Put a scanner on the $600 s430 and oh boy the codes - Page 3 - Mercedes-Benz Forum
post #21 of 35 (permalink) Old 08-09-2017, 06:41 AM Thread Starter
Date registered: Jul 2017
Vehicle: 2000 W220
Last time we checked there was no voltage at the relay but I will check again.
I know the compressor fires up because when i replaced it and it still didn't lift i took the old compressor and a battery charger as a power supply and it fired right up.
So last night i put that compressor back in the car. I then connected everything but the power harness to the compressor and i used some connectors to power the compressor directly off another battery with the ignition on.
The compressor fired up and after about a minute it sounded like it was fighting against pressure so i disconnected it because i didn't want to burn it up or blow one of the lines(nylon?).
The car didn't raise at all doing this.
If there is a valve between the compressor and the tank in the block and it isn't opening that would explain what I think I heard.
I will try to check the ground as soon as I can but the car is about an hour away at a friends house.
lothar863 is offline
post #22 of 35 (permalink) Old 08-09-2017, 08:08 AM
pinkster's Avatar
Date registered: Jul 2013
Vehicle: 2002 S430
Quoted: 381 Post(s)
Wiring diagram and legend for you to check. It has all the fuses and ground points in the legend.
File Type: pdf Wiring diagram of AIRmatic control unit l.pdf (93.3 KB, 50 views)
File Type: pdf Wiring diagram of AIRmatic control unit.pdf (111.1 KB, 40 views)
Dave2302 likes this.
Dean
GMT +10
2002 W220 S430
2003 Toyota Rav4
2017 Yamaha Stryker
pinkster is offline
post #23 of 35 (permalink) Old 08-09-2017, 08:15 AM
pinkster's Avatar
Vehicle: 2002 S430
Quoted: 381 Post(s)
Here is the block diagram as well.
Dean
GMT +10
2002 W220 S430
2003 Toyota Rav4
2017 Yamaha Stryker
pinkster is offline
post #24 of 35 (permalink) Old 08-11-2017, 09:28 PM Thread Starter
Vehicle: 2000 W220
crap caught on fire
replaced and it lifted
still have no audio from the amp. i am guessing an error in the D2B chain.
But next big issue is there are no tail, brake, or rear turn signals. And have a BAS and ESP light.
Tried the lock to lock but still have the lights.
I am thinking maybe the brake switch I have read about but I dont think that would cause turn signal or tail light issues.
post #25 of 35 (permalink) Old 08-12-2017, 01:46 AM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 675 Post(s)
Hi,
[email protected]@k me, that must have been some "red wire touched the case" to melt that ally like that
It sounds to me like there is other fried stuff in the aftermath of this
SDS will be the quickest and easiest way to sort out what is what
Cheers Dave
Dave2302 is offline
post #26 of 35 (permalink) Old 08-12-2017, 01:52 AM
Date registered: Feb 2008
Vehicle: Too many to list
Quoted: 1484 Post(s)
What part is that caught on fire
tusabes is online now
post #27 of 35 (permalink) Old 08-12-2017, 02:11 AM
Date registered: Mar 2016
Vehicle: 2005 Mercedes-Benz S600
Quoted: 4 Post(s)
@tusabes , the bottom left part of the board looks charred, though a bit hard to see at first sight.
prs600 is offline
post #28 of 35 (permalink) Old 08-12-2017, 07:15 PM
Right , I'm asking what board /part is that ?
post #29 of 35 (permalink) Old 08-13-2017, 12:31 AM
Quoted: 4 Post(s)
Not sure but looks like the airmatic control unit.
Sent from my A0001 using Tapatalk
prs600 is offline
post #30 of 35 (permalink) Old 08-13-2017, 06:45 AM Thread Starter
Vehicle: 2000 W220
yes it is the airmatic.
here is a closer shot
