722.6 auto-gearbox dipstick - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 04-13-2019, 01:31 AM Thread Starter
Digger41's Avatar
Date registered: Feb 2008
Vehicle: 1999 S430, Jaguar XJ-SC V12, Jaguar MK2, JaguarS-Type
Hi all, can someone please tell me the length that the dipstick goes into the tube, ie, how many inches.
When I put mine in to check I can never seem to find the right place to stop.
Seems to have a little resistance but I can push it in all the way!!
I checked the archives but no luck.
Cheers, Brian.
Digger41 is offline
post #2 of 16 (permalink) Old 04-13-2019, 05:36 AM
Date registered: May 2011
Vehicle: 2005 S600
Quoted: 54 Post(s)
The dipstick hits bottom, and you stop there. Read the fluid level in mm from the bottom of the dipstick.
It is longer than the tube. It's not designed to be left in place. It's a "tool" for checking the level.
When you're done checking the level, then put the cap back in place with a new red locking tab.
Put the dipstick back in your tool box.
Dave2302 likes this.
Current Fleet:
2016 Tundra 1794
2005 MB S600 (100K, Michelin AS3+, M1 0W40)
2002 V70-XC (228K Castrol 0W40)
2002 V70-T5 (198K, Mobil 1 0W40)
1932 Packard Sedan (straight 8, dual sidemount spares, original paint and interior, Shell Rotella 15W40)
Astro14 is offline
post #3 of 16 (permalink) Old 04-13-2019, 04:47 PM Thread Starter
Digger41's Avatar
Hi Astro, I know all that mate but I have a problem knowing when it hits bottom as first post.
Cheers, Brian.
Digger41 is offline
post #4 of 16 (permalink) Old 04-13-2019, 05:37 PM
Vehicle: 2005 S600
Quoted: 54 Post(s)
Hey Digger - sorry to have misunderstood...
So, the one that I use goes in about 36", give or take. (might be an inch or two more, it's sitting in my tool box at the moment)
About 4" sticks out when the tip hits bottom on the pan. I would guess that yours is about the same, since they're all sold as a "service tool" and that leads me to believe that they are the same...from memory, they're about 40" long.
This transmission is known as the NAG1 - (new automatic gearbox 1) and used in a lot of Chrysler and Dodge vehicles. A perusal of those fora and a bit of Googling and you'll get lots of information on this trans.
Hope that helps.
If you need a more precise measurement on the length of the one that I am using, I'll take a look in the morning.
Cheers,
Astro
Current Fleet:
2016 Tundra 1794
Astro14 is offline
post #5 of 16 (permalink) Old 04-13-2019, 11:44 PM
Date registered: Dec 2012
Vehicle: 2006 S500 4matic
Quoted: 50 Post(s)
Astro
Astro,
Do you mean that S-class MB transmission is used at Chrysler and Dodge ?!!
Barmaley is offline
post #6 of 16 (permalink) Old 04-13-2019, 11:48 PM
Quoted: 50 Post(s)
Wow - I did not know that! My car came without dipstick and I was hunting for one from donor cars. I finally found one and left it forever in the car. Frankly, I never used it since I can check oil level on instrument cluster.
Did I ruined my engine? What is the reason not to leave it there? Do I need one anyway or better just get rid of it?
Barmaley is offline
post #7 of 16 (permalink) Old 04-14-2019, 12:42 AM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 716 Post(s)
No one is talking about Engines in this thread !!
BTW the Mercedes 5 Speed Auto Trans is also called 722.6 which is the MB Number, then depending upon exact fitment / ratios etc it has more numbers ........... like ...........
722.6??
I can see OP already knew this by his Thread Title
HTH,
Dave
Dave2302 is offline
post #8 of 16 (permalink) Old 04-14-2019, 12:53 AM Thread Starter
Digger41's Avatar
Thanks Astro, that's a good start.
If you do get the time a more precise measurement would be great.
Cheers, Brian.
Digger41 is offline
post #9 of 16 (permalink) Old 04-14-2019, 01:02 AM
Dave2302's Avatar
Quoted: 716 Post(s)
HTH,
ID:	2504336   Click image for larger version
MikeKerr likes this.
Dave
Dave2302 is offline
post #10 of 16 (permalink) Old 04-14-2019, 06:05 AM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 885 Post(s)
Dipstick does not stop against bottom of the pan. Shoulder of measuring tip stops against the funnel in conductor plate.
Dave2302 and cowboyt like this.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
2003 A170 auto gearbox swap Chris Souch W168 A-Class 1 08-10-2015 03:42 PM
2002 V220 CDI AUTO Gearbox Problems newboos V-Class 0 05-10-2015 07:56 AM
1992 190e 2.3 auto with oil coming out dipstick? WRCWare W201 190-Class 49 01-22-2011 01:14 PM
Which c270 cdi auto gearbox? darthmal W203 C-Class 0 05-24-2010 05:04 PM
auto gearbox does change gear carlwil V-Class 2 03-09-2009 12:39 AM
