Will these aftermarket heated/ventilated seat kits work? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-23-2019, 05:42 AM Thread Starter
Date registered: Jan 2018
Vehicle: 2002 S320
2002 s320 pre facelift, will these kits work? I think my leather is perforated already.
ThunderHex is offline
post #2 of 4 (permalink) Old 05-23-2019, 07:12 AM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 720 Post(s)
Hi,
I expect they work, quality is dubious until it's a known quantity.
If I were you I'd visit a wrecking yard, pull a pair of Heated / Cooled Seats and left / right Front Door Control Modules, and fit them.
Don't stress if you can't get the right trim colour it is fairly straightforward to swap the covers especially as you have to R&I them to install the heated / cooled parts anyway, and if you can get the correct colour then it will take you about 2 hours to install the whole lot
HTH,
Dave
Dave2302 is offline
post #3 of 4 (permalink) Old 05-23-2019, 07:13 AM Thread Starter
Vehicle: 2002 S320
Originally Posted by Dave2302 View Post
Hi,
Don't stress if you can't get the right trim colour it is fairly straightforward to swap the covers especially as you have to R&I them to install the heated / cooled parts anyway, and if you can get the correct colour then it will take you about 2 hours to install the whole lot [IMG class=inlineimg]/forums/images/BenzWorld2/smilies/tango_face_wink.png[/IMG]
HTH,
Wow really? How complex is the wiring? My car never had heated seats so does a retrofit work easily?
post #4 of 4 (permalink) Old 05-23-2019, 08:34 AM
Dave2302's Avatar
Quoted: 720 Post(s)
Hi,
OK, I've never done this, but I have had my own Heated / Ventilated Seats out of the Car and in a million bits as I changed a damaged leather cover and added DVD Player Headrests.
IIRC, there will should be no extra wiring needed, DCM communicates with Seat Ctrl Module via CAN Bus, CAN Bus will already be there for the Seat Adjusters.
Worst case scenario you'll need to run a +ve feed from the Fuse Boxes to each Seat, but I think they run off the existing supply to the Seat Module anyways, I just had a very quick look and can see no separate Fuses or Relays listed for Heated Seats
You shouldn't even need to code the Modules on SDS if you get them all from the same Car.
HTH
Dave
Dave2302 is offline
