STAR lowering help - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-16-2019, 05:25 AM Thread Starter
Date registered: May 2019
STAR lowering help
What’s up guys I’m in need of some help. I have lowered 3 vehicles in the past with star with out issues( 06 cls x2 and e500 211). I attempted to adjust my ride height on my 220 yesterday with no success. Here are the detail. I have always used this method. Functions performed by more than one module>Chassis>level adjustment > suspension > initial start up > initial start up with manual adjustments> Lower with voltages with in parameters> set inclination angles and done.
this Is the first 220 I ever do. After selecting Functions control by more than one control module there is no option for chassis or suspension. So I decided to go to the air Matic module hit initial start up set the height and angles and hit done. As soon as I back out the car raises back up.
What is going on here?? Any ideas? What am I doing wrong. Air Matic is fully functional no errors or leaks. Thanks in advance
Fernando Lojero is offline
post #2 of 4 (permalink) Old 06-10-2019, 04:31 AM
jnash's Avatar
Date registered: Apr 2005
Vehicle: 2003 S55 AMG
Quoted: 31 Post(s)
W220 (ABC for sure) height adjustments never seem to work that well in STAR. I ended up buying adjustable length links for the height sensors.
2003 S55
K&Ns, 80mm TB, NPI headers, X-pipe / 3in pipes, Kleemann Cams & 168mm Pulley, ECU & TCU tune. 550cc injectors, Meziere WP136S SC pump. UPD SC pulley & SC belt wrap, Alum idler pulley set. Fuel rail loop, LFR7AIX plugs, NPI heat exchanger, -10C mod, shift paddles, TeleAid removed.
Lowering links (1.5" front, 1" rear), 18x9.5+35 offset rims, clear side markers, KG Key retrofit, H/W Valentine1, BT phone, BT AUX, laser jam, upgraded fans in seat backs, inline ABC mag filter.
jnash is offline
post #3 of 4 (permalink) Old 06-11-2019, 08:42 PM
Date registered: Dec 2004
Vehicle: 1972 280CE
Quoted: 152 Post(s)
Careful, if you use the star to adjust height, you could wipe your abc level settings which is not a fun issue to deal with (ask me how I know).
With best regards
Al
Check out the W114, W115 /8 enthusiast forum
alabbasi is offline
post #4 of 4 (permalink) Old 06-11-2019, 11:30 PM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 719 Post(s)
Hi,
Yes, this procedure works with Airmatic, but with ABC there are also "Plunger Travel Sensors" inside the Shocks, (that little plug on the top of each strut), so ABC knows where the Strut is sitting in relation to the Height Sensor readings, and so Tweaked "Romess" Angles are therefore un acceptable to an ABC Module, and then it locks you out until you get it right with the right equipment ..........................
With Airmatic however IMHO it is the correct way to lower them (a little).
I do not advocate lowering ABC at all, and Airmatic only to get it sitting nice, not slammed like Homey's Low Rider
HTH,
Dave
Dave2302 is offline
M120 Suppressor Engine Star / Chrome Merc-S600 W140 S-Class 20 03-26-2019 07:17 PM
Old German 6 Pointed Brewer's Star Teutone Off-Topic 2 03-02-2015 09:48 AM
Mercedes Star diagnosis Mb Star C3 Pro for Benz Trucks & Cars V07-2012 MEPEH-W140 For Sale/Wanted/Trade/Giveaway 8 02-06-2013 07:16 AM
Weird Spinning Star Defies Explanation isthisdave Off-Topic 12 01-26-2013 05:58 PM
Scientists Discover Monster Star isthisdave Off-Topic 8 07-21-2010 09:21 PM
