Plz Read Post 1!! Laptop & Desktop Technical Thread, NO POSTS ABOUT CAR PROBS ! - Page 2 - Mercedes-Benz Forum
post #11 of 79 (permalink) Old 03-13-2018, 05:18 AM
salman108's Avatar
Date registered: Mar 2011
Vehicle: Mercedes S500 - W140 && S500 W220.
Quoted: 76 Post(s)
Originally Posted by W220_N00b View Post
Has anyone tried a decent USB to RS232. I have one I use to help me configure legacy switches (usually Cisco). My assumption is that the software is looking for a COM port as that is how 90% of most applications work that require serial connection to an endpoint. I do know there are some applications out there that don't utilize the OS environment as part of the OSI pathway and use a proprietary app embedded in their own software which may work with only very specific chipsets. I was just curious if possibly the SDS fell into that later.
I tried that.
COM port emulation does not work
some IBM laptops have had it going, but these are rare.
It is a pain to have connection loss during coding.
Dave2302 likes this.
Proudly cruising in W-140, 1998 S-500
salman108 is offline
post #12 of 79 (permalink) Old 03-13-2018, 05:41 AM Thread Starter
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 712 Post(s)
Originally Posted by salman108 View Post
I tried that.
Hi,
Couldn't agree more, it is also an even bigger pain if you are flashing a Software update and connection drops out, that is just as likely to brick the controller concerned
I don't see what the problem is with buying a cheap Dell and using RS232, as it was intended by the Chinese Software Programmers
At the end of the day you would be ill advised to put SDS Clone on a Lappy or Tablet that you use every day, it is so full of Viruses etc.
Much better to keep it as a stand alone IMHO .............
Hell, in my Workshop I have a separate Dell for MB Star, VW/Audi Group VAG COM & ELSAWin, JLR, Delphi Generic, and soon BMW ICOM (when I get around to the Install)
Each one is stand alone, and they all work flawlessly
Much better IMHO
Cheers Dave
Dave2302 is offline
post #13 of 79 (permalink) Old 03-13-2018, 07:19 AM
Date registered: Feb 2018
Vehicle: 2003 S500
Quoted: 11 Post(s)
I tried that.
When I get my SDS I will play with it. I have a few laptops laying around, including a D630 already. As I am curious. That is the same issue you would have with trying to console into Cisco switches without using a specific usb bridge to serial chipset. As I like to play with this kind of stuff to find out, I will do a follow-up report when I have time to tinker.
Tiger_one likes this.
W220_N00b is offline
post #14 of 79 (permalink) Old 03-13-2018, 10:19 AM Thread Starter
Dave2302's Avatar
Quoted: 712 Post(s)
Hi again,
Well I fixed the Java 8 / mosaic.jar issue
Uninstalled Java 8 and replaced it with an archive version of jre6 ...........
It's all working with one tiny bug, see first pic ...........
Each time I start "Tickertape" something, (Internet Explorer I think), is prompting me to update the Java, which of course I don't want to do DOH !!
If I click "run this time" then it all works fine, and the Update bar disappears for that "gig"
Not too big a deal I know, but it annoys the hell outta me and I want to get it right, anyone got any Ideas ?????
The other pics show it all working fine, and in between each Cartoon Pic, it puts up my "Karaoke" logo.
I suppose I could try Uninstalling Internet Explorer and re Installing an earlier version, these Laptops have never been on the Internet except for downloading Drivers, Java etc upon initial setting up, but it would be useful to be able run them on Internet now and then for updating Music Files / Karaoke CDG's...............
I'm thinking that an earlier version might give me more grief ??????
Any ideas how to get rid of that prompt would be well received
Cheers Dave
Pix:-
ID:	2395258   Click image for larger version
ID:	2395266   Click image for larger version
ID:	2395274   Click image for larger version
ID:	2395282   Click image for larger version
ID:	2395298   Click image for larger version
Dave2302 is offline
post #15 of 79 (permalink) Old 03-13-2018, 12:09 PM
Vehicle: 2003 S500
Quoted: 11 Post(s)
How do you load the jar file? Anything after jre 7 requires high to very high security and you cannot change that. However you can add an exception under security. Just click "Site Exemption List". You can either use URL or FILE syntax.
URL = http://prefix.hostname.suffix (i.e. http://localhost/file.jar)
FILE = file:///<drive_letter>:/<directory>/<file>.jar (i.e. file:///C:/temp/file.jar
You would have to add an exemption per file or just use the pathway with no ending "/" and that should allow any jar file to run under that directory.
post #16 of 79 (permalink) Old 03-13-2018, 12:55 PM
Date registered: Mar 2015
Vehicle: 2006 S500 4matic, 2005 S500
Quoted: 75 Post(s)
Thought to post up my situation. A few days ago received a C4 system for use with a Dell 630. SD Connect version DEC 2017.
Inserted the SSD drive with pre-loaded software into the D630, and the system will not complete a load of the pre-installed windows software. Tried numerous "fixes", and no go. Fixes included letting windows try to fix itself to going to a command prompt and running chdsk.
Not sure how to address with a chinese ali-baba vendor. Looking at buying another pre-loaded hard drive .
Here are two screen shots
ID:	2395370   Click image for larger version
MikeKerr is offline
post #17 of 79 (permalink) Old 03-13-2018, 01:21 PM
Quoted: 75 Post(s)
Here is the follow up to get the drive to load the Windows 7 OS from the SSD. After working numerous fixes for 24 hours, was about to give up. I remembered a setting in the bios that said: SATA is configured for ATA- which is the default setting. I switched it to SATA for AHCI, and low and behold the OS loaded...
Here is a pic of the bios change from the Dell D630:
MikeKerr is offline
post #18 of 79 (permalink) Old 03-13-2018, 01:28 PM
Vehicle: 2003 S500
Quoted: 11 Post(s)
I was going to write a reply to that exact troubleshooting step. As that is a common issue especially when changing spinners to solid state. Glad you got it resolves, let us know how the C4 treats you.
post #19 of 79 (permalink) Old 03-13-2018, 04:06 PM
Date registered: Dec 2012
Vehicle: 2003 S430
Quoted: 377 Post(s)
Glad that you got it going so far, Mike. It will be interesting to see how things go with Windows 7 and more memory.
I am building a D830 to replace one of the D630 systems. I cloned the SDS conventional hard drive to a SSD the same size and installed it in the D830. The system starts and runs with no problems, until I try to actually use DAS. At that point, it tells me that I have no DAS authorization key. Not really a surprise, since the key is tied to the LAN ID, which is obviously different on the D830.
I tried to install a new key, with no luck. The hardware ID and LAN ID are both different, and I didn't find an intuitive way to change the numbers on the cloned drive.
After a couple of hours messing with it, I decided that the best approach was a clean install. After 2 1/2 hours of intermittent attention, I am 43% of the way thru loading the 14-DVD distribution...
Wally
wallyp is online now
post #20 of 79 (permalink) Old 03-13-2018, 09:21 PM
Vehicle: 2003 S430
Quoted: 377 Post(s)
Got system reloaded, and was reminded of one of the small "gotcha!" items with loading key authorizations - there is a space for the expiration date for the new key. That date has to be later than today - DOH! I set the expiration for 1-1-2030 - I doubt if I will be using the system when I am 89 years old...
Got the system to accept the key for DAS, but not for Xentry nor for WIS.
Wally
