Removing battery to maintain it - Mercedes-Benz Forum
post #1 of 30 (permalink) Old 02-08-2019, 03:28 PM Thread Starter
Date registered: Jan 2018
Vehicle: '04 S500 4Matic
Quoted: 44 Post(s)
I am still working on the condo board to allow me to install a power outlet in the parking garage so I can use my battery tender.
I really don't want to use the car in this bad weather.
Is there any risk associated with removing the battery if I am not going to use the car for a month? I thought I could plug it into the tender in the condo.
Thanks in advance
Ollie
(2004 S500)
oliverp is offline
post #2 of 30 (permalink) Old 02-08-2019, 03:31 PM Thread Starter
Quoted: 44 Post(s)
Also, just to add. I understand I will need to reset the windows, seats, sunroof etc. I was more worried about the risk of breaking something
oliverp is offline
post #3 of 30 (permalink) Old 02-08-2019, 03:50 PM
STRGLZ's Avatar
Date registered: Oct 2018
Vehicle: 2003 S430 4Matic
Quoted: 12 Post(s)
Worst case scenario I think you're just gonna have to resync more stuff, the question is what and how. From what I've experienced if you just fully charge the battery before storing it for a month you should be fine.
jimknock likes this.
STRGLZ is offline
post #4 of 30 (permalink) Old 02-08-2019, 07:38 PM
Date registered: Feb 2011
Vehicle: 2009 E350 4M Avant Garde, My Mistress 2002 S600, Wife 2014 C300 4M Avant Garde with AMG
Quoted: 155 Post(s)
I use my sister-in-law's condo garage to store my W220 over the winter. First year I disconnected the battery, but big hassle to get things going again.
Since then, for several years, I leave it as is, and once a month connect a NOCO (Canadian Tire) intelligent charger over night. I have installed a NOCO wire extension (provided with lugs) to the battery terminals, which I leave hanging out of the closed trunk. I just plug the charger into that wire extension when needed.
I just plug in a long extension chord from an outlet in the garage, and wrap the extension chord along the water & sprinkler plumbing to the car, and connect the charger. There is no way I could get a dedicated 110 outlet at the the car space (condos!).
Kraut56 is offline
post #5 of 30 (permalink) Old 02-09-2019, 04:44 AM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 698 Post(s)
I got one thing to say .....................
linky:- https://www.benzworld.org/forums/w22...ension-18.html
Post #345
Dave
Dave2302 is offline
post #6 of 30 (permalink) Old 02-09-2019, 05:06 AM
STRGLZ's Avatar
Quoted: 12 Post(s)
Canadian brother ?
STRGLZ is offline
post #7 of 30 (permalink) Old 02-09-2019, 06:42 AM
Date registered: May 2011
Vehicle: 2005 S600
Quoted: 53 Post(s)
Three weeks is about the limit for how long I would leave the car without running it, or topping off the battery charge.
Since you can't plug in a full time charger, which would be my preference, and you can't add a solar trickle charger, I would suggest one of the following:
1. Run a long cord out to the car for a couple of hours each month with a smart charger. I've got this one: https://www.batterychargers.com/en/p...engine-starter
2. Get a second, small 12V battery and connect it while you bring yours in for a full charge each month.
Now, I've not tried this, but my wife and daughter each have a NOCO portable jumpstart charger. They WORK. My daughter jumped a friend's car that was so dead, she had to use the 'Manual Override" to get it to connect. They have the GB-40. It charges via a typical USB tablet-size (not cellphone) USB brick from the wall. Very convenient.
List price is a bit steep, there are cheaper places to buy it. https://no.co/gb40
I wonder if, perhaps, connecting that to your battery periodically and setting up for a "jump start" would add enough charge to keep your battery topped off?
Current Fleet:
2016 Tundra 1794
2005 MB S600 (100K, Michelin AS3+, M1 0W40)
2002 V70-XC (228K Castrol 0W40)
2002 V70-T5 (198K, Mobil 1 0W40)
1932 Packard Sedan (straight 8, dual sidemount spares, original paint and interior, Shell Rotella 15W40)
Astro14 is offline
post #8 of 30 (permalink) Old 02-09-2019, 08:05 AM Thread Starter
Quoted: 44 Post(s)
Thanks everyone. Coincidentally I bought a NOCO 7.2a charger yesterday. The maintenance man in the condo let me plug a long cord across the parking lot. When I plugged it in it showed under 25% charge, so I think I caught it just in time. It's been sitting for a couple of weeks and prior to that has only been out on short trips.
I like the idea of a second battery and swapping them out periodically, and maintaining the 2nd one in the condo.
I just need to figure out Dave's post that he linked to. I can't figure out how I can keep one battery plugged in at all times when swapping.
Also my current battery is a 'Motomaster' which I doubt is as good as a genuine MB. So my next step might be to go to the dealer for a decent battery. The good thing is, I don't think I have an abnormal draw when the car is off.
Thanks
Ollie
oliverp is offline
post #9 of 30 (permalink) Old 02-09-2019, 08:15 AM
STRGLZ's Avatar
Quoted: 12 Post(s)
Thanks
Ollie
Motomaster is rarely the best choice in any case.
STRGLZ is offline
post #10 of 30 (permalink) Old 02-09-2019, 09:00 AM
Date registered: Apr 2008
Vehicle: W219 320CDI -07 W220 320CDI -01 W210 270CDI -01 EX: W211 320CDI -04
Quoted: 109 Post(s)
jump start cables and spare battery parellel... but ALWAYS wait a while after connect another battery parallel to system, IF either of them is drained, big balancing current is running in cables which means great possibility to 'welding arc' or at least some harmful sparks when connecting cables... (sorry Dave didn't read you thread if you already mentioned it)
honestly I used to use double battery with my W211 but it was pretty ackward playing with cables and two heavy batteries in trunnk, so I went back to conventional way... only if I owned W203 I would use doubles, I never heard any other car so sensitive to voltage spikes...
edit: as a battery I use Varta and Varta only
-Do not try this at home -
mersum1es is offline
battery drain on my c180 Alex berlein W203 C-Class 0 10-02-2016 07:07 AM
Replacing the battery, do I need to maintain a 12v supply whilst changing it? Taipan W169 A-Class 1 02-07-2015 11:11 PM
New Battery "Quirk"? akent99 C209/A209 CLK-Class 30 05-08-2014 01:07 PM
Has anyone replaced their main battery? cadillacbart W251 R-Class 31 12-25-2011 07:15 PM
NOKIA Battery Advisory (BL-5C) Check Codes Off-Topic 3 08-14-2007 10:49 PM
