Issues electrical - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 06-13-2019, 04:58 PM Thread Starter
Date registered: Jun 2019
Vehicle: 2006 S600
Quoted: 2 Post(s)
Issues electrical
2006 S 600
recently had battery issues had to jump car from passnger side floor board area because battery was completely dead keys in the trunk "comedy of errors" Any way Replaced battery cranks up and runs just fine.
However when I open the door no lights come on inside the car and the entire dash is completely black to include radio and Nav no door chimes nothing.
Driverside door panel is dead as well no lock window heat etc.
In addtion the wipers dont work now either. Oddly enough passenger side control function as normal Check fuses replaced a total from 5 to 20 amps.
Perplexed any ideas on what could be wrong ?????
Jv Lewis is offline
post #2 of 11 (permalink) Old 06-13-2019, 05:03 PM
Date registered: Dec 2012
Vehicle: 2003 S430
Quoted: 377 Post(s)
Did you check the fuses behind the hidden panel in the right end of the dash?
Wally
wallyp is offline
post #3 of 11 (permalink) Old 06-13-2019, 05:07 PM
nrphlly's Avatar
Date registered: Feb 2007
Vehicle: 2002 Mercedes S600, 2002 S500, 2001 BMW 750IL
Quoted: 41 Post(s)
This car has a very complex electrical system, when you jumped it from the front I think you killed the front SAM. I have done this to the rear SAM. We can’t jump these cars without harming them.
nrphlly is online now
post #4 of 11 (permalink) Old 06-13-2019, 05:44 PM Thread Starter
Vehicle: 2006 S600
Quoted: 2 Post(s)
No idi not check that location but i did check under the passenger seat. These fuses are ok as well in the hidden area
Jv Lewis is offline
post #5 of 11 (permalink) Old 06-13-2019, 05:45 PM Thread Starter
Vehicle: 2006 S600
Quoted: 2 Post(s)
alas SAM do you know where its located
Jv Lewis is offline
post #6 of 11 (permalink) Old 06-13-2019, 07:02 PM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 885 Post(s)
Were any of the fuses blown?
Connect stable power supply to battery, connect scanner and run "Quick Test". Post results.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #7 of 11 (permalink) Old 06-13-2019, 07:33 PM
nrphlly's Avatar
Quoted: 41 Post(s)
I think you two under the hood for motronic and dash interior. Both left and right.
I blew a fuse and my car would not even start back up at the gas pump. I found the fuse and all was good.
post #8 of 11 (permalink) Old 06-13-2019, 11:47 PM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 712 Post(s)
Hi,
I think that if you are lucky you have blown a pre fuse, more likely multiple modules due to feedback.
You see, a Front or Rear SAM does not cause no Cluster.
FWIW, maybe this will help others, the procedure in your case would have been connect jump leads, open trunk using door switch / trunk handle, then actually jump start the vehicle from the Battery Terminals.
HTH,
Dave
Dave2302 is offline
post #9 of 11 (permalink) Old 06-14-2019, 04:34 AM
Date registered: May 2011
Vehicle: 2005 S600
Quoted: 54 Post(s)
The only thing running under the passenger floor board is the SAM power supply. It's 12v and relatively big, and I think, as others have said, that you've overloaded the SAMs with all that current. It wasn't designed for jump starts, it powers the SAMs.
If you're very lucky, you blew the 100A pre-fuse in the trunk. On the right side of the trunk there is a big fuse, and I think the SAM power supply is fed by that. You may have blown that fuze. Pull the carpet/liner back and on the right side, forward of the battery, under the hinges for the lid, and mounted on the inside of the right rear wheel well is that pre-fuse. Easy to see if it's blown. Used (eBay) are available, new is quite pricey.
Check the prefuse under the front carpet as well. Same capacity, same chance of overload.
By the way, when looking at these things, the squiggly conductor is the fuze. There is a gap in the conductor, visible through a hole, that looks like a blown fuze, but it's not. I think it's a troubleshooting thing - bypass the fuze through that hole for troubleshooting...
Take a look here for pre-fuse information: https://w220.ee/Fuses#Prefuses
As I said, if you're lucky, that's what happened...
Dave2302 likes this.
Current Fleet:
2016 Tundra 1794
2005 MB S600 (100K, Michelin AS3+, M1 0W40)
2002 V70-XC (228K Castrol 0W40)
2002 V70-T5 (198K, Mobil 1 0W40)
1932 Packard Sedan (straight 8, dual sidemount spares, original paint and interior, Shell Rotella 15W40)
Astro14 is offline
post #10 of 11 (permalink) Old 06-26-2019, 06:10 AM Thread Starter
Vehicle: 2006 S600
Quoted: 2 Post(s)
Update Prefuse IN REAR OF TRUNK WAS DEFINITELY BLOWN THANKS FOR THAT TIP. i
DID RECEIVE AND INSTALL NEW PREFUSE. unfortunately THIS DID NOT SOLVE ALL OF THE PROBLEMS.
I checked all of the fuses again with the schematic to ensure that i have the right fuse sizes in the correct locations to include another fuse panel in the passenger side of the dash. I do not have any power to the driver side door functions, interior lights do not come on when door is opened, wipers do not work and the entire dashboard console is black to include radio temp controls and the like. Oddly i do have power to the passenger door. The car start up runs drives but i still cant get scanner to pull codes. Any ideas on what is wrong?
Jv Lewis is offline
