Old W140 guy with a new W220 - Page 2 - Mercedes-Benz Forum
post #11 of 18 (permalink) Old 01-13-2018, 04:06 AM
Date registered: May 2009
Vehicle: 2006 S600
Quoted: 30 Post(s)
Originally Posted by MercedesMikeNAtlanta View Post
I pressurized the system again, but nothing happened. Now the pump is making a strange sound. That's why I'm going to rebuild the pump and try again.
Converting to regular shocks/struts is my last resort. I'd like to keep the car original.
Rebuilding the pump is properly difficult, and not that cheap either. One of the best options IMHO is to buy a reconditioned tandem pump from Rock Auto. I always encourage people to keep their ABC going. It's not an easy system to look after, but it's cheaper than a conversion, and you get the advantage of active suspension!
I second the suggestion to get SDS. What people usually get is a Chinese clone; the real ones are very expensive. Installing on the Dell laptop is a faff. If you can find someone who's done the work and is selling a little-used system, that would be a good option.
I think it's also worth getting WIS and EPC on a DVD from ebay or amazon so have cheap, quick and easy access to all the documentation on your PC.
Nick
Dave2302 and cowboyt like this.
welwynnick is offline
post #12 of 18 (permalink) Old 01-13-2018, 04:20 AM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 762 Post(s)
Hi,
/\ /\ /\ +1 to all of that
I have rebuilt lots of different pumps............
To elaborate on what Nick says, the problem is that the "Hard Parts" Seize and you cannot buy spares off the shelf, yeah, seals etc are readily available from a Hydraulics Supplier, but that isn't the problem, the re conditioners actually strip loads of used Pumps and use the Metal Hard Parts to make up a good unit.
They may get commonly busted up parts manufactured, they also will Machine damaged Castings and fit oversized newly manufactured parts, which they buy in batches..............
Not something the average DIY Guy has access to
If you do manage to find someone who supplies Parts, please let me know, I have 3 u/s Pump Core Units here.
Assuming it was profitable, I would rebuild them and put them into stock, for the next Vehicle with a broken pump
Re the SDS, that's exactly how I bought my first Kit, an owner had sold his MB and had no further use for it, I bought it plug and play
Cheers Dave
cowboyt likes this.
Dave2302 is offline
post #13 of 18 (permalink) Old 01-13-2018, 07:57 AM
Date registered: Dec 2012
Vehicle: 2003 S430
Quoted: 386 Post(s)
"...I bought it plug and play"
It's really too bad that you can't buy the experience in using it at the same time...
wallyp is online now
post #14 of 18 (permalink) Old 01-15-2018, 02:05 PM Thread Starter
Date registered: Jul 2007
Vehicle: 2002 CL500, 2001 S500, 1997 S500, 1999 S320, 2005 ML500, 2005 CLK320, 2009 BMW 535xi, & 1975 Midget
Quoted: 28 Post(s)
Thanks for the help. The parts to rebuild the pump should arrive on Wednesday. I'm trying to get it back in the car by the weekend. I'll keep everyone posted on the progress and if I need to get a "professionaly" rebuilt tandum pump.
mercy-me and Dave2302 like this.
MercedesMikeNAtlanta is offline
post #15 of 18 (permalink) Old 01-15-2018, 02:51 PM
mercy-me's Avatar
Date registered: Apr 2012
Vehicle: 2003 SL500, 2012 E350 4Matic P2
Quoted: 64 Post(s)
.................and snap a few pictures along the way to share!
Thanks and good luck!
Bob
mercy-me is offline
post #16 of 18 (permalink) Old 01-16-2018, 09:08 AM
Dave2302's Avatar
Quoted: 762 Post(s)
Hi,
Hmmmm, I'm interested to see how this pans out, there's an awful lot of bits inside these pumps that get melted when they run dry, pic below, sorry about the quality, it's the only one I've got atm
Where did you get the rebuild kit, any chance of a pic of what parts it contains please ??
Cheers Dave
Dave2302 is offline
post #17 of 18 (permalink) Old 01-16-2018, 10:24 AM
Date registered: May 2016
Vehicle: 2000 S430, 2003 S430, 2003 S600 TT, and 2005 E320 CDI
Quoted: 995 Post(s)
I thought about a rebuild, too. Turns out my "professionally reman'd" tandem pump has a small leak, and given the labour required to replace that pump, I'd like to do it only once. My guess is that whoever did the rebuild probably put good metal parts in, but they didn't do the seals right. The kit with the seals is somewhere around US $90.
The major issue I face with this is that I don't have the tool to pull off the pulley-holder wheel from the shaft. It looks like it's a very tight press-fit. I tried the one I got from the local auto parts store, and that's just not strong enough. If I can get that pulley wheel off, then I think replacing the seals on this pump is doable.
Anybody got a suggestion for how to get that wheel off, and then back on, without damaging things?
cowboyt is offline
post #18 of 18 (permalink) Old 01-16-2018, 10:46 AM
Vehicle: 2003 S430
Quoted: 386 Post(s)
I haven't been able to get the pulley off of a standard (single, non-ABC) pump off...
