SLK 320 to SLK 500 Daves Project - Page 2 - Mercedes-Benz Forum
post #11 of 203 (permalink) Old 12-03-2018, 12:09 AM Thread Starter
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 720 Post(s)
Hi @Deplore ,
...........Have you ever driven a V6 SLK R170, it's just over 1600kg, it's bloody dangerously quick as is lol
Besides which, I have an M113 55K motor to go in my W220 eventually, so I will then have two 5.0 M113's spare
Transmission wise, yes I know the V6 is weaker than the V8, what I will probably do is leave the V6 one in the Car for initial testing, with it's own TCU and Diff.
SLK320 runs a 3.27 if my sources are correct, my SDS screen Photos seem to confirm that. I reckon the V8 Diff would be needed on a Road Car.
Once the Car is tested out and no issues I will then swap in the V8 Box and Converter after a freshen up, plus the V8 TCU and the V8 Diff, hopefully the V8 TCU Plug is the same as the V6, I will check that out soon
OK, on to your initial reply about the Immo Virginise I have some questions .......................
1) I take it as I don't do Eepromming that means getting my Eeprommer man to Virgin that little 8 legged chip in my pictures ??
2) Is this Chip where SDS reads the VIN from ??
3) Do I then need to have a "Green" Key to perform the marriage on SDS ??
4) Do I need unlocked SDS ??
5) Would simply swapping the 8 legged Chips not do the same thing ??
6) The V6 Car is DAS 2 (Blade Key) and the V8 is DAS 3 IR Key, is that still good to go ??
Thanks in Advance, Dave
Dave2302 is offline
post #12 of 203 (permalink) Old 12-03-2018, 01:49 AM
SDS Guru
Deplore's Avatar
Date registered: Apr 2014
Vehicle: 1998 MB E300TD, 1997 MB E320
Quoted: 763 Post(s)
Hi @Deplore
Quote:-
Actually, I have. And while yes, the car is quick....you know what makes it even better? MOOOOOORE POWAAAAAH!
LOL, what is it "There ain't no substitute for Cubic Inches"
1. Correct. Got it
2. Yes it does. Got it
3. No, green key is only for EIS. Got it
4. No. Any plain jane SDS will do it. Great, my old one asks for passwords sometimes, my new one is unlocked allegedly but yet to try it in anger.
5. Technically yes, but then you won't have an original V6 ECU that will start the car. Also, this chip holds the SCN coding as well, so it might be easier to have the M113 SCN code present in the M113 ECU. Having M112 SCN code in M113 will work, but weird things might happen? Never tried it. OK, can I alter that SCN ? isn't that just Version Coding on something this age? with Offline SDS ? If so I will try soldering the Drivers onto V6 ECU from that spare V8 unit I have as I'm comfortable with that, but not so comfortable with soldering 8 legged Chip
6. Yes, no problems. I can interchange the ECU from 1997 and 1998-2000 W210 here.... 97 is DAS2 with blade key, 98 went electronic key. Still works. Got it
Incidentally, M112 ECU in a M104 car will start it and it will run.....though I very highly recommend you do not do that. The firing order is out of order, and you get constant backfires.
Scared the crap out of me, lol. .........................
Cheers Dave
--1998 MB E300TD 291k
--1997 MB E36 Frankenstein'd AMG 199k
--2011 Suzuki DL650 58k
--1997 MB E320 161k. SOLD...loved that stupid car.
--1997 MB C36 AMG 273k -- stripped and junked
Deplore is offline
post #13 of 203 (permalink) Old 12-03-2018, 08:59 AM Thread Starter
Dave2302's Avatar
Quoted: 720 Post(s)
Hi Guys,
The last unknown quantity will work ................
A quick bit of info, I have verified that the V6 R170 and the V8 C215 / W220 TCU's are both EGS52, so they have the same identical Wiring Plugs, so that opens up various Transmission combinations for the project
I could use a v8 Trans built with a V6 Gearset ratio, and V6 Diff, and stock V6 TCU =humongous acceleration but will be thirsty for fuel at motorway speeds
or
I could use V8 Trans stock, V8 Diff and stock V8 TCU = probably the best set up, car weighs 1660 KG so significantly quicker than W220 but will have sensible Fuel Consumption
or use a combination of bits, aka "Franken Transmission" and find out how to set what number to what number for the SCN Code probably too much messin' for me.
I'll drive it on V6 Diff / Trans / TCU and if it is waaaaaay too wild and thirsty I will tame it a bit with a V8 W220 Diff / Trans / TCU.
I will check the p/n of Gearsets and number of Clutches in each pack between V6 and V8 Trannys next, as I simply do not know for certain if they are actually any different !!
Maybe @MAVA can chip in here
Cheers for now,
Dave
Dave2302 is offline
post #14 of 203 (permalink) Old 12-03-2018, 10:26 PM
Date registered: Jun 2018
Vehicle: 2005 SL65 plus 13 other non MB toys
Quoted: 84 Post(s)
Actually the saying is "There's no replacement for displacement!"
Triple cranks is offline
post #15 of 203 (permalink) Old 12-04-2018, 05:05 AM Thread Starter
Dave2302's Avatar
Quoted: 720 Post(s)
I already bought a private plate for it in the same series as my S class one ...................
S for SLK, 50 for 5.0 litre and Dave !!
ID:	2470508   Click image for larger version
ID:	2470510   Click image for larger version
ID:	2470512   Click image for larger version
Deplore and cowboyt like this.
Dave2302 is offline
post #16 of 203 (permalink) Old 12-04-2018, 05:17 AM
Date registered: May 2016
Vehicle: 2000 S430, 2003 S430, 2003 S600 TT, and 2005 E320 CDI
Quoted: 962 Post(s)
^^ I've seen both versions, and in either incarnation, the statement is true. :-) The S430 is great, no question. Drove the project S500 to work yesterday, yeah, the difference is there.
@Dave2302 , that looks like a sweet car. With that engine, I can imagine the cops' reaction.
Cop 1: That's Dave, he's speeding, pull him over!
(blink their eyes)
Cop 2: Man......DAVE'S NOT HERE!!
Dave2302 and Deplore like this.
2000 S430 (Dad's car, used for special occasions)
2000 S500 (wife's DD: my first W220 project car)
2003 S600 ("sex on wheels"--second w220 project car)
2003 S430 (one of two current DD's--third W220 project car)
2005 E320 CDI (the other current DD--first W211 project car)
cowboyt is offline
post #17 of 203 (permalink) Old 12-04-2018, 05:24 AM Thread Starter
Dave2302's Avatar
Quoted: 720 Post(s)
LOL, It is a legal requirement in UK to have a post code on the bottom of Reg Plates so officials can tell who made the plates !! ......................
Can you see the (non existant) "post code" next to the MB writing on the footer, it is SL50 2FU
I don't read anywhere in said stoopid law that it has to actually be a real post code
cowboyt and Smackrattle like this.
Dave2302 is offline
post #18 of 203 (permalink) Old 12-04-2018, 06:44 AM
Date registered: Dec 2012
Vehicle: 2003 S430
Quoted: 377 Post(s)
I don't believe that there is a single state of the fifty that will let you manufacture your own plates, and each state has its own graphics design and letter/number pattern. All are the standard size, though:
"Designs for use in the United States, Canada and Mexico must fit into an 11.44 x 5.44 inch rectangle, with radius corners sized to match the debossing rim in the blanking press."
Georgia recently went from an embossed (raised letters and numbers) aluminum plate with Scotchlite (reflective) background and very fancy semi-hidden holograms in the background to a cheap flat printed non-reflective piece of junk.
Wally
wallyp is offline
post #19 of 203 (permalink) Old 12-04-2018, 07:16 AM Thread Starter
Dave2302's Avatar
Quoted: 720 Post(s)
The loophole over here is that you can get mail order for the Illegal ones, note that the way mine is done is almost 100% legal, except that the U is slightly narrowed to make it look a little more like a V
Of course way back, when I bought S55 if I could have got DAV I would have, but that series has been allocated long ago and fetch silly money
I bought the number on retention yesterday, ordered the plates from mr "X" and they turned up today
Dave2302 is offline
post #20 of 203 (permalink) Old 12-04-2018, 07:47 AM
MAVA's Avatar
Vehicle: 93 SL500, 95 SL320, 96 S320, 98 S500, 2002 E320 4Matic Wagon & A little 91 5.0 FORD Mustang
Location: Sacramento, California & El Dorado Hills, California, USA
Quoted: 1233 Post(s)
Originally Posted by Dave2302 View Post
Hi Guys,
or
Cheers for now,
Dave
Dave,
Off the gate, V6 tranny has three pinion transmission output shaft, and the V8's/V12's have four pinion transmission output shaft, so that will not work.
Also, the differential for that specific model must go with that engine, but I guess you could always change the reluctor rings on the half shafts where the car gets it speed feedback, but then the speedo/odometer have timing issues too...
Try the tranny and differential first...
The TCMs have different CAN bus versions, so stay with the generation of the same years as the vehicle. If you get a AMG tranny, get the AMG TCU, or you may get some really hard shifts at low Km/hr (bumper to bumper traffic). They may feel like you are getting hit from the rear on every shift. No mixing.
Martin
MAVA is offline
