2001 S320 cdi Limp mode help - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-20-2019, 05:05 AM Thread Starter
Date registered: Jun 2019
Vehicle: 2001 W220 S320 CDi
Damn thing.
The car is in permanent limp mode apart from a few mornings where it springs into life and smokes like hell for a mile or so, then back to limp mode.
What I have done so far....
New MAF sensor
New EGR valve and inlet manifold
New turbo pressure switch (one near EGR valve)
Checked turbo hoses etc, non seem split.
When it does go, it really flies but some black smoke. No smoke in limp mode.
Its spoiling the car for me now.
Thanks
NigeMBW220 is online now
post #2 of 3 (permalink) Old 06-20-2019, 07:22 AM
Date registered: May 2016
Vehicle: 2000 S430, 2003 S430, 2003 S600 TT, and 2005 E320 CDI
Quoted: 962 Post(s)
Hi @NigeMBW220 ,
I have a 2005 E320 CDI that was doing the same thing (similar motor as your S320 CDI). In my case, it turned out to be, of all things, the air filter. I opened up the air filter housing, and it looked like there was a bird's nest or something similar in there. Took that out, thoroughly cleaned out the housing, put a new air filter in there, and like magic, the engine has been great since. No more smoke, no more limp mode, none of that. It's been almost two years now (I happened to drive it today to work--it's been about 3 days since it's been driven).
You are very likely getting engine codes. Do you have access to a STAR Diagnostic System or a friend who has one? If you're doing your own work on your car, and I think one should when possible, an SDS setup really is so valuable for diagnosing things like this.
Dave2302 likes this.
2000 S430 (Dad's car, used for special occasions)
2000 S500 (wife's DD: my first W220 project car)
2003 S600 ("sex on wheels"--second w220 project car)
2003 S430 (one of two current DD's--third W220 project car)
2005 E320 CDI (the other current DD--first W211 project car)
cowboyt is offline
post #3 of 3 (permalink) Old 06-23-2019, 11:26 PM Thread Starter
Solved!!
Reset everything by disconnecting battery and leaving for 30 seconds.
The new inlet manifold and EGR seem to have it sorted.
No smoke under decent acceleration, but still some on hard.
Feels great again !
