Adjusting ride height - Mercedes-Benz Forum
post #1 of 24 (permalink) Old 04-19-2019, 01:22 PM Thread Starter
Date registered: Jan 2018
Vehicle: '04 S500 4Matic
Quoted: 44 Post(s)
I know there are lots of threads on the various ways to make adjustments, and the real correct way being a proper airmatic calibration.
However, I have had a mismatch in my ride height since I got the car. I have taken it to a couple of independent specialists who have done ride height calibrations and it's still pretty much the same. I spoke to the dealer and the service person I spoke to said they wouldn't simply do a ride height calibration, they would start by looking into why the height is uneven and proceed from there. Makes sense, but I am a little concerned about how quickly dealers can get expensive.
You can see in the photo below, my front driver side is too high. I have checked on very level ground and it's the same. The passenger side front looks normal. I have checked the sensor linkage and the sensor arms and it all looks normal.
So, I bought some lowering links (Ghost). My plan was to make minor adjustments. Not to lower the car too much, but to get it looking as close to stock as possible. My aim is stock.
Does anyone have any comments on this? I am wondering what the risks are if any? Once I have it at a good height and it's stable after a few drives I was going to get an alignment done.
This car isn't a daily driver. I walk to work. It's purely a recreational thing that I don't use very often. If it was a daily driver that I depended on I would probably go the dealer route.
Thanks
Oliver
oliverp is offline
post #2 of 24 (permalink) Old 04-19-2019, 03:26 PM
Date registered: Dec 2012
Vehicle: 2003 S430
Quoted: 374 Post(s)
I would spend a lot of time on the front ride height sensors before doing anything else. It wouldn't take much bend or misalignment in the linkage or the sensor to cause the problem. It might not take much adjustment to fix the problem.
Dave2302 and oliverp like this.
Wally
wallyp is offline
post #3 of 24 (permalink) Old 04-20-2019, 01:55 AM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 695 Post(s)
Hi,
Just to add to what Wally says, first off if the rest of the Cars corners are correct I would be comparing V readings between Left Front and Right Front, in SDS Actual Values .............
If they are different carefully compare the linkages, especially if the Car has had the Upper Left Wishbone replaced with a cheapie, I've seen the holes drilled in the wrong place
If you are convinced Linkage is OK, then fit a new Genuine Sensor, and get it Calibrated, you need a real good Indie for this !!
Please don't fit those stupid lowering links, they are a bodge, the Cars never came out of the factory sitting like that
alabbasi and oliverp like this.
Dave
Dave2302 is offline
post #4 of 24 (permalink) Old 04-20-2019, 03:38 AM Thread Starter
Quoted: 44 Post(s)
Thank you both, I will spend some more time troubleshooting first. I'll go down and actually measure things either side (like the sensor arms and distances between various components).
Dave, the exact symptoms are the front left high. Front right looks normal, rear right looks low and rear left looks normal. I don't remember exact readings, but when I plug in SDS, the numbers seem to match what I am seeing. I don't know exactly what the numbers mean, but the differences in each number match the symptoms.
Maybe like Wally says the front left sensor arm is bent, so it's shorter - but I just haven't seen it yet. I wonder if it's possible that the top control arm/wishbone is bent down?
I will carefully compare each side.
I really don't want to do anything that isn't stock. As well as it looking odd, I am wondering how if affects the ride quality.
Thanks
Ollie
Dave2302 likes this.
oliverp is offline
post #5 of 24 (permalink) Old 04-20-2019, 04:00 AM Thread Starter
Quoted: 44 Post(s)
OK here is another update with photos. The bad side does look a bit different. At the very least, the sensor arm doesn't seem to be properly on the ball joint.
Does anybody notice anything else of concern?
The good side has the Arnott logo visible on the strut. The bad side has the white grease sprayed around (this was me a few months ago).
Thanks again
Ollie
ID:	2506116   Click image for larger version
oliverp is offline
post #6 of 24 (permalink) Old 04-20-2019, 06:22 AM Thread Starter
Quoted: 44 Post(s)
Actually looking closer, I wonder if I need to loosen the bracket at the control arm and rotate the sensor arm counter clockwise a bit?
oliverp is offline
post #7 of 24 (permalink) Old 04-20-2019, 07:23 AM
Vehicle: 2003 S430
Quoted: 374 Post(s)
May just be the angle of the photo (although you did a great job with them), but it looks to me as if the fastener between the bottom of the link and the sensor arm is at an angle.
Wally
wallyp is offline
post #8 of 24 (permalink) Old 04-20-2019, 07:37 AM
Dave2302's Avatar
Quoted: 695 Post(s)
Hi @oliverp ,
I've studied them pics until my eyes hurt, and I really don't spot anything there that is too far out and would cause this
My money is on incorrect Calibration
You will find that when the Left Front is at the correct height the Right Rear should come up a little, Rear end only has one sensor and raises or lowers the Rear Shocks according to an average computed by the Airmatic Controller
Dave
Dave2302 is offline
post #9 of 24 (permalink) Old 04-20-2019, 07:37 AM Thread Starter
Quoted: 44 Post(s)
Thanks Wally. I just sprayed the top and bottom bolts with some penetrating fluid. I'm going to let it sit for a bit and then see if I can loosed and adjust everything
oliverp is offline
post #10 of 24 (permalink) Old 04-20-2019, 07:38 AM Thread Starter
Quoted: 44 Post(s)
Thanks Dave. I will try and have a play with the linkage and I may have to give in and take it to the dealer if I can't fix it!
Or, I might swap it for a W140
oliverp is offline
Ride Height Specs Smokinb W220 S-Class 10 11-21-2017 12:27 AM
w126, raised ride height, shock absorber lengths AustralMercedes W126 S,SE,SEC,SEL,SD,SDL Class 6 05-12-2016 07:08 PM
Viano standard ride height VENTUZIAST V-Class 1 04-27-2016 11:52 AM
Thoughts on ride height, steering axis inclination, and wheel offset. Six_wheeler W124 E,CE,D,TD Class 14 12-27-2015 04:45 PM
300TD - How to set rear ride height? sdelasal W123 E,CE,D,CD,TD,TE Class 5 02-01-2006 05:42 PM
