Couldn't turn on the Key - Mercedes-Benz Forum
post #1 of 25 (permalink) Old 04-26-2019, 01:16 AM Thread Starter
Date registered: Apr 2019
I have a w220 s 350 model. I couldn't turn on the key, what could be the problem..
Ajay Karthik is offline
post #2 of 25 (permalink) Old 04-26-2019, 04:59 AM
Date registered: May 2016
Vehicle: 2000 S430, 2003 S430, 2003 S600 TT, and 2005 E320 CDI
Quoted: 898 Post(s)
Same problem I had with the S600 last year; the key wouldn't turn at all. There are a few things to check.
1.) Did the fuse that powers the EIS (the ignition key receptacle) go pop? That's what happened on mine.
2.) Did the EIS itself go bad? There are US $10.00 things called EIS testers that will see if you're getting current flow through it.
3.) Do you have more than one Mercedes-Benz, with similar-looking keys, and put the wrong key into it? Don't laugh too hard; I've done this more times than I care to admit Granted, that's kind of a good "problem" to have.
If it's the fuse popping, then time to figure out why. In my case, the reed valve up front had gotten plugged, water got into the passenger-side interior, and things started shorting out (I fixed it).
Dave2302 likes this.
cowboyt is offline
post #3 of 25 (permalink) Old 04-26-2019, 06:07 AM
Date registered: Dec 2012
Vehicle: 2003 S430
Quoted: 370 Post(s)
First check is always, "Is the battery really good?".
Wally
wallyp is offline
post #4 of 25 (permalink) Old 04-26-2019, 07:22 AM
Quoted: 898 Post(s)
I discovered that if the battery has at least 11.5V, the key will turn. Didn't try going lower than that and not going to...not purposefully, anyway. :-)
2000 S430 (Dad's car, used for special occasions)
2003 S430 (one of two current DD's--second W220 project car, just for fun--decided to keep it after all)
2003 S600 (third w220 project car, the sports car)
2005 E320 CDI (the other current DD--first W211 project car)
Formerly--AND ONCE AGAIN! (I just married the girl):
2000 S500 (best friend's--now WIFE's--DD: my first W220 project car, once gone to, AND NOW RETURNED FROM, an excellent home--welcome back home, baby!)
cowboyt is offline
post #5 of 25 (permalink) Old 04-29-2019, 12:25 AM Thread Starter
Thank you for your reply, Sorry for not providing the details, actually my car battery was dead for a weak and when I tried to restart the car with jump I couldn't turn on the key .
post #6 of 25 (permalink) Old 04-29-2019, 03:20 AM
Vehicle: 2003 S430
Quoted: 370 Post(s)
First, fully recharge the battery and have it tested. Then, determine why it went dead, and fix that.
Wally
wallyp is offline
post #7 of 25 (permalink) Old 04-30-2019, 10:00 AM Thread Starter
I did recharge the battery but still problem remains the same. Where can I find the fuse for the EIS ?
post #8 of 25 (permalink) Old 04-30-2019, 10:57 AM
Quoted: 898 Post(s)
The Encyclopedia of Stickies has the fuse charts for all models of W220, by VIN.
cowboyt is offline
post #9 of 25 (permalink) Old 05-01-2019, 01:07 AM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 674 Post(s)
Including Pre Fuse Locations
Of course the first thing I'd do is plug it into SDS and see what is or isn't going on
Dave
Dave2302 is offline
post #10 of 25 (permalink) Old 05-01-2019, 06:52 AM
Date registered: Feb 2009
Vehicle: '04 S430
Quoted: 27 Post(s)
SDS - as best as I can tell - requires the key to be in the ACC position to work.
-04 S430
-04 Terminator
-16 T&C (whole family van)
Huachipato is offline
Smart key won't turn in ignition/EIS problem 98w202 W202 C-Class 37 06-08-2016 11:16 PM
Help Please msaffar W220 S-Class 6 05-18-2014 09:13 PM
Odd key & tumbler event. sbaert W124 E,CE,D,TD Class 15 02-16-2011 12:20 PM
Key wont turn, hope these info may help jcmbz W201 190-Class 16 06-27-2009 01:36 PM
Casting a key (or whatever) ScottinSoCal R/C107 SL/SLC Class 44 03-03-2008 05:03 AM
