Removing battery to maintain it - Page 3 - Mercedes-Benz Forum
post #21 of 30 (permalink) Old 03-07-2019, 08:14 AM Thread Starter
Date registered: Jan 2018
Vehicle: '04 S500 4Matic
Quoted: 44 Post(s)
OK understood. Thanks for the input everyone!
Ollie
oliverp is offline
post #22 of 30 (permalink) Old 03-07-2019, 06:19 PM
Date registered: Oct 2007
Vehicle: 1984 500 sec
Quoted: 9 Post(s)
Another approach that is considerabley more straightfoward would be to get a Battery Monitor. I purchased a Battery Monitor from the Google Playstore for my Android phone. It is was listed as a BM2 monitor. It works quite well. It is a device that attaches to the battery and transmits via bluetooth the status of my pattery. Voltage, Cranking voltage, Charging test, and has set points for notification if the battery is out of usable range. It keeps a history of readings, too. I get a status update twice per day. Paid about $35 for it. It gave me notice when I needed a battery replacement. Futher, you could use it to notify you to go to the garage and run your car for a period of time to recharge the battery. Last, a drained battery causes a severe shortening of overall battery life. Keep it topped off.
oliverp likes this.
500sec_dave is offline
post #23 of 30 (permalink) Old 03-08-2019, 12:20 AM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 696 Post(s)
Thanks Kraut, I didn't even think about the Cig Lighter off without Ignition, but irrelevant as he was thinking of OBD Plug In, but that circuit likely has an even lower Amp fuse so it still has one helluva risk to it
The easiest option is to go down there once every 2 weeks, start the Car and run it with your foot on gas pedal at a fast idle, say 1200 - 1500 rpm until the Cooling Fan kicks in, thhen give it a rev or 2 so it hits the 4000rpm limiter to blow the exhaust out, switch off and leave it for another 2 weeks.
If it's a nice day with no salt on the roads drive it around the block instead !!
That is all I do with mine right now, until it is finished.
HTH,
oliverp likes this.
Dave
Dave2302 is offline
post #24 of 30 (permalink) Old 03-08-2019, 04:28 AM
Date registered: May 2011
Vehicle: 2005 S600
Quoted: 53 Post(s)
I like the "fire it up every two weeks" plan*.
Or the "slip the maintenance guy $20 so he ignores my extension cord once every two weeks" plan.
*Not the best for the engine, but allows battery charging, engine oil to circulate, hydraulics/airmatic to be pressurized, interior to get fresh air, trans fluid to circulate.
Dave2302 and oliverp like this.
Current Fleet:
2016 Tundra 1794
2005 MB S600 (100K, Michelin AS3+, M1 0W40)
2002 V70-XC (228K Castrol 0W40)
2002 V70-T5 (198K, Mobil 1 0W40)
1932 Packard Sedan (straight 8, dual sidemount spares, original paint and interior, Shell Rotella 15W40)
Astro14 is offline
post #25 of 30 (permalink) Old 03-08-2019, 04:52 AM
Dave2302's Avatar
Quoted: 696 Post(s)
Yeah, that's why I keep it at fast idle and get it right up to temperature, and blow the exhaust clear before switching off, I will also change the Oil and Filter once the Paintwork is finished and she is back on the road
Like I said, if it's a clear day, no salt around I have been taking it out with "Trade Plates" on for a 10 - 15 mile run to clear any moisture.
Dave
Dave2302 is offline
post #26 of 30 (permalink) Old 03-14-2019, 07:11 AM Thread Starter
Quoted: 44 Post(s)
Sorry to bring this up again
I was in WIS yesterday, reading about retrofitting illuminated door sills. In the instructions it says prior to disconnecting the battery, attach a device that maintains current. Does anyone know what device the dealer would use?
oliverp is offline
post #27 of 30 (permalink) Old 03-14-2019, 11:18 AM
Dave2302's Avatar
Quoted: 696 Post(s)
Hi Ollie,
I have no idea, probably the same idea as I do, a slave Battery of some kind. Don't quite understand what the advantage of that would be when doing a retro fit why bother disconnecting Battery anyways, just disconnect the circuit involved !!!!
Unless of course the Dealer Technicians are likely to short something out, (oh wait ) .................. In which case slave power is useless as well..........
Phut !! Bang!! Dead !!
And how long does it take to do the retro fit ...............
Couple of hours ??
Certainly not 3 weeks
There is no such thing as a free lunch, you are wasting your time looking for a cheap or easy short cut
The sensible answer is don't leave it more that a couple of weeks or use a Smart Battery Maintainer
HTH,
Dave
Dave2302 is offline
post #28 of 30 (permalink) Old 03-15-2019, 06:17 AM Thread Starter
Quoted: 44 Post(s)
Thanks as always Dave. I spoke to the janitor this morning and he's going to let me plug in again tomorrow for the day.
They have been building a new condo on our street for the past few months, so now that the snow's gone I have to deal with shitty cement water. AND they just started to build another two condos. So I think snow is now the least of my worries!
Dave2302 likes this.
oliverp is offline
post #29 of 30 (permalink) Old 03-15-2019, 07:08 AM
Vehicle: 2005 S600
Quoted: 53 Post(s)
So, it seems clear - your best investment is in a relationship with your janitor.
IF he lets you plug this in, you're all set.
Find out if he likes coffee...and bring him a fresh cup. Fresh baked goods are always appreciated...
You get the idea.
Current Fleet:
2016 Tundra 1794
Astro14 is offline
post #30 of 30 (permalink) Old 03-15-2019, 07:09 AM Thread Starter
Quoted: 44 Post(s)
Good idea. I will look after him, thanks!
oliverp is offline
battery drain on my c180 Alex berlein W203 C-Class 0 10-02-2016 07:07 AM
Replacing the battery, do I need to maintain a 12v supply whilst changing it? Taipan W169 A-Class 1 02-07-2015 11:11 PM
New Battery "Quirk"? akent99 C209/A209 CLK-Class 30 05-08-2014 01:07 PM
Has anyone replaced their main battery? cadillacbart W251 R-Class 31 12-25-2011 07:15 PM
NOKIA Battery Advisory (BL-5C) Check Codes Off-Topic 3 08-14-2007 10:49 PM
