S500 Resurrection, Dave's Thread - Page 49 - Mercedes-Benz Forum
LinkBack Thread Tools
Old 05-12-2019, 11:38 PM Thread Starter
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 729 Post(s)
Hi,
Yes that is the reason I do all my Wheels Satin Black on the Back side.
I knew I'd find a use for the old Door I removed when I built the Workshop Extension, It's angled at around 130 degrees, Wheels are now south facing in the Sun all day since yesterday morning baking nicely
It's early here, so overcast at the minute, but Weather looks good all week, very very shiny yesterday with the Sun on 'em
Biped, doni01 and fsb1284 like this.
Dave
Dave2302 is offline
Old 05-25-2019, 08:59 AM Thread Starter
Dave2302's Avatar
Quoted: 729 Post(s)
Hi,
Tyres fitted and balanced, and I managed to do all 4 without scratching / chipping the finish anywhere
Gonna take me a while to get used to the Gunmetal colour ....................
I can't go for a test drive yet as I've only got 10 of the correct length / type of Wheel Bolts, so currently there is only 3 Bolts holding each Front Wheel and 2 Bolts holding each Rear Wheel, I can drive it in and out of the Workshop but I wouldn't take it up the road like that, there is a new set of 20 Wheel Bolts in the post, but they didn't arrive today
I'm going to finish the Bi Xenon's install tomorrow, I have all the proper Plugs and Wiring Connectors from MB arrived yesterday, plus all the new fancy 5000k Bulbs etc, several different makes of H7's to try in the Full Beams and Fogs, see if I can get 'em to look "whiter light" like the Xenons
The Plugs and Wiring Connectors weren't cheap, just under 66 and that's with my discount , but at least it will all be done properly with the correct plugs etc
Piccies
ID:	2515606   Click image for larger version
doni01 and Deplore like this.
Dave
Dave2302 is offline
Old 05-25-2019, 12:39 PM
doni01's Avatar
Date registered: Jun 2012
Vehicle: S500 4Matic 2005
Quoted: 107 Post(s)
Yeah I agree but since I like you I will do you a favor and take them off your hands
They look great!!!!!
Dave2302 likes this.
doni01 is online now
Old 07-20-2019, 03:02 AM Thread Starter
Dave2302's Avatar
Quoted: 729 Post(s)
Originally Posted by johnksss View Post
Auto folding mirrors on lock and unlocking using convenience feature. (I'm trying to convert mine as we speak)
1 touch auto fold-in/out mirrors. (I'm trying to convert mine as we speak)
Hi,
Please let me know how you do this, I have been looking at achieving it with mine, I have a 2001 S500 to break for parts, that has working 1 touch folding, I currently suspect it is to do with having a different DCM, (perhaps it has had a replacement from a later Car), as I have tried various codings on my personal W220 to no avail.
The bug bear is my W220 has Heated and Cooled Seats, but the breaker car does not so I cannot use that DCM, but when I get time I might just plug it in and see if I can get the One Touch and Fold on Locking working, then if I can I'll look at getting the correct DCM, or it may even be that the Heating and Cooling Buttons can be swapped into the "1 touch" DCM I've not had one apart in a while
Mels C Class did not have this option, but it did have "one touch", I got that one folding / unfolding upon lock purely by Version Coding DCM, (and IIRC Dash Cluster, but maybe not it was a few years back now) !!
Cheers
Dave
Dave2302 is offline
Old 07-20-2019, 03:16 AM
Date registered: Feb 2008
Vehicle: Too many to list
Quoted: 1535 Post(s)
The different seat heat buttons can be swapped into the Dcm
tusabes is online now
Old 07-20-2019, 03:40 AM Thread Starter
Dave2302's Avatar
Quoted: 729 Post(s)
Hi @tusabes
Thanks for that, I thought they could but was not absolutely certain as it has been a while since I had a DCM off a Car
So, swap the DCM and swap Switches, and then maybe just version code the seat fans function, so with any luck I should then have the one touch working and hopefully the Fold upon Locking feature can be coded from there
Cheers
Dave
Dave2302 is offline
Old 07-20-2019, 05:56 AM
johnksss's Avatar
Date registered: May 2014
Vehicle: 2001 S430
Quoted: 23 Post(s)
Hi,
With current knowledge I'd opt for brand new Bilstein Airmatic Struts as and when you need them, they will give you some warning before they "go south"
You [email protected]@r lol, I though I had the lowest mileage pre facelift W220 here at 34,000 miles
As Tusabes says, good deal at $10k
Cheers,
You are right about the struts. Just went through this over the course of the last two weeks. I tried two 150.00 dollar struts and my car road like I was in a lowrider. The 3rd one came from Arnott (300.00) and now the car is riding fine.
@Dave2302
It takes 4 parts. You need both DCM's + mirror switch from a car newer than an 01. And you also need the updated Instrument Cluster. You know you have one if you can get to the hidden menu. And they all need to be coded correctly. I think I have the right drivers DCM, but the passenger may be wrong. So I ordered 2 05's and hopefully they will be here Monday. I am really eager to see if it works.
To the your other post.
It seems that this option was on some 02 cars and more so on 03 and up. The heat/cool can be swapped out and recoded to work the correct buttons for the seats.
johnksss is offline
Old 07-20-2019, 12:57 PM
johnksss's Avatar
Vehicle: 2001 S430
Quoted: 23 Post(s)
Well damn Dave! I found this thread by accident, but what an excellent accident it was. Did not know you had that much time and effort invested in the S500.
Great job!
I need to swap out my grill and hood ornament just like yours.
johnksss is offline
Old 07-21-2019, 02:42 AM Thread Starter
Dave2302's Avatar
Quoted: 729 Post(s)
Hi @johnksss ,
Thanks for confirming that. Maybe European Cars got this option a bit earlier ?
So my breaker Car which definitely has working "one touch" must have all these parts on it, I know it was a very late 2001 / early 02 registered compared to my own restored S Class, which is a mid 2001 reg.
I do have the "mirror fold upon locking" option on the cluster in my good Car, I already Version Coded that, but still they refused to work, obviously I now know I can swap the Mirror Switch pack and DCM's over using the heated / cooling Switches from my good car so here's hoping
Very busy right now, but I'll try and get the DCM's and Switches swapped soon
Cheers,
Dave
Dave2302 is offline
Old 07-21-2019, 02:58 AM Thread Starter
Dave2302's Avatar
Quoted: 729 Post(s)
Hi @johnksss ,
It's been a long haul, and not being daily used yet, as I'm too busy to have finished the Paintwork yet, but it gets my trade plates on it and a good run up the Glen and back, around 32 miles, a couple or 3 times a month just to keep everything moving etc.
Have you actually read it from day one lol, get some popcorn and a flask of coffee / six pack of beers
Cheers,
johnksss likes this.
Dave
Dave2302 is offline
