Adjusting ride height - Page 3 - Mercedes-Benz Forum
post #21 of 24 (permalink) Old 04-21-2019, 11:39 PM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 696 Post(s)
Good call Sonny
doni01 likes this.
Dave
Dave2302 is online now
post #22 of 24 (permalink) Old 04-22-2019, 12:03 PM Thread Starter
Date registered: Jan 2018
Vehicle: '04 S500 4Matic
Quoted: 44 Post(s)
Hi Doni (Or Sonny!)
I read through that forum post a couple of days ago. I checked the level sensor as best I could, but I didn't want to unscrew it fully because the bolts looked quite rusty and I was scared of breaking something.
It would make sense though, because the adjustment I made was tiny - probably just as if it wasn't seated properly.
I'll jack it up again at the weekend and check it out.
Thanks
Ollie
oliverp is offline
post #23 of 24 (permalink) Old 04-22-2019, 03:39 PM
doni01's Avatar
Date registered: Jun 2012
Vehicle: S500 4Matic 2005
Quoted: 105 Post(s)
Originally Posted by oliverp View Post
Hi Doni (Or Sonny!)
Thanks
Ollie
It is very easy to miss that little hole completely. Just remove the tire and you will be able to see it
Dave2302 likes this.
doni01 is offline
post #24 of 24 (permalink) Old 04-23-2019, 05:47 PM
Smokinb's Avatar
Date registered: Dec 2012
Vehicle: 2004 S430, 2014 E400 Cabriolet
Quoted: 16 Post(s)
After I replaced all the front suspension parts, I took my car to the dealer for alignment. The did it and when i got my car back, the front end was jacked up like yours. I noticed right away and said it didn't look right. if the back was jacked up, well...that might look ok.. but the front? The service writer said if he took it back and the car fell into specs, they'd charge me another $225 or whatever. I was pissed and just left. Then came back later and talked to the service manager. He agreed to hook it up and get it level. I still don't like going there and make a point to stay clear of that service writer.
Smokinb is offline
Ride Height Specs Smokinb W220 S-Class 10 11-21-2017 12:27 AM
w126, raised ride height, shock absorber lengths AustralMercedes W126 S,SE,SEC,SEL,SD,SDL Class 6 05-12-2016 07:08 PM
Viano standard ride height VENTUZIAST V-Class 1 04-27-2016 11:52 AM
Thoughts on ride height, steering axis inclination, and wheel offset. Six_wheeler W124 E,CE,D,TD Class 14 12-27-2015 04:45 PM
300TD - How to set rear ride height? sdelasal W123 E,CE,D,CD,TD,TE Class 5 02-01-2006 05:42 PM
