S430 windshield wiper calibration - w220 - Page 2 - Mercedes-Benz Forum
post #11 of 17 (permalink) Old 04-22-2019, 04:02 PM
Date registered: Jan 2018
Vehicle: '04 S500 4Matic
Quoted: 44 Post(s)
How did you re-position the wiper arm? I have read in some posts that it's possible to force them down, but I was worried about doing this.
Thanks
Ollie
oliverp is offline
post #12 of 17 (permalink) Old 04-22-2019, 11:37 PM Thread Starter
Martin Beld's Avatar
Date registered: Feb 2019
Originally Posted by oliverp View Post
<img src="https://www.benzworld.org/forums/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> <img src="https://www.benzworld.org/forums/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
Thanks
Ollie
Bert easy to change motor. Just a fee screws. The shield stuck to the window was the trickiest part. - Just pull up delicatelly. Repositioning: first place the motor and attach the wipersarms - then reposition before You screw Them down.
Martin Beld is offline
post #13 of 17 (permalink) Old 04-23-2019, 04:46 AM
Date registered: May 2011
Vehicle: 2005 S600
Quoted: 53 Post(s)
That's good to know Martin. I had been avoiding the job for both the expense of a new motor* and because it looked like a PITA.
Now, it's just the expense holding me back. My wipers occasionally stop just above park when switched off. It's a little annoying, and I have to clear the (f) every time a scan the car.
*About $215 on MBOEMParts.com.
Current Fleet:
2016 Tundra 1794
2005 MB S600 (100K, Michelin AS3+, M1 0W40)
2002 V70-XC (228K Castrol 0W40)
2002 V70-T5 (198K, Mobil 1 0W40)
1932 Packard Sedan (straight 8, dual sidemount spares, original paint and interior, Shell Rotella 15W40)
Astro14 is offline
post #14 of 17 (permalink) Old 04-23-2019, 10:01 AM
doni01's Avatar
Date registered: Jun 2012
Vehicle: S500 4Matic 2005
Quoted: 105 Post(s)
Thanks
Ollie
No you do NOT force them down!! You remove them completely and then re install them few clicks down. Just make sure you get a wiper removal tool since sometimes they are stuck and can't be removed by hand.
Dave2302 likes this.
doni01 is offline
post #15 of 17 (permalink) Old 04-23-2019, 10:14 AM
Date registered: Dec 2012
Vehicle: 2003 S430
Quoted: 373 Post(s)
You can adjust the arms. If you look closely at the windshield near the end of the passenger wiper blade park position, you will find a small line in the windscreen. This shows the desired parked position for the blade.
500sec_dave and Dave2302 like this.
Wally
wallyp is offline
post #16 of 17 (permalink) Old 04-30-2019, 04:03 AM
Date registered: Oct 2011
Vehicle: S500 2000 (W220)
Quoted: 23 Post(s)
I believe in most cases, these sorts of problems can be resolved by cleaning & lubricating the "ring contact" in the wiper motor. Some have also suggested moving the "ring contact" so that a non-worn part of the metal/copper is exposed. I believe this contact point is how the wipers know the correct position to "park" the wipers when they are switched off.
Obviously replacing the wiper motor will also fix the issue, but the above DIY is a much cheaper thing to try first. It's something we need to do on mine, as the wiper 9 times out of 10 don't park correctly now (and run once when the car is next switched on as a result). I'm also wondering if it will resolve issues with why my wiper don't sense rain properly on setting I, as the rain sensor is believed to be good.
chapzboy is offline
post #17 of 17 (permalink) Old 04-30-2019, 11:51 PM
Date registered: Apr 2008
Vehicle: W219 320CDI -07 W220 320CDI -01 W210 270CDI -01 EX: W211 320CDI -04
Quoted: 109 Post(s)
I would try this first... I never opend wiper motor myself but my neighbour has same age W163 and he stated that repairing ring contact by bending contact clips to get more contact force and cleaning surfaces cured issue in his car. W220 wiper has very likely similar structure.
-Do not try this at home -
mersum1es is offline
Windshield Wiper Issues Ishii-kun W123 E,CE,D,CD,TD,TE Class 1 05-12-2013 08:15 PM
How to install the new '08 G windshield wiper arm covers? aknutsen G-Class 1 04-12-2010 03:06 PM
wiper blade scratching up the windshield..?? ProV1x W210 E-Class 6 10-15-2007 03:23 PM
windshield wiper motor hchau5 W124 E,CE,D,TD Class 3 09-06-2007 08:12 AM
Windshield wiper arm design fgwinn R171 SLK-Class 13 09-21-2004 06:00 PM
