Windshield Washer Reservoir Won't Hold Fluid - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-03-2019, 03:40 PM Thread Starter
Date registered: Aug 2014
Vehicle: 2012 E350 4Matic, 2003 S500 4Matic, 2001 S430
My 2003 S500 won't hold washer fluid. Within a few minutes of filling it up, the tank is completely dry. I've read prior posts that point to the hoses and grommmets, and actually I also have a 2001 S430 with a similar problem: Its tank also loses fluid but only above the point where the hose is connected. Since the S500 loses all of the fluid, I'm thinking it's probably not a hose or grommet problem but the tank itself....Wondering if the group agrees with my assessment.
Jtc63701 is offline
post #2 of 7 (permalink) Old 03-03-2019, 03:42 PM
noetico's Avatar
Date registered: Feb 2015
Vehicle: 2002 Mercedes ML320, Mercedes 190E 2.3L (sold), 2001 Mercedes c320(gone)
Quoted: 220 Post(s)
Sorry for the issue... If you find leaks underneath the car, tank may be cracked right under.
Kent
noetico is offline
post #3 of 7 (permalink) Old 03-03-2019, 04:10 PM
Date registered: Apr 2007
Vehicle: 2004 S500 4Matic, 2018 Ford Expedition Max, 2017 Jaguar F-Pace S, 2015 BMW 750Li
Quoted: 31 Post(s)
My car had this issue last year, and I first suspected a cracked tank. However, on inspection, it was fine. The culprit was a cracked headlight washer housing. If you remove the undertray at the bumper you can look up at the washer tubing and housing, and you can also look up at part of the tank. Hope this helps
Regards, John
NKJohn is offline
post #4 of 7 (permalink) Old 03-03-2019, 05:48 PM
Date registered: Mar 2015
Vehicle: 2006 S500 4matic, 2005 S500
Quoted: 75 Post(s)
Willing to bet it is the connection at the tank to the hose, it looks almost like a t connection. The replacement part is a new distribution line, about $150 (plus or minus) and about 90 minutes labor.
I did the job and spent the money. Had the same issue on another w220, and found a retrofit for about $4. A piece of vacuum tube over the connection, coated in gorrila glue, placed over the nipple is a great solution. Gorilla glue is a good match as it is water activated. I am working out of state, will send a picture of the retro repair in a week if interested. I am 99% sure this is your problem.
MikeKerr is offline
post #5 of 7 (permalink) Old 03-03-2019, 08:08 PM
Date registered: Feb 2009
Vehicle: '04 S430
Quoted: 27 Post(s)
I recently had the fluid leaking out of my car as well - and spot where the line connects to the pump had a slit through hose that attached to the nipple. It would just slowly loose all the fluid.
I did put some plastic repair tape over it and found another issue after that - where the line would just disconnect from the nipple. I used a few zip ties to hold it in place - a total red neck solution for now - but it is working alright.
I think I might look at adding some new vacuum hose and some glue to that spot - I bet that would do the trick in my case.
-04 S430
-04 Terminator
-16 T&C (whole family van)
Huachipato is offline
post #6 of 7 (permalink) Old 03-04-2019, 07:38 AM Thread Starter
Thanks (to everyone) for the replies.....And yes I'd love to see that pic when you get back home and have a chance to send it.
Thanks.
John
Jtc63701 is offline
post #7 of 7 (permalink) Old 06-09-2019, 12:08 PM
Vehicle: '04 S430
Quoted: 27 Post(s)
My Mickey Mouse fix ended up not lasting long. I took it all apart and made what I hope is a much more permanent solution to the problem I had. I made a video - hopefully it helps others:
Essentially Replaced the connection to the Windshield Washer motor with a Tee connection and a little bit of hose and some Window Weld to seal off the one side were the heater cable is threaded through...
-04 S430
-04 Terminator
Windshield washer reservoir leak Camman595 W124 E,CE,D,TD Class 13 09-11-2015 02:54 AM
Windshield washer fluid container not holding fluid... Jayhawk W220 S-Class 18 02-26-2015 07:17 AM
Windshield Washer Fluid Leak - Not The Grommet rudeney C209/A209 CLK-Class 0 07-12-2011 07:32 AM
Factory Windshield Washer Fluid easygreenus Detailing and Car Care 2 02-09-2007 07:46 PM
Windshield washer fluid pump/leak Guest (MBNZ) W124 E,CE,D,TD Class 1 07-25-2002 07:18 PM
