Poor Ride Quality - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 07-10-2019, 12:36 AM Thread Starter
Date registered: Jul 2019
Vehicle: 2005 S320 CDI L
Poor Ride Quality
I've not had my 320 CDI for too long, but I just can't get to grips with the suspension. It's definitely not right, but I can't figure out why. Firstly; the suspension isn't firm as such, but small bumps and imperfections seem to upset the front wheels, resulting in a secondary shudder/jiggle/bounce that gets really tiresome, and it happens at all speeds. This does not appear to be the case on the rear, which seems to sweep over bumps that would otherwise be felt through the front.
The car has been inspected on two occasions and no play discovered in any of the rubber. The airmatic system itself seems to operate exactly as it's supposed to; it raises and lowers normally, you can feel it cycle through the settings normally, and it doesn't lose any height while standing. The only thing I've found that seems suspect is that the push down test reveals that one front corner is softer and has more bounce than the other. The firmer one feels more like the rears do. However, this doesn't seem to present itself while driving; the whole of the front feels off rather than just one side.
Any advice?
Hart6 is offline
post #2 of 12 (permalink) Old 07-10-2019, 01:08 AM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 726 Post(s)
Hi,
Welcome to the forum
Please complete your profile so we all know exactly what Car you have and at least where in the world you are ............ Different models and geographical locations will often have different parts fitted !!
Does the car look like it has had a strut replaced recently at the front end ? ............. Could be a cheap Chinesium one which are always harder and nasty junk (IMHO !!)
Also it is often difficult to find play in Rack Joints, Ball Joints, Bushes etc when a Car is up on a jack and you are tugging at the wheels, because of course those joints are not sitting at "ride height" position, which is where the most wear occurs. It needs someone with experience, often a 4 poster lift / pit and sometimes even "Shaker Plates" to find this wear, which is often significant play
Finally, the Airmatic Struts have Air Springs, which obviously seem to be OK, but also do not forget they have a Damper Valve which adjusts the Damping Rate, these have been known to go bad, but sadly are an integral part of the strut, so would require strut replacement !! They are the round looking canisters with a black cable going to them at the bottom of the strut
HTH,
Dave
Dave2302 is online now
post #3 of 12 (permalink) Old 07-10-2019, 01:33 AM Thread Starter
Updated my details!
When I say inspected - this was indeed in an inspection pit by trusted mechanics.
The front struts both look the same from what I can see, and I'd hazard a guess that they're actually the car's original units too. I don't think that one of them is a different brand. The interesting thing is that it's the softer corner that feels like the outlier, not the firmer one, so perhaps your suggestion of a shot damping valve is correct.
I'm more than happy to replace the struts, as they look like a very straightforward DIY job, but obviously I'd like to be sure that they need changing before throwing money under there (though I do have half a mind to simply rebuild the front). Interestingly I can't find anyone with similar symptoms to me. People describe having overly firm suspension or terribly bouncy suspension, but my issue is somewhere in the middle of those.
Dave2302 likes this.
Hart6 is offline
post #4 of 12 (permalink) Old 07-10-2019, 02:05 AM
Dave2302's Avatar
Quoted: 726 Post(s)
Hi,
OK that's all good news, thanks for sorting the profile
Based upon your latest and from OP :- "secondary shudder/jiggle/bounce" if this is a vertical movement / bounce, then I'd say it does sound like a Damper issue so starting with a decent replacement pair of Front Struts is the way to go ..................
AFAIK there is no way SDS can test the Damping, it can only report an 'electrically' faulty valve, but if the problem is mechanical inside the damper or valve then it will be no point paying for SDS diagnostic in this scenario.
MB are very expensive, but their own RE Manufactured are good and carry the same guarantee as new MB.
Bilstein are OEM for MB, good products reasonably well priced.
Arnott are now supplying in UK via Factors, New and Rebuilt I believe, can be troublesome once in a while, but warranty and after sales service is good, but double check that Arnott still have the Adjustable Damping Valve, as I have heard that some did not
HTH,
Dave
post #5 of 12 (permalink) Old 07-10-2019, 02:21 AM
Dave2302's Avatar
Quoted: 726 Post(s)
Further to my post above, read this current post and a few back from it ..........
https://www.benzworld.org/forums/w22...l#post17836216
Now, I run my own MB Indie Workshop in NW Scotland ........................
If this were a Customers Car it would get MB Reman's, as I gotta guarantee the job and don't want "bad press" ......................
If it were my own Car I'd fit new Bilstein, and likely have no trouble at all
HTH,
doni01 likes this.
Dave
post #6 of 12 (permalink) Old 07-10-2019, 03:13 AM Thread Starter
Much appreciated Dave! Will look into the options.
Hart6 is offline
post #7 of 12 (permalink) Old 07-10-2019, 05:39 AM
doni01's Avatar
Date registered: Jun 2012
Vehicle: S500 4Matic 2005
Quoted: 107 Post(s)
HTH,
^^Once again, right on the money!! I used MB Reman's for my two front ones as well. I paid around $1100 for both. I would have liked to have used the Bilsteins but since mine is 4Matic the price for them was a little too high. I believe around $900 for each at the time
doni01 is offline
post #8 of 12 (permalink) Old 07-10-2019, 09:08 AM
Date registered: May 2016
Vehicle: 2000 S430, 2003 S430, 2003 S600 TT, and 2005 E320 CDI
Quoted: 965 Post(s)
There are two series of Arnott struts--the remans, and the "new-mans". The remans retain full adjustability. The new-mans do not, i. e. they've got one setting, namely Sport 1, though they are brand-new.
It depends on whether the car is 2WD or 4Matic. For a 2WD car, I'd go with new Bilsteins, as they are very nearly the same cost as the Arnott remans. For a 4Matic car, I'd go with the Arnott new-mans, since the 4Matic Bilsteins or M-B remans are going to be hundreds of dollar$ more money per strut.
2000 S430 (Dad's car, used for special occasions)
2000 S500 (wife's DD: my first W220 project car)
2003 S600 ("sex on wheels"--second w220 project car)
2003 S430 (one of two current DD's--third W220 project car)
2005 E320 CDI (the other current DD--first W211 project car)
cowboyt is offline
post #9 of 12 (permalink) Old 07-10-2019, 04:06 PM
doni01's Avatar
Quoted: 107 Post(s)
T,
I don't know about the OP but I personally prefer to do the job once and be done with it. So even if Arnott made 5 series of struts instead of 2, I would still go M-B Reman's ALL DAY LONG
doni01 is offline
post #10 of 12 (permalink) Old 07-10-2019, 11:46 PM
Dave2302's Avatar
Quoted: 726 Post(s)
Hi,
Thing is this, y'all know how fussy I am about my Cars, and the same is true when I do a job for a customer ...............
So, I simply could not live with having a function that no longer works, (Adjustable Damping)
Further to that, i have seen many posts on here that suggest Arnott re mans quailty control can at times be somewhat lacking, so although they promptly rectify the matter by sending one or 2 replacements out in short order, I am not the most patient person when it comes to having to do the same job twice due to someone elses, (or my own), fault !!
If like @wallyp 's experience I had to do it a 3rd time in short order I would be chucking hammers around and swearing, which is really no good for anyone
It would appear to me that due to most faults with Arnotts being Damper related, it means the Arnott "Re Mans" just get cleaned up, painted and new Airbags and Dust Covers etc, rather than the Damper Part being overhauled at the same time !! Either that or they are not testing them properly after rebuild ................
If this is true, and not just my educated guess, this means really they are just repaired units, not re-mans !!
I never have an MB Reman back for damping issues, and with very close inspection one cannot tell the difference between New MB Parts and Reman MB Parts !!
Being in business for many years in the UK has made me a naturally suspicious individual, and, to that end I often wonder if MB just have 2 tiers of pricing for the same "Brand New" Part, if you ask for reman you get hefty discount, if you don't you "pays the piper"
HTH,
doni01 likes this.
Dave
