S500 Resurrection, Dave's Thread - Page 44 - Mercedes-Benz Forum
post #431 of 483 (permalink) Old 11-25-2018, 10:04 AM
Date registered: Feb 2011
Vehicle: 2009 E350 4M Avant Garde, My Mistress 2002 S600, Wife 2014 C300 4M Avant Garde with AMG
Quoted: 155 Post(s)
Dave: "Uebung macht den Meister", or practice makes perfect (loosely translated).
You have obviously mastered a good technique that gives great results. Congrats!!!
FYI: I once on a hot day doing MB Black after the 4th or 5th clear coat it turned "milky". I just kept going, and, miraculously by the next day it was perfectly clear. Never had that again.
Never ever had a run doing the quick coats 5-10 mins max.
I'm an amateur DIY painter, not a pro.
Dave2302 likes this.
Kraut56 is offline
post #432 of 483 (permalink) Old 11-30-2018, 12:46 AM
Date registered: Jun 2018
Vehicle: 2005 SL65 plus 13 other non MB toys
Quoted: 79 Post(s)
Just throwing in my two cents here. Three clear coats only. First one kind of a quick dusting. Second one complete coverage but thin coat. Third as thick as you can get it without runs (this one comes with experience).
Also when painting, put the panel in the correct position it will be when affixed to the car (vertical vs. horizontal). Very important especially with metallics. It is not recommended to do a panel on this day then another panel on that day. Color variations will be very noticeable when the panels are later placed side by side. The best way is to paint and clear jambs, undersides of hoods, etc. then assemble the car and do an all over paint job. Silver is also one of the toughest to get to look good. They seem to "tiger stripe" very easily. Your work is really looking good Dave! For some reason my thumbnails are now all showing. ???
Triple cranks is offline
post #433 of 483 (permalink) Old 01-07-2019, 09:48 AM Thread Starter
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 697 Post(s)
OK, here we go, my W220 resurrection is back again
BTW, the Car is Chalcedonblau 347, not Silver, it's a very pale Metallic Blue, but my photo's hardly show it.
Yeah, when I first started I did the Trunk Lid 3 times before I was happy due to it having slight Tiger Stripes
I'm not having any edge to edge matching issues, always painting in the same direction, and have 10 litres, well around 7 now, of RFU pre thinned Basecoat so no variation = good matching ......................
Well either that or I just got lucky so far
I haven't finished the W220, but I have done the hardest part of it, was supposed to have had the 2 left doors finished yesterday evening, but things never go to plan, and I ended up Clear Coating them today.
My only problem here really is the shape and layout of my workshop, and the fact the S Class is way longer at it's front than rear, plus the location of my lift posts ..................
When I did the 2 Right Doors I was able to open and close them around the Lift Post, without having to move the Car, but the 2 Left Doors needed the Car the other way round, i.e. reversed into the workshop, and this meant I had to keep opening the Workshop Doors to roll the Car forward for opening and closing the Left Front car Door
Translated I then lose all the heat outta the Workshop, and have to re heat each time etc etc, as it's sub zero temps outside this made the entire process a complete [email protected] ache
I would definitely have been quicker to have completely stripped both Doors, then taken them off the Car and done them on a bench, but then I have nowhere dry for the Car to stand with no Doors on it ..................... Catch 22
Anyway, I've finished Clear Coat around 3pm, she's now un masked, and these 2 Doors, like the panels for Mels C Class, and the S Classes Side Skirts etc have come out lovely straight out of the DeVilbiss Gun
They will only need minimal polishing, when the Valet and Polishing Stage arrives.
I'll spend an hour fitting it all back together in the morning before I start back on the growing queue of Customers Cars building up outside now
There is Rear Fenders and Roof left to do, before she can go back on the road, which I will do all in one hit soon. These do not need anywhere near as much masking and messing around, and I can get right around them however I park it in the Workshop
After that Rear Bumper and Bonnet, (Hood), are the only bit's left, but as neither of these are that off Colour or needing work, I will do them at my leisure whilst I am using the Car
I'll take a week off in a month or 2 to do the Roof and Rear Fenders ..............
All in all a happy "Bunny", and I've definitely cracked the Clear Coat now
Pics:-
ID:	2479338   Click image for larger version
ID:	2479340   Click image for larger version
ID:	2479342   Click image for larger version
ID:	2479344   Click image for larger version
doni01, Ex-Fed, compaddict and 2 others like this.
Dave
Dave2302 is online now
post #434 of 483 (permalink) Old 01-07-2019, 12:14 PM
Date registered: Jan 2018
Vehicle: '04 S500 4Matic
Quoted: 44 Post(s)
You would like the model I have on my desk at work!
doni01 and Dave2302 like this.
oliverp is offline
post #435 of 483 (permalink) Old 01-08-2019, 12:13 AM Thread Starter
Dave2302's Avatar
Quoted: 697 Post(s)
Where did you get that gorgeous model ??????????????
I just gotta get me one some time soon, and do a mini paintwork project so the wheels match mine etc etc
Dave
post #436 of 483 (permalink) Old 01-09-2019, 10:17 AM
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2013 S550
Quoted: 441 Post(s)
Indeed, these are nice models. Here is mine - a 1:18 Maisto Premiere Edition (pre-facelift). The label on the "showroom" display says 1998, but even with European model years, that probably relates to the first year is was unveiled, possibly at an auto show.
And now, Dave, it is yours. Even if the steering wheel is on the proper side!!
ID:	2479820   Click image for larger version
ID:	2479822   Click image for larger version
doni01, Dave2302 and oliverp like this.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #437 of 483 (permalink) Old 01-09-2019, 10:24 AM
Skylaw's Avatar
Vehicle: 2013 S550
Quoted: 441 Post(s)
A few more...
ID:	2479834   Click image for larger version
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #438 of 483 (permalink) Old 01-09-2019, 10:24 AM
Quoted: 44 Post(s)
Yes, that's the same as mine - the Maisto model.
I had lots of these growing up and my parents have since given them away. So sad!
oliverp is offline
post #439 of 483 (permalink) Old 01-09-2019, 10:34 AM Thread Starter
Dave2302's Avatar
Quoted: 697 Post(s)
Hi Guys,
Wow, these really are very beautiful Models
Once again, this really is appreciated, it will be treasured, many many thanks Warren, I can't wait for Mel to see it
Cheers
oliverp likes this.
Dave
post #440 of 483 (permalink) Old 01-10-2019, 09:44 AM Thread Starter
Dave2302's Avatar
Quoted: 697 Post(s)
Hi Guys,
Well below is a paintwork pic that I took outside tonight when it was dark, with Workshop lights shining at the front of the Car to try and capture the different "colour hues" of the "Chalcedon Blau" Paintwork as the light alters along the length of the Car, it goes from "Silver" looking to "Blue" looking, but as usual my pix don't do it justice
The best one I got was the one below, of the Left Front Door, and also bearing in mind this paintwork is "off the gun" so not polished at all, and it is very dark outside, see the reflection of Mels C Class standing along side it
When the Car is done I will see if I can get a better picture with my Canon DSLR up on here, but I fear the files will be too big
All my pics on Benzworld are just shot with a crappy Samsung "point and shoot" that I keep in the Workshop
Also included are pictures showing how I am fitting it up with maximum care and protection from future rust ............
I have Waxoyled the fixing clips for the Door Window Trims and put little pieces of pvc insulating tape over the doors edges where the clips go, Waxoyled behind the Plastic Door Mouldings fixing holes, and behind the Door Handle holes rubbers
Also I've Waxoyled inside the channel of the brand new Mercedes Door Bottom Lip Rubbers you can see the Waxoyl at the moment on the Door bottoms (yellowy greasy look), once it all sets nicely I will tidy it up with a damp rag, that is the best protection I can give it for the future.
I have also Waxoyled up inside the Doors drain holes, and before she hits the road again I will have all the Doors Interior Trims off and Waxoyl from inside as well.
With any luck she'll be ready for the road spring time, so all the salt will be away by then
Finally the Front Bumper Primer is now wet flatted, hopefully I'll get it painted and clear coated by the end of this weekend, and find some time next week to refit it
Then it will be Rear Bumper off, and start prepping the Rear Fenders and Roof ready for Paint
The eagle eyed amongst you will have noticed I have not refitted the Chrome / shiny Stainless Strips to the Door Mouldings yet, there is a very very very good reason for this.................
But it is "Top Secret" right now, however when the Car is almost complete you will see why ...................
Oh the suspense
Pics:-
ID:	2480038   Click image for larger version
ID:	2480040   Click image for larger version
ID:	2480042   Click image for larger version
ID:	2480044   Click image for larger version
Dave
