Oil filter won't fit? 2003 S430 4matic - Mercedes-Benz Forum
post #1 of 27 (permalink) Old 08-07-2019, 03:44 PM Thread Starter
Date registered: Aug 2019
Vehicle: 2003 S430 4matic
I have a 2003 S430 4matic and after changing the oil, I couldn't seem to get my new filter to fit. I've tried a FRAM CH8481 and MANN HU718/5x, both of which are supposed to fit my vehicle. The MANN filter has black marks which indicate how far the filter is supposed to slide into the filter housing, and the closest I could get it was about 1/4 - 1/2" away. There's far too much resistance if I try to reinstall the housing with one of these two filters. This is the first time I've tried to change the filter since buying the car from an individual, and the filter he had in it is noticeably smaller than either of the two that are supposed to fit. It also looks like it may have been crushed down when installing originally, because the fins of the filter are in a bit of a spiral pattern rather than vertical.
I can get some pictures if needed, but I'd like to see if anyone has an idea before I go make an oily mess.
Thanks in advance!
Two Scoops is offline
post #2 of 27 (permalink) Old 08-07-2019, 05:51 PM
Date registered: Feb 2011
Vehicle: 2009 E350 4M Avant Garde, My Mistress 2002 S600, Wife 2014 C300 4M Avant Garde with AMG
Quoted: 157 Post(s)
the oil filters for later engines ( 2012) and up will not fit the earlier engines.
Buy from MB for your car - the price difference is minor!
Dave2302 likes this.
Kraut56 is offline
post #3 of 27 (permalink) Old 08-08-2019, 12:52 AM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 757 Post(s)
Hi,
I suggest those who insist on "cheaping out" on Oil Filters have a watch of this short Video ....................
HTH,
Dave
Dave2302 is offline
post #4 of 27 (permalink) Old 08-08-2019, 02:01 AM
Benzyle's Avatar
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 305 Post(s)
I have installed Mann HU718/5X fleece filters ,on M112 and M113 engines many times. They are excellent filters.
I like to place the cap /frame inverted on the bench , then slide and twist and push the filter down and on. Put a smear of oil around the inside edges first. Smear clean oil on the o rings before installing into the car , and be sure to place the large o ring in the 2nd groove down , NOT right next to the flange.
There should be one black line visible when it is in the correct position ,,and the filter should protrude from the cap by 68mm.
Good luck
tonylinc likes this.
Benzyle is offline
post #5 of 27 (permalink) Old 08-08-2019, 02:14 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 160 Post(s)
Dont mes about with aftermarket filters .Mercedes is the only place for vital parts like this .One wrong step and yopur talking 1000$ for a new engine or auto box .All this through fitting a not up to specs filter . Vin number your filter and get it right, so you dont have any nasty problems later on .
plinker17722 is offline
post #6 of 27 (permalink) Old 08-08-2019, 04:55 AM
Dave2302's Avatar
Quoted: 757 Post(s)
EXACTLY
How much do you save by buying a cheapo Filter ............... $5 ??
Not even chump change
doni01 likes this.
Dave
Dave2302 is offline
post #7 of 27 (permalink) Old 08-08-2019, 06:59 AM
Vehicle: 1999 E430; 2005 ML500
Quoted: 114 Post(s)
Mann is an OEM supplier, and it should fit. If there’s a problem, you can always get a new plastic housing.
This DIY shows the topic around minute 5.
Hirnbeiss is offline
post #8 of 27 (permalink) Old 08-08-2019, 08:40 AM
Date registered: May 2016
Vehicle: 2000 S430, 2003 S430, 2003 S600 TT, and 2005 E320 CDI
Quoted: 989 Post(s)
Yeah, Mann is an OE for M-B. Mahle and Xengst apparently are also OE's. I run all three in my own cars, and they fit perfectly. All made in Germany or Austria, too.
Remember to twist and push the filter all the way into the oil filter housing. It takes a little bit of oomph, and this is true when you buy that Mann filter from Mercedes-Benz as well.
By the way, are you using the fleece filter or the paper filter?
EDIT: Duh...the 718/5x *is* the fleece filter and the correct one for the M112/M113 engines. You should be fine.
tonylinc and Benzyle like this.
cowboyt is offline
post #9 of 27 (permalink) Old 08-08-2019, 09:53 AM
tonylinc's Avatar
Date registered: Oct 2005
Vehicle: W163 ML320, W220 S500, R230 SL600TT, R170 SLK230, W140 S500, More
Quoted: 48 Post(s)
I recently bought a X164 GL450 from a small car dealer who said all vehicles were "all serviced up". The car had a little sticker at the top of the windshield indicating 2500 miles left before the next oil change... but it indicated the license plate that was a vanity plate belonging to the previous owner. So, I decided to change the oil. My surprise when I took out the oil filter and it said on it, Made In Korea. The oil was black and nasty, too. On to all the air filters, which were very dirty, probably had been in there for 15,000 miles, maybe more! So I replaced all the air filters in the car, and did spark plugs as well, which were the original ones that came with the car. This dealer had left on their advertising license plate frames, which I took off and tossed in the garbage. The guy also claimed he had put "new" tires on the car because the old tires were cracking rubber. A close look at the tires showed that's been on the car about three years. Never believe a word any car dealer tells you! And Yes I use MANN Fleece filters. Made in Germany!!
Dave2302 and Benzyle like this.
tonylinc is offline
post #10 of 27 (permalink) Old 08-09-2019, 12:18 AM
Dave2302's Avatar
Quoted: 757 Post(s)
Hi,
A Car Dealers idea of a "Full Service" is and always has been at very best an Oil change without new Filter using supermarket oil
Don't believe a word that comes out of their mouths !!
tonylinc and cowboyt like this.
Dave
Dave2302 is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
