06 S65 Spurious Gearbox drop out of gear issues - Page 7 - Mercedes-Benz Forum
post #61 of 71 (permalink) Old 01-02-2018, 12:01 PM
Date registered: Dec 2004
Vehicle: 1972 280CE
Quoted: 152 Post(s)
Nice, when did you get a lift??? It's not much warmer in my steel building.
If you've removed the valve body before to replace the conductor plate, I suspect that you've already pulled the solenoids when doing this. There should be four on one side and two on the other, underneath a cover.
There's a guy on youtube called Diesel Mercedes that has some great videos:
Also look up sonax kits which you can probably do at the same time and does not cost a lot : https://www.sonnax.com/parts/2317-ma...lve-sleeve-kit
Dave2302 likes this.
With best regards
Al
Check out the W114, W115 /8 enthusiast forum
alabbasi is offline
post #62 of 71 (permalink) Old 01-03-2018, 09:32 AM Thread Starter
Date registered: Mar 2007
Vehicle: 2004 S55 & 2006 S65
Quoted: 29 Post(s)
Thanks Al much appreciated. I have had the lift for a few years now - sort of necessary with my hobby.
Looking back to when I changed out the conductor plate I may have screwed something up. I tried to keep everything really clean but maybe I introduced some crap into the valve body.
With it being very cold and the car not engaging D or R until the fluid warms up and even then it thumps into gear. Once she is rolling not more issues.
Thanks for the links - very interesting and certainly worth a try. Solenoids are about $50 each- is it worth changing them all? Can they be tested?
Any advice on cleaning/flushing the valve body?
Thanks Roger
ROG100 is offline
post #63 of 71 (permalink) Old 01-03-2018, 06:29 PM
Vehicle: 1972 280CE
Quoted: 152 Post(s)
Roger,
I believe that the kid that works for me used brake clean on his when he put a 722.6 in a diesel 124 wagon. Before ordering new solenoids, you might want to check part #'s. The 722.6 went into many engines from a C230 with a 1.8l 4 cylinder to the twin turbo v12 in the S65, they may not all be equal. Also check your Email, I might have a last ditch solution for you in case all others fail.
With best regards
Al
alabbasi is offline
post #64 of 71 (permalink) Old 01-04-2018, 12:20 AM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 720 Post(s)
Hi,
Over here in UK, decent Auto Trans Shops have what is called a "Hydra Test" Machine, which a Valve Block assembly is bolted into a Machine and tested Electronically and Hydraulically
I know the USA makes it's own Machine, can't remember the brand name of it now ........ "Hydra Test" is a UK Brand, built and sold by a friend of mine, which deals more specifically with the Brands of Auto Transmissions in UK
Would it not be far more cost effective to find a decent Trans Shop with such a machine, perhaps phone round some MB Indies to get a recommendation, and pay them a few bucks to check and repair your Valve Block if necessary ??
Just a thought, because back in my Transmission building days if I ever had a suspected Valve Block problem I would always bung it on the Hydra Test Machine
However, in my experience, unless I was getting a bad Solenoid Code, the Valve Blocks themselves were very rarely at fault
HTH,
Cheers Dave
Dave2302 is offline
post #65 of 71 (permalink) Old 02-08-2019, 08:48 AM
Premium Member
Date registered: Feb 2019
Vehicle: 2004 S500 & 2006 E350
Premium Member
Roger,
Good morning. Wanted to find out if you found what's wrong with your car. I have 04 S500 with very similar problems. Please let us know. Thank you
Paaw7541 is offline
post #66 of 71 (permalink) Old 02-09-2019, 08:19 AM Thread Starter
Quoted: 29 Post(s)
Hi Paaw7541 - well I did everything I could bar have the gearbox rebuilt. Correctly flushing the system solved most of the issue but alas it was still there but less frequent.
I was at the point of having the gearbox rebuilt when I blew the engine (another thread). About a year later I am in the process of replacing the engine and gearbox.
So if you have fully flushed the system, changed the round connector and conductor plate, rebuild is on the cards.
Good luck.
ROG100 is offline
post #67 of 71 (permalink) Old 02-12-2019, 03:05 PM
Premium Member
Premium Member
Thank you Roger for letting us know. Wojtek
Paaw7541 is offline
post #68 of 71 (permalink) Old 05-26-2019, 04:50 AM
Herman K's Avatar
Date registered: Jul 2011
Vehicle: 2006 S55 AMG - 2007 SL55 AMG P030 -2007 S65 AMG
Quoted: 23 Post(s)
Like wise issue solved on 08 SL65
Originally Posted by ROG100 View Post
2006 S65 Gearbox 722.6
Gearbox will drop out of gear or hold a particular gear every now and then. No rhyme or reason.
Drove 800 miles to FL and it did it twice. Slow down or stop and it comes back. Worst is when the gear is not engaged and the engine just revs until you realize it is out of gear.
800 mile return trip never missed a beat. This was hard driving.
Short run to the local shop and it does it again. Then nothing for a couple of weeks.
About 12 months ago I replaced the conductor plate when the screw holding the connector sheared. Box was clean and fluid replaced. Correct MB connector, conductor plate and fluid. Same for the gasket and filter.
I just pulled the TCU to check for fluid wick contamination and all clean.
I plan to drain and pull the pan as well as check the connector again. I have another conductor plate ready as well.
Any pearls of wisdom from the W220 tifosi?
I have gone through the same issues and I'm posting my resolve in the R230 thread under
08 SL65 Spurious Gearbox drop out of gear issues [Solved] intro
https://www.benzworld.org/forums/r23...l#post17797008
For those off you that have contributed to this issue here and like to find out more I'm posted the link here.
Thanks for all your time spend
Herman K is offline
post #69 of 71 (permalink) Old 05-28-2019, 05:07 PM
Date registered: May 2019
Anyone have a shifter wiring diagram 2000 s430... Mine pulls no communication codes and was woundering the symptoms of bad shifter module
post #70 of 71 (permalink) Old 05-28-2019, 05:09 PM
Do u know the location of antitheft module. 2000 s430 mercedes
