Couldn't turn on the Key - Page 3 - Mercedes-Benz Forum
post #21 of 25 (permalink) Old 05-08-2019, 05:16 AM
Date registered: Jan 2019
Vehicle: 2004 Mercedes S430 4Matic
Quoted: 16 Post(s)
Originally Posted by tusabes View Post
You still are not providing enough details . Did the car start when you jumped it ? If you turn the car back off the battery is still too weak and the key will not turn .
Start by taking the battery out of the cAr and having it tested . If you are in the USA places like oreilly auto parts will test and charge your battery for free .
If the battery is good (and that’s a big if- it probably is not charged if you just tried to jump start without a proper charger ) you likely blew the fuse under passenger floor carpet when you tried jump starting it
https://youtu.be/Jb_7E-Z5D7g
DO NOT DO WHAT THIS GUY SAYS IF YOU THROW HIGH CURRENT TO THE LOWER RIGHT SIDE OF THIS JUNCTION BOX UR BY PASSING ALL THE FUSES AND CAN BLOW OUT A FEW SAM MODULES AND ALOT OF FUSES.
YOU SHOULD ONLY CHARGE HERE WITH LOW CURRENT SAY 2 OR 10 AMP MAX
AND ONLY SAYING ON THE LEFT SIDE FEED
Stay on the left side. The big fat long red one on the top left.
I'd say ur battery was low and thats why ur key wouldnt turn and now you blew a fuse or two in the junction box or blew out a sam or two.
That junction box has midi fuses a yellow 60 amp a red 150amp and I think a 100 amp
Check for power from the thick red one on the top left to the three on the right
Make sure you have battery power accross the junction box
It sends power to all the sams/fuses and engine control under both engine fuse boxes
Including EIS
cudamax is offline
post #22 of 25 (permalink) Old 05-12-2019, 10:40 PM Thread Starter
Date registered: Apr 2019
I have attached the images of the fuse boxes under the hood, which fuses should I check.
ID:	2512198   Click image for larger version
Ajay Karthik is offline
post #23 of 25 (permalink) Old 05-13-2019, 05:24 AM
Quoted: 16 Post(s)
All of them
cudamax is offline
post #24 of 25 (permalink) Old 05-13-2019, 06:18 AM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 670 Post(s)
NONE OF THEM ACTUALLY
(although it wouldn't hurt to check them)
Those are not the Pre Fuses, it has already been posted where to find Pre Fuses.
Dave
Dave2302 is offline
post #25 of 25 (permalink) Old 05-13-2019, 11:10 PM Thread Starter
I didn't find any fuse boxes in the place mentioned in the post .. actually it's Indian make and it's a RHD.
Smart key won't turn in ignition/EIS problem 98w202 W202 C-Class 37 06-08-2016 11:16 PM
Help Please msaffar W220 S-Class 6 05-18-2014 09:13 PM
Odd key & tumbler event. sbaert W124 E,CE,D,TD Class 15 02-16-2011 12:20 PM
Key wont turn, hope these info may help jcmbz W201 190-Class 16 06-27-2009 01:36 PM
Casting a key (or whatever) ScottinSoCal R/C107 SL/SLC Class 44 03-03-2008 05:03 AM
