EGR how do I get MAF out of the way? - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 06-08-2019, 04:41 PM
Date registered: Feb 2009
Vehicle: '04 S430
Quoted: 29 Post(s)
I used a wobble head extension to get the bold bolts.
ARES 70330 | 9-Piece Wobble Extension Set | Premium Chrome Vanadium Steel Construction | 1/4-inch, 3/8-inch and 1/2-inch Drive Sizes Included | Storage Tray Included https://www.amazon.com/dp/B07BW1764L..._7Be.CbWFWVQZF
I don't have that set in particular - just linked for reference. I got my set from Harbor Freight (cheap). It allows you to access bolts at an angle.
Sent from my Pixel 3 XL using Tapatalk
Dave2302 likes this.
-04 S430
-04 Terminator
-16 T&C (whole family van)
Huachipato is offline
post #12 of 16 (permalink) Old 06-08-2019, 05:22 PM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 885 Post(s)
Originally Posted by bmoe100 View Post
Got MAF out of the way. The main tube was fairly clean. One of 2 vacuum lines was old( I did not see a hole but it crumbled taking it off) so replaced both. I drove 60 miles but error code still on. In order to take EGR out(since check engine light still on) I need to access E or star socket underneath the round metal pipe that is running from 6 to 3 o clock. How do I access it? Is there a trick? The round pipe would seem to be hard to get off. To get the yellow clip off do I squeeze the wires or pull them apart?
Are Pierburg EGR valves ok?
Thanks
EGR function is evaluated by MAP sensor on front if intake manifold. Remove air pump and check, replace vacuum lines leading to MAP and SAI valve.
To remove EGR valve you need 1/4 E10 swivel socket.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #13 of 16 (permalink) Old 06-09-2019, 02:26 AM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 720 Post(s)
Pierburg are an OEM, yep fine
Dave
Dave2302 is offline
post #14 of 16 (permalink) Old 06-10-2019, 05:17 PM Thread Starter
Date registered: Apr 2015
Quoted: 13 Post(s)
Thanks everyone
Pierburg is fine if I need it
so I need a wobble extension
I drove another 80 miles and light went out. The degraded hose may have been a factor. Will see.
Witek If error code comes back will try to find air pump and related hoses before changing EGR
bmoe100 is offline
post #15 of 16 (permalink) Old 06-11-2019, 08:01 AM
Date registered: May 2011
Vehicle: 2005 S600
Quoted: 54 Post(s)
In addition to wobble extensions, and universal joints/extension, I have this set, purchased just to enable me to get at things on the MB:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Universal sockets are compact enough to get in spaces where a socket + universal extension, or socket + wobble extension cannot.
Current Fleet:
2016 Tundra 1794
2005 MB S600 (100K, Michelin AS3+, M1 0W40)
2002 V70-XC (228K Castrol 0W40)
2002 V70-T5 (198K, Mobil 1 0W40)
1932 Packard Sedan (straight 8, dual sidemount spares, original paint and interior, Shell Rotella 15W40)
Astro14 is offline
post #16 of 16 (permalink) Old 06-12-2019, 05:49 AM
Witek_M's Avatar
Vehicle: 1972
Quoted: 885 Post(s)
Remove air pump (5) and replace vacuum hoses 119. Going back don't forget to put air pump ground wire over bolt 23.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
