ABS reluctor ring location - Page 2 - Mercedes-Benz Forum
post #11 of 18 (permalink) Old 11-13-2018, 07:05 PM Thread Starter
STRGLZ's Avatar
Date registered: Oct 2018
Vehicle: 2003 S430 4Matic
Quoted: 12 Post(s)
Thanks guys but I don't plan on replacing the whole axle because it obviously doesn't need it, and if I can replace the reluctor ring then I don't see how replacing the whole assembly would be a good idea. I think I found the part number, it looks like it is 210-357-00-82. They have it on mboemparts but no pictures included. For that price (around 7$), I cannot complain !
https://www.mboemparts.com/oem-parts...IFJlc3VsdHM%3D
STRGLZ is offline
post #12 of 18 (permalink) Old 11-13-2018, 08:38 PM
pinkster's Avatar
Date registered: Jul 2013
Vehicle: 2002 S430
Quoted: 381 Post(s)
The part you have above is the ring for the rear axle of your car. I would check that they are the same size before ordering it.
For reference rear axle ring is A210 357 00 82.
Front axle no part number listed in the EPC.
For RWD rear same as above A210 357 00 82.
Front axle A022 997 97 47.
Dave2302 likes this.
Dean
GMT +10
2002 W220 S430
2003 Toyota Rav4
2017 Yamaha Stryker
pinkster is offline
post #13 of 18 (permalink) Old 11-14-2018, 12:17 AM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 698 Post(s)
Thanks Dean,
Yeah, I should have stated that was a rear listing and just posted as an example, don't have hardly any spare time right now, but I'm sure one of those companies can supply the correct one, then again i wouldn't expect the MB one to be expensive
Post edited
Dave2302 is offline
post #14 of 18 (permalink) Old 11-14-2018, 11:37 AM
Date registered: Jan 2018
Vehicle: '04 S500 4Matic
Quoted: 44 Post(s)
I have a 2004 S500 4Matic in Toronto. My front left reluctor ring broke a few weeks ago. The indie was not able to source just the ring so we ended up with a genuine remanufactured axle.
I am not sure how hard they are to get hold of.
Thanks
Oliver
oliverp is offline
post #15 of 18 (permalink) Old 11-14-2018, 01:29 PM Thread Starter
STRGLZ's Avatar
Quoted: 12 Post(s)
Thanks
Oliver
How much did it cost you overall ?
I think I'll give a call to the stealership, just to see. In the worst case I could build my own ring, it's basically just metal, right ?
STRGLZ is offline
post #16 of 18 (permalink) Old 11-14-2018, 03:48 PM
Quoted: 44 Post(s)
From memory it was $1200 for the axle and then $500 for labor. They said the dealer quoted them $2000 for the axle.
I think my ring was bent - there were no teeth missing. As Dave mentioned in my thread, it could probably have been straightened. The CV joint was badly leaking and the boot was shot on the old axle, so it turned out OK in the end.
I am probably imagining it to try and justify the cost, but it seems to ride a little better at the front now. Maybe a bit smoother.. but probably not
oliverp is offline
post #17 of 18 (permalink) Old 11-14-2018, 04:24 PM Thread Starter
STRGLZ's Avatar
Quoted: 12 Post(s)
That's a lot of money in my case, this is why I wanna be sure that I don't need to change the whole axle 😅 In your case it seems it was necessary.
STRGLZ is offline
post #18 of 18 (permalink) Old 11-14-2018, 05:13 PM
Quoted: 44 Post(s)
Yes I was pretty surprised how much it cost but I don't think I had a choice. I really trust the mechanic and have a good relationship with him.
oliverp is offline
