Pre-safe unavailable/Airmatic visit workshop - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-10-2019, 03:14 PM Thread Starter
Date registered: Jan 2019
Vehicle: 2005 S500 with amg package
Hi All
I have put a new front air shock on my 2005 S500 front left/drivers side. The car looks to be approx the right height but i'm getting two warning signs: -
Pre-safe Unavailable
Airmatic visit workshop.
I tried disconnecting the battery for approx 30 seconds and reconnected it but i still get the warnings.
any idea what i screwed up while installing the shock?
Thanks
gpjlytham is offline
post #2 of 4 (permalink) Old 04-10-2019, 05:06 PM Thread Starter
I put the car back on axle stands, disconnected the battery, took off the front wheel and disconnected the the 2 electrical sockets one from the new shock and another elec connector that clips to the new shock elec connector. The pins in the connectors all looked good, not bent, so i put it back together again and wiggled the thing at the top of the a arm, it's an electrical thing that I assume senses the height or angle of the a arm.
put the wheel back on, got the car off the axle stands and took it for a run.
no warning lights. I guess the electric connectors weren't attached all the way?
Hopefully it's all fixed.
post #3 of 4 (permalink) Old 04-10-2019, 06:14 PM
Date registered: Jun 2018
Vehicle: 2005 SL65 plus 13 other non MB toys
Quoted: 76 Post(s)
Two things...
First, stop disconnecting that battery. Not good practice.
Second, run a quick test using SDS. You will probably have a lot of codes stored. Erase them and take it for a short drive then run the test again. Lots of good info to be gained. The ultimate goal is no "F","f" or "i"'s. Wish mine was that way. I still have some air line leaks to repair in the seats and door locks.
Best tool you can have owning a Benz.
Dave2302 likes this.
Triple cranks is offline
post #4 of 4 (permalink) Old 04-10-2019, 07:55 PM
Date registered: Dec 2012
Vehicle: 2003 S430
Quoted: 370 Post(s)
A poor connection on the two connectors in the single jack is a very common problem, so there is a very good chance that you fixed it...
Wally
wallyp is offline
E320, 04, REDUCED BRAKING POWER - VISIT WORKSHOP brown1959 W211 E-Class 5 07-11-2015 08:29 PM
2005 CL600 Tele-Aid 'visit workshop' message in IC brucemendel Audio & Telematics Forum 1 06-02-2010 10:45 PM
Hooray...Airmatic Visit Workshop barristerbear W220 S-Class 8 04-10-2010 03:29 AM
Stop Lamp Visit workshop and Restraint System Visit Workshop! Jas Merc 230K W203 C-Class 0 01-21-2010 09:03 AM
EL power control. EPC visit workshop fault any ideas??? paulhandley W210 E-Class 1 04-10-2009 10:12 AM
