The greedy pay twice - Page 3 - Mercedes-Benz Forum
post #21 of 65 (permalink) Old 04-09-2019, 07:30 AM
Date registered: May 2016
Vehicle: 2000 S430, 2003 S430, 2003 S600 TT, and 2005 E320 CDI
Quoted: 965 Post(s)
Yep. I'm a n00b. If I can learn how, and that process is ongoing, then believe me, anyone can. And to get to drive cars like these, oh boy, is the effort worth it.
2000 S430 (Dad's car, used for special occasions)
2000 S500 (wife's DD: my first W220 project car)
2003 S600 ("sex on wheels"--second w220 project car)
2003 S430 (one of two current DD's--third W220 project car)
2005 E320 CDI (the other current DD--first W211 project car)
cowboyt is offline
post #22 of 65 (permalink) Old 04-09-2019, 08:06 AM
Date registered: Dec 2012
Vehicle: 2003 S430
Quoted: 377 Post(s)
"You definitely get what you pay for."
I wish that were true. A more accurate saying would be "You rarely get more than you paid for. You might not get as much as you paid for, but you almost never get more."
I agree on the profanity.
MikeKerr and Triple cranks like this.
Wally
wallyp is offline
post #23 of 65 (permalink) Old 04-09-2019, 11:52 AM
doni01's Avatar
Date registered: Jun 2012
Vehicle: S500 4Matic 2005
Quoted: 107 Post(s)
Where is the OP ?? Hopefully he didn't get hurt since the "Mobile Mechanic" had done both sides...
doni01 is offline
post #24 of 65 (permalink) Old 04-09-2019, 08:15 PM Thread Starter
Vehicle: 2006 S500 4matic
Quoted: 50 Post(s)
Hi Guys,
I was dealing with my car so did not get a chance to check with the forum, and there are a lot of posts here.
First about the tire. Last time I checked the tire was exactly one year ago when I passed State inspection. The inspector told me that the tire passed but is very low and I need to replace it ASAP. Since that I was not driving my car and in total I got about 1200 miles. The alignment obviously is so bad that the tire got to this terrible shape too fast.
About repair - on the picture is what I got. I pulled it from another car and I checked that those used parts are genuine MB parts. I assume you guys will be satisfied
My concern is about broken brake line. I remember what ones I changed a brake line on a Cadillac DTS and then a year later I brought it to a dealer to replace transmission they had to redo the line as well since I put it at an easier path, unfortunately it prevented the transmission to be removed from the car!!!
Obviously, I will use my original rotor and pads, the rest of the assembly I am planning on using the used one. The control arm looks to be very tight, hopefully recently replaces since the donor car had 160K miles. Would you recommend to replace some additional parts from the assembly? I think is should be very easy so install since everything is intact.
Barmaley is offline
post #25 of 65 (permalink) Old 04-09-2019, 09:20 PM
SDS Guru
Deplore's Avatar
Date registered: Apr 2014
Vehicle: 1998 MB E300TD, 1997 MB E320
Quoted: 763 Post(s)
Yes, replace the mechanic.
doni01, Dave2302 and cowboyt like this.
--1998 MB E300TD 291k
--1997 MB E36 Frankenstein'd AMG 199k
--2011 Suzuki DL650 58k
--1997 MB E320 161k. SOLD...loved that stupid car.
--1997 MB C36 AMG 273k -- stripped and junked
Deplore is online now
post #26 of 65 (permalink) Old 04-09-2019, 09:23 PM Thread Starter
Quoted: 50 Post(s)
I don't think so since I am going to do it myself this time and I am not replacing myself
cowboyt and Triple cranks like this.
Barmaley is offline
post #27 of 65 (permalink) Old 04-10-2019, 01:17 AM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 728 Post(s)
Hi,
So you ignored advice from an experienced Vehicle Examiner about the Tyre / Alignment ..................
You are concerned about doing a simple Brake Pipe, which you obviously made a hash of on the GTS ...................
You intend to re use a Disc and Pads that has had the entire front corner weight of the Car on them, dragging up the road before the Caliper Carrier eventually gave way, and the Wheel and Hub part company with the rest ....................
And are not going to replace potentially 160k mile parts like Wheel Bearing and Swivels with new ones !!
Yes a DIY owner can save a lot of money doing his own repairs, buuuuuuut .............
I have to agree with @Deplore I seriously don't think you have the aptitude for this, and I mean that in the nicest possible way.
Take it to a decent Indie and stick to non safety critical repairs yourself, before you kill yourself or someone else's family.
doni01 likes this.
Dave
Dave2302 is offline
post #28 of 65 (permalink) Old 04-10-2019, 06:52 AM
Date registered: Feb 2009
Vehicle: '04 S430
Quoted: 29 Post(s)
I can't imagine this being rocket science or too complicated a job. You learn a lot just doing it yourself too - so I would like to think with a good set of instructions he should be able to pull off this job just fine.
I have my own experience with a lousy mechanic on a similar job. The end result for me was just that the car sat for an extra month while I sourced all the parts the mechanic broke and ended up completing the job myself.
As for the parts used - I bet they will work for now. It will at least get him up and running again and buy time to get newer/better parts down the road. Assuming all the nuts and bolts get torqued down this go around, the worst case scenario should be extra squeaks and play from worn bushings and parts.
I got to imagine the old caliper/rotor/pads are fine too as they were protected by the wheel when it hit the eject button.
-04 S430 (sold)
-04 Terminator (for sale)
-16 T&C (whole family van)
-15 Tesla Model S (MB/Cobra replacement)
Huachipato is offline
post #29 of 65 (permalink) Old 04-10-2019, 10:04 AM
Quoted: 965 Post(s)
Yes, you can do it, and it's a good thing for you to learn. With that said, @Barmaley , yes, please do be careful and please do get the proper torque specs for everything that you're working on. While you're at it, go ahead and replace the brake disc, brake pads, ball joint, wheel hub assembly, all that stuff with new parts. Check out that axle, too; if it's good, you're fine, but if you have any doubt, then replace it, even though it's not cheap.
Regarding the control arm, if you see cracked rubber bushings, it's not a bad idea to replace those. If they're tight, though, this can wait a few years, but since it's apart anyway, now's a good time.
Regarding axles, I can tell forum members here that my S600 TT has 174,500 miles on it, and the axles (rears--all my Benzes are 2WD) are fine. Same with the 2003 S430 with 155K on its clock. So, it's entirely possible, and I'd even say probable, that the axle in that left front corner that Barmaley got second-hand is going to be OK.
cowboyt is offline
post #30 of 65 (permalink) Old 04-10-2019, 11:07 AM
Dave2302's Avatar
Quoted: 728 Post(s)
Hi,
Oh no they were not, they took the whole weight of that front corner while that Wheel was wobbling and hanging and eventually the weakest link, (the Caliper Carrier) snapped allowing the Wheel Disc and Hub to come off and rip out the Brake Pipes !!
Why risk using a stressed, maybe distorted, maybe cracked Disc, and maybe distorted, or un bonded Pads ..................
It just beggars belief
That's it I've done my bit, I'm outta here
Dave
Dave2302 is offline
Debt and Democracy Why Germany's Rich Must Pay Higher Taxes Teutone Off-Topic 4 08-28-2011 09:48 AM
U Will Pay Dprophet72 C219 CLS-Class 17 07-25-2011 01:33 AM
German Government will pay for Greece maine_coon Off-Topic 3 06-28-2011 04:55 AM
The Myth About Corporate Taxes Qubes Off-Topic 39 04-11-2011 11:22 AM
Pelosi and the Democrats Prevented From Murdering Impoverished American Babies Qubes Off-Topic 7 01-31-2007 09:37 AM
