Adjusting ride height - Page 2 - Mercedes-Benz Forum
post #11 of 24 (permalink) Old 04-20-2019, 09:54 AM Thread Starter
Date registered: Jan 2018
Vehicle: '04 S500 4Matic
Quoted: 44 Post(s)
I jacked up the car and took off the sensor arm. I put it all back and I also added a couple of small washers at the bottom of the control arm to try and make it go down a bit (I know... I shouldn't need to do this)
It's raining a lot here today so I won't take it out. I will go for a drive tomorrow and see if I can get that corner down a bit.
oliverp is offline
post #12 of 24 (permalink) Old 04-20-2019, 12:26 PM Thread Starter
Quoted: 44 Post(s)
Well rightly or wrongly, I installed 3 washers and it's what I would consider normal now
oliverp is offline
post #13 of 24 (permalink) Old 04-20-2019, 01:04 PM
Date registered: Feb 2008
Vehicle: Too many to list
Quoted: 1517 Post(s)
The washer method is cheap and works well
oliverp likes this.
tusabes is offline
post #14 of 24 (permalink) Old 04-21-2019, 01:16 AM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 699 Post(s)
Hi,
OK so that worked for you, but it does mean, like I said earlier, that the only problem is that the Calibration is in fact wrong
mersum1es and doni01 like this.
Dave
Dave2302 is online now
post #15 of 24 (permalink) Old 04-21-2019, 05:29 AM Thread Starter
Quoted: 44 Post(s)
Hi Dave
Yep, I know I need to get it calibrated - I've tried a few times at different indies, but they either don't know how to do it properly, or don't have the right equipment. So I think my only option is the dealer. This just makes me nervous. I am in downtown Toronto with a huge dealership and I've heard they are very expensive. I don't mind paying to do it right, but I'm afraid I will just end up dealing with a service sales person who's just going to run off a big list of things they advise me to do.
I'm going to monitor it for a bit. Do you think I should get an alignment after making the height adjustment?
Thanks
Ollie
oliverp is offline
post #16 of 24 (permalink) Old 04-21-2019, 07:26 AM
Date registered: Dec 2012
Vehicle: 2003 S430
Quoted: 375 Post(s)
If the alignment was good before you changed the ride height, it should be good now.
Just enjoy the car, but keep an eye out for any problems...
Dave2302 likes this.
Wally
wallyp is offline
post #17 of 24 (permalink) Old 04-21-2019, 08:00 AM
Date registered: Jan 2019
Vehicle: 2004 Mercedes S430 4Matic
Quoted: 19 Post(s)
Ride Height affects Caster/Camber and toe big time and I think ur air suspension valve block needs replacement with the better plastic bodied ones along with a new filter and rubber holder
oliverp likes this.
cudamax is offline
post #18 of 24 (permalink) Old 04-21-2019, 08:06 AM
Quoted: 19 Post(s)
https://suncoreindustries.com/produc...ic-a2203200258
Ithink these are better than aluminum bodied ones
oliverp likes this.
cudamax is offline
post #19 of 24 (permalink) Old 04-21-2019, 10:00 AM
Dave2302's Avatar
Quoted: 699 Post(s)
Hi @oliverp ,
Trouble is the Stealers likely won't do a decent job either
I'd do as @wallyp says, monitor it to make sure the Tyres aren't wearing an edge and if it's good, leave well alone ............
"If It Ain't Broke, Don't Fix It"
oliverp likes this.
Dave
post #20 of 24 (permalink) Old 04-21-2019, 11:01 AM
doni01's Avatar
Date registered: Jun 2012
Vehicle: S500 4Matic 2005
Quoted: 105 Post(s)
Hey Oliver,
I am a little late to the party since was on vaca and got in late last night BUT have you done upper control arms?? If you have, check this...https://www.benzworld.org/forums/w22...then-rest.html
doni01 is online now
Ride Height Specs Smokinb W220 S-Class 10 11-21-2017 12:27 AM
w126, raised ride height, shock absorber lengths AustralMercedes W126 S,SE,SEC,SEL,SD,SDL Class 6 05-12-2016 07:08 PM
Viano standard ride height VENTUZIAST V-Class 1 04-27-2016 11:52 AM
Thoughts on ride height, steering axis inclination, and wheel offset. Six_wheeler W124 E,CE,D,TD Class 14 12-27-2015 04:45 PM
300TD - How to set rear ride height? sdelasal W123 E,CE,D,CD,TD,TE Class 5 02-01-2006 05:42 PM
