk in the fully opened position, and then again from the closed position. Sometimes I've had to go through two full open\close cycles to get the trunk or particular window to be reset correctly.
Have you tried changing the dash setting to ON, cycling the trunk lid, and then turn the setting back to OFF?
In case you've not seen it, here's a page with more than you ever wanted to know about the trunk, including how to open it by force if ever necessary:
https://w220.ee/Trunk
4DGeorge is offline
post #10 of 11 (permalink) Old 08-17-2019, 11:13 AM
Date registered: Sep 2013
Vehicle: W220 S350 2004
Quoted: 46 Post(s)
If you have option code
https://w220.ee/Option_codes#881_-_REMOTE_TRUNK_LOCKING
then you will have in DAS under PSE module
https://w220.ee/Pneumatic_System_Equ...AS_adaptations
adaptation for normalizing remote opening (it will ask you to raise trunk lid to the highest position by hand).
Pokseva is offline
