Rear SAM - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 06-05-2019, 02:35 AM Thread Starter
nrphlly's Avatar
Date registered: Feb 2007
Vehicle: 2002 Mercedes S600, 2002 S500, 2001 BMW 750IL
Quoted: 44 Post(s)
Rear SAM
Is there a power source for entire Sam. Windows won’t move and brake lights are always on.
2000 year W220 is a pain in the a**. This is my fathers car.
nrphlly is offline
post #2 of 10 (permalink) Old 06-05-2019, 05:04 AM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 716 Post(s)
Hi,
Rear SAM is fused at the Rear End Pre Fuse Box IIRC.
I doubt that is the problem, or the Brake Lights simply would not come on.
HTH,
Dave
Dave2302 is offline
post #3 of 10 (permalink) Old 06-05-2019, 07:21 AM
Date registered: May 2016
Vehicle: 2000 S430, 2003 S430, 2003 S600 TT, and 2005 E320 CDI
Quoted: 962 Post(s)
Sounds like what happened when my S600 TT's SAM got wet due to water intrusion (that accursed reed valve). I took the entire SAM apart and cleaned up every electrical contact that I could find.
Is yours wet, or does it show any signs that it might have gotten wet in the past? Also, check all fuses.
Dave2302 likes this.
2000 S430 (Dad's car, used for special occasions)
2000 S500 (wife's DD: my first W220 project car)
2003 S600 ("sex on wheels"--second w220 project car)
2003 S430 (one of two current DD's--third W220 project car)
2005 E320 CDI (the other current DD--first W211 project car)
cowboyt is offline
post #4 of 10 (permalink) Old 06-05-2019, 10:28 AM Thread Starter
nrphlly's Avatar
Quoted: 44 Post(s)
Originally Posted by Dave2302 View Post
Hi,
HTH,
Thankyou Dave, I figured this as well. The car answered my own question
nrphlly is offline
post #5 of 10 (permalink) Old 06-05-2019, 10:29 AM Thread Starter
nrphlly's Avatar
Quoted: 44 Post(s)
I saw the corrosion but I can’t be sure. I’m going to try this anyway and see if it helps with anything.
nrphlly is offline
post #6 of 10 (permalink) Old 06-05-2019, 10:46 AM
Dave2302's Avatar
Quoted: 716 Post(s)
Hi,
TBH if I'd seen corrosion, I would be trying a good used SAM, you do need SDS to check it's Version Coding though, even if it is same part number
HTH
Dave
Dave2302 is offline
post #7 of 10 (permalink) Old 06-06-2019, 01:46 AM
Date registered: Feb 2008
Vehicle: Too many to list
Quoted: 1533 Post(s)
You need a new Sam case closed
tusabes is offline
post #8 of 10 (permalink) Old 06-06-2019, 01:58 AM Thread Starter
nrphlly's Avatar
Quoted: 44 Post(s)
LoL I ordered two both from 2000 s430
nrphlly is offline
post #9 of 10 (permalink) Old 06-06-2019, 02:00 AM Thread Starter
nrphlly's Avatar
Quoted: 44 Post(s)
Hi,
TBH if I'd seen corrosion, I would be trying a good used SAM, you do need SDS to check it's Version Coding though, even if it is same part number [IMG class=inlineimg]/forums/images/BenzWorld2/smilies/tango_face_wink.png[/IMG]
HTH
A shop can help after my faults are repaired
nrphlly is offline
post #10 of 10 (permalink) Old 06-06-2019, 02:04 AM
Dave2302's Avatar
Quoted: 716 Post(s)
Hi,
It is NOT a proper repair until it has Coding Checked, that is the correct way to do the job.
Remember you will need to check Version Coding with SDS and correct if needs be ....................
If this is going on your TT it is even more likely that the TT will have extra options over and above the 430.
For example, but not an exhaustive list, Rear Window Blind.
I'm not absolutely certain, but it just might also have something different if there are any Engine related Codings in Rear SAM.
Not checking the Codings is like betting on a Nag, you may get lucky, you may get grief, part numbers are not the be all and end all, if you bought a Brand New module from MB it would still need Coding.
HTH,
Dave
Dave2302 is offline
