THERE IS A 2014 NAV MAP UPDATE DVD FOR THE '04-'06 W220
New Information (confirming the there IS a 2014 nav DVD update for the '04-'06 W220 and and possibly the MY04-’06 CL Class and MY05-’08 SLK and SL Classes). All of those models have the NTG1 (COMAND 2.0), and should be able to use the DVD described below.
I just purchased the 2014 update that Ex-Fed references above. While neither the disc nor the box referenced the '04-'06 W220, I bought it because it referenced ALL the other models that had used the earlier discs for the W220. While the labels added models of the Maybach, it omitted the '04-'06 S-Class. I inserted the disc, and it went through the usual brief update sequence, then became available.
All features work in my car. Photos of the disc and the box are below.
Some confusion factors you may need to work through with your dealer and the NavTeq (Navigation.com, aka HERE) website:
1. If you enter navigation.com with data related to the '04-'06 W220, you will be taken to a page showing the latest update as being 2011 update v.10. THIS IS INACCURATE.
2. If you enter the navigation.com site with data indicating any of the other models - such as the applicable years of the E, SLK, CLS or Maybach, you will be taken to a listing for the 2014 NTG1 DVD v.13.0 DVD. THIS IS ALSO THE DISC FOR THE '04-'06 W220 although the label on the disc and on the box do not say so. NavTeq lists it for $249.
3. I contacted Navteq (navigation.com) approximately by email to query the discrepancy; after 30 hours at the time of this post they have not responded.
4. The part numbers for the 2014 nav DVD for North America, including the U.S., Canada, Alaska, Hawaii, Puerto Rico and the US Virgin Islands is Version 2014 BQ 6 46 0315, A211 827 49 65. Navigation .com describes it as "2014 Mercedes-Benz NTG1 DVD v.13.0" (but Not on the W220 page).
Note: the COMAND system for the '04-'06 W220 IS NTG1. In another departure for NavTeq, they DO show the MB part number for the DVD (in the past they have not).
5. My dealership queried NavTeq directly again this morning, and fed them the information above. NavTeq professed no knowledge (but it was the warehouse she was talking to). I asked her to bring out a disc for the '05 E-Class; it was of course the disc pictured below. Essentially, NavTeq mis-designated the 2014 disc, and as a result its website, the disc label, and the box description are incorrect, as was their failure to notify dealerships of an update for the W220.
6. If you have not updated your nav maps in a while, see post
#12 at
http://www.benzworld.org/forums/audio-telematics-forum/1360778-re-command-aps-upgrade-mode-2.html - I had no problem going from the 2011 v.10 to the 2014 v.13, but can't speak for earlier discs.
NOTE: One of our members reports that he was able to upgrade from a 2005.1 nav DVD (MB part # BQ 6 46 0206) directly to the 2008/2009 v.8 DVD (P/N BQ 6 46 0243); and then direct to the 2010-2011 v.10 DVD (P/N BQ 6 46 0262); and from that, to the v.13.0 DVD discussed here (P/N BQ 6 46 0315).
No interim update was required using this upgrade sequence (a good thing, because even though he ordered the v.13.0 DVD from his dealer - and received the v.10 disc, and had to argue with them to get the v.13.0 disc - they were going to charge him an hour's labor for the interim updates, which is something most dealers will do free if you order the disc from them).
Here are the pics of what I bought, in case you run into someone at a dealership who is incredulous (because they are stuck with a bunch of outdated 2011 discs that NavTeq/HERE Maps failed to notify them to return for credit).
