EGR how do I get MAF out of the way? - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 05-23-2019, 09:08 PM Thread Starter
Date registered: Apr 2015
Quoted: 13 Post(s)
2001 S 430 got P0400 error code. need to check EGR and pipe. After geting plastic air cleaner box off hot do I get the MAF unclipped/out?
bmoe100 is offline
post #2 of 16 (permalink) Old 05-24-2019, 07:12 AM
Date registered: May 2016
Vehicle: 2000 S430, 2003 S430, 2003 S600 TT, and 2005 E320 CDI
Quoted: 962 Post(s)
I did this to the project 2000 S500 a bit over a month ago. I found it easier to just remove the entire air intake.
1.) There's what looks like a quite large, circular clip at the top. Use a screwdriver to gently pry its lever open and remove that clip.
2.) Remove the electrical connector for the MAF. It's a clip-on like other M-B connectors; mine came off with minor persuasion.
3.) There's one clip in the back of the air intake that I could see. I undid that and then just kinda gradually twisted the MAF out. There is what looks like a second clip below that, but as I recall, it's more like a plastic spacer "stud" more than anything else. Anyway, it does come out with some gentle-ish persuasion.
You should now have the room to manoeuver the EGR pipe so that it'll come out.
Dave2302 likes this.
2000 S430 (Dad's car, used for special occasions)
2000 S500 (wife's DD: my first W220 project car)
2003 S600 ("sex on wheels"--second w220 project car)
2003 S430 (one of two current DD's--third W220 project car)
2005 E320 CDI (the other current DD--first W211 project car)
cowboyt is offline
post #3 of 16 (permalink) Old 05-24-2019, 09:33 PM Thread Starter
Quoted: 13 Post(s)
code resolved by itself?
The code went away today before I could fix anything. Does that mean the EGR works, that is, EGR is all or nothing? If the EGR works then does that point to more towards a vacuum hose or EGR pipe narrowing?
bmoe100 is offline
post #4 of 16 (permalink) Old 05-25-2019, 04:51 AM
Date registered: Feb 2009
Vehicle: '04 S430
Quoted: 29 Post(s)
No, the issue is still there, just not triggering the CEL.
When the issue starts out, I find some good highway driving tends to make the CEL ago away for a while. It will come back.
If you haven't already, you could check the rubber hose between the engine and the EGR valve. At this age, those hoses start cracking and leaking vacuum. Cheap easy fix if it needs replacing too.
Sent from my Pixel 3 XL using Tapatalk
-04 S430
-04 Terminator
-16 T&C (whole family van)
Huachipato is offline
post #5 of 16 (permalink) Old 06-06-2019, 11:07 AM Thread Starter
Quoted: 13 Post(s)
I got the MAF off and realized the bolts have an unusual head- are they E and what size. The EGR is different than the EGR pipe.thanks
bmoe100 is offline
post #6 of 16 (permalink) Old 06-06-2019, 11:26 AM
Vehicle: '04 S430
Quoted: 29 Post(s)
This is what I purchased a few months ago:
https://smile.amazon.com/gp/product/B000I45Y8Q
I don't recall which sizes was needed for the EGR valve. That set is all I have and has had all I needed for the repairs I've done so far. If you plan on working on your W220 - it is probably a good idea to get the set anyways.
-04 S430
-04 Terminator
post #7 of 16 (permalink) Old 06-06-2019, 11:50 PM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 715 Post(s)
That's a good range of sizes
Dave
Dave2302 is offline
post #8 of 16 (permalink) Old 06-07-2019, 08:54 AM
Quoted: 962 Post(s)
Yep, that looks like a good set.
Here's the set that I bought. This one's made by Lisle; Sears happened to have it on sale back when we still had a Sears store.
https://www.fcpeuro.com/products/mas...cket-set-26280
cowboyt is offline
post #9 of 16 (permalink) Old 06-08-2019, 10:12 AM Thread Starter
Quoted: 13 Post(s)
Got MAF out of the way. The main tube was fairly clean. One of 2 vacuum lines was old( I did not see a hole but it crumbled taking it off) so replaced both. I drove 60 miles but error code still on. In order to take EGR out(since check engine light still on) I need to access E or star socket underneath the round metal pipe that is running from 6 to 3 o clock. How do I access it? Is there a trick? The round pipe would seem to be hard to get off. To get the yellow clip off do I squeeze the wires or pull them apart?
Are Pierburg EGR valves ok?
Thanks
bmoe100 is offline
post #10 of 16 (permalink) Old 06-08-2019, 04:35 PM
Date registered: Dec 2012
Vehicle: 2003 S430
Quoted: 377 Post(s)
To remove the yellow connector, pull the wire loop up.
Wally
wallyp is offline
