Is this normal? lowered ABC suspension after shutdown. - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 08-04-2016, 06:07 PM Thread Starter
ajunsu's Avatar
Date registered: Aug 2016
Vehicle: 2005 W220 S500
2005 W220 S500 with ABC
I have noticed that in the morning before I start my car, the suspension on the front left (driver side) is lowered quite significantly.
When I start the car and press the button to raise the body, the suspensions level out evenly immediately.
There is no problem driving it and ABC itself seems to be working fine considering the pleasant ride quality.
Is this normal?
Could it be a leak? or loss of liquid?
ajunsu is offline
post #2 of 17 (permalink) Old 08-04-2016, 06:36 PM
calgary's Avatar
Vehicle: 2001 CL500 2006 E350 4-matic
Quoted: 60 Post(s)
Is this normal?
Not normal, but it happens to many ABC equipped models. It could be a leak or low oil level in the system. Have a look and see if you see any oil on the floor (green oil) or if the oil level on the dipstick shows loss of oil. (Not the dipstick for engine oil)
calgary is offline
post #3 of 17 (permalink) Old 08-05-2016, 03:15 AM
Date registered: Mar 2016
Vehicle: 2005 Mercedes-Benz S600
Quoted: 4 Post(s)
I can think of a couple of scenarios:
1. Leaky strut or line: in this case you will find some green Pentosin oil under/around the offending strut as calgary pointed out.
2. Malfunctioning valve block: the valve block has a shut-off valve that ensures that the car stays level after turning the engine off (or when pump is not running). The seals of this valve deteriorate over time and it leaks the ABC fluid back into the reservoir through the ABC plumbing. In this case you may not see leaked fluid under the car.
Hope this helps.
Is this normal?
prs600 is offline
post #4 of 17 (permalink) Old 08-05-2016, 05:43 AM
Date registered: May 2011
Vehicle: 2005 S600
Quoted: 53 Post(s)
Not normal.
It should hold its height for several days. Beyond that period of time, some sag is considered normal.
Generally, it's internal valve block leakage. A rodeo and fluid flush, with new ABC filters, would be the first thing to try. Next is a removal of the valve blocks, disassembly, cleaning, and o-ring replacement. The latter fixed the sag in my ABC car.
Current Fleet:
2016 Tundra 1794
2005 MB S600 (100K, Michelin AS3+, M1 0W40)
2002 V70-XC (228K Castrol 0W40)
2002 V70-T5 (198K, Mobil 1 0W40)
1932 Packard Sedan (straight 8, dual sidemount spares, original paint and interior, Shell Rotella 15W40)
Astro14 is offline
post #5 of 17 (permalink) Old 08-05-2016, 08:21 AM
mercy-me's Avatar
Date registered: Apr 2012
Vehicle: 2003 SL500, 2012 E350 4Matic P2
Quoted: 63 Post(s)
Originally Posted by Astro14 View Post
Not normal.
Spot on. If there is no external leak then fluid is bypassing the left side valve in the valve block.
See attached DTB for clarity on the sagging issue. There are also write-ups on doing a fluid & filter change without SDS. I don't think that the original 10 micron filters are still being sold but you want to be sure that you get a 3 micron filter as that is the latest spec.
Good luck,
Bob
(Thanks Astro, I transposed the numbers of course. I have edited to the correct values.)
File Type: pdf DTB PB 32.50-34 Suspension Lowing Issue Causes and Corrections.pdf (147.5 KB, 89 views)
File Type: pdf ABC Oil Reservoir Loacation task design.pdf (37.8 KB, 83 views)
File Type: pdf Filter Active Body Control (ABC) hydraulic fluid.pdf (62.2 KB, 82 views)
Cinnasnootzer likes this.
mercy-me is online now
post #6 of 17 (permalink) Old 08-05-2016, 07:06 PM
Vehicle: 2005 S600
Quoted: 53 Post(s)
I believe that 3 micron (finer) is the most recent filter specification. 10 micron was the previous filter specification. Hard to believe that particles that small will foul the system, but the valves are solenoids, they are electromagnets, and wear particles (steel or iron) will stick to them and cause them to leak when they shouldn't.
Clean fluid is essential to ABC component life.
Current Fleet:
2016 Tundra 1794
Astro14 is offline
post #7 of 17 (permalink) Old 08-06-2016, 04:21 AM
mercy-me's Avatar
Quoted: 63 Post(s)
Thanks again Astro..............................
Some additional reading on the subject here.
Bob
post #8 of 17 (permalink) Old 08-09-2016, 06:26 PM Thread Starter
ajunsu's Avatar
Update on situation.
Thank you for all your advises.
Here is an update. The following are further investigations taken.
1. There seems to be no external leak (what a relief)
2. So value issue is highly thought to be the reason.
3. Does not sag within an hour or two, but is visible after 3~4 hours.
At overnight, tire is even touching the rim, when not in straight position.
4. Returns to normal position when engine is turned on AND "level control" button is pressed. So there is no problem running the vehicle.
However, operating the vehicle or turning steering wheel without once raising the body will probably cause excessive damage to wheel or rims. So need to fix this immediately. Might cause damages in Valet situations.
Actions taken.
First of all, the ABC fluid level was very low.
fluid barely touched the dip stick even when the engine was off (Aus).
Wonder where all the fluid went... (there must be a problem somewhere..)
So I have added about 500ml of ABC fluid to the system, and now is in normal level.
I will observe progress (if it still sags) after 4~6 hours.
If sagging continues, I will have to find time to work on the valves.
Thank you.
ajunsu is offline
post #9 of 17 (permalink) Old 08-09-2016, 06:34 PM
Cinnasnootzer's Avatar
Date registered: Mar 2014
Vehicle: 2001 ML320 2004 ML500 2011 E350 2015 ML350 2002 CL55 AMG
Quoted: 192 Post(s)
If the accumulators, or nitrogen spheres by another name, are failed or failing they can start to fill with the Pentosin fluid.....So you will not see a leak in the closed system, but the fluid is collecting in the spheres.
There is a rubber membrane in the spheres that separate the fluid side from the nitrogen side. This is the component that degrades and fails over time.
P.S. - you are very smart to get on this right away and not let it become a disaster.
Cinnasnootzer is offline
post #10 of 17 (permalink) Old 08-09-2016, 09:44 PM Thread Starter
ajunsu's Avatar
Yup, She's still sagging...
Despite the addition of ABC fluid, the sagging is still present.
Looks like I need to take time to work on the valves.
I will update this at a later time.
ajunsu is offline
