S500 W220 Automatic trunk opener fix - Mercedes-Benz Forum
post #1 of 28 (permalink) Old 08-10-2012, 11:52 AM Thread Starter
Date registered: Dec 2009
Hi guys, have a S55 AMG and my automatic power trunk opener stopped working. First it started only lifting the trunk half way, then it quit alltogether. Heard a groaning noise coming from the hydrolic cylinder under the side trunk trim. Benz dealer told me I need to replace the whole pump/cylinder assembly. $1,100. GASP. took the car home and pulled the pump out from by the battery. It has a resevior to hold hydro fluid. Looking further I notice little to no fluid in that resevior. Took the clamp off and twisted the resevior off, (only sealed by an "O" ring) it was empty. Took some ATF/ power steering fluid and filled it up, slid back on, replace clamp......WORKS as new! I did not find this procedure anywhere so I decided to give this shout out. There may be a small leak by the hydro cylinder where it was loosing the fluid. I bet it lasts for years though. Hopefully this can help someone to do it yourself, service, not replace!
StigHelmer likes this.
craigndee is offline
post #2 of 28 (permalink) Old 08-10-2012, 12:30 PM
Date registered: Jul 2011
Vehicle: S320 W220
Quoted: 2 Post(s)
Sounds interesting and cool your DIY though I don't have the automatic trunk opener feature.
Thanks for sharing!
mghaz is offline
post #3 of 28 (permalink) Old 10-08-2012, 12:49 PM
TxML320's Avatar
Date registered: Jan 2003
Vehicle: 2002 S430, 2002 Camaro SS, 2010 Navigator
I am having this same issue with my hydrolic pump for the Trunk opener, I will try this fix as the dealership quoted me $800 to replace the pump as it was a non-serviceable part! I noticed the clamp holding the reservoir and it was only half full, but they told me it was a sealed system and the fluid could not be topped off. Thanks for the info!!
2002 S430 Black with Java Leather. Keyless Go, Rear Side and Back Window Roller Blinds, Electronic Trunk Opener, S3 Comfort Package, Integrated Motorola V60 (now replaced with Motorola Bluetooth Puck) with Voice Control, and CD changer. Chrome AMG split spoke wheels witth Michelin Pilot A/S Plus tires
2010 Lincoln Navigator Tuxedo Black Metallic Black Leather Interior, every option.
2002 Silver Camaro SS #8539 Ebony Leather, every option. 496 RWHP 536 Torque
TxML320 is offline
post #4 of 28 (permalink) Old 10-08-2012, 03:11 PM
Date registered: Jan 2008
Vehicle: 98 ML320, 01 S500, 15 GL350
Quoted: 7 Post(s)
Can someone post a picture of the pump?
idahombz is offline
post #5 of 28 (permalink) Old 10-08-2012, 04:53 PM
Date registered: Jan 2007
Vehicle: 2003 S55K, 2002 W220 S430 (RIP), 1999 W163 ML430, 2004 W230 SL500 Sport
Thanks for Sharing the information. I will check my fluid. Mine intermittently when the trunk is raised will start to go down after a few seconds. It started doing it but not all the time. From the ssound of it maybe i have a small leak in the supposedly "sealed" system. Now I know where the reservoir is. Thanks.
wsy3benz is offline
post #6 of 28 (permalink) Old 10-08-2012, 05:37 PM
TxML320's Avatar
I just filled my reservoir all the way up with power steering fluid and now my trunk goes all the way up quickly and stays up until I push the button to make it go back down, that's so much Craig for finding and posting this fix!!! This issue has been driving me crazy for years, but not $800 crazy! Lol
TxML320 is offline
post #7 of 28 (permalink) Old 10-08-2012, 08:09 PM
Quoted: 7 Post(s)
Where is the reservoir? in Trunk? Thanks!
idahombz is offline
post #8 of 28 (permalink) Old 10-08-2012, 08:12 PM
TxML320's Avatar
In the trunk next to the battery under some foam. This is only if you have the automatic trunk opener/closing option.
TxML320 is offline
post #9 of 28 (permalink) Old 10-08-2012, 08:39 PM
Quoted: 7 Post(s)
Thanks! I took a look, there is nothing next to the battery! I have open trunk button on the remote but no auto closing. Maybe I do not have that feature....
Trunk can not be opened fully though!
idahombz is offline
post #10 of 28 (permalink) Old 11-13-2012, 10:46 AM
Date registered: Feb 2010
Vehicle: 2010 GL350 Bluetec
I am having the same issue. I just went out to the car and pulled the pump out. There is good bit of fluid in the reservoir. Should I open it, drain the fluid and refill it completely with new fluid?
Jason
2010 GL350 Bluetec
2000 C230 Kompressor
2004 S500 4-matic
1995 S500 254K and going strong!
Sold
1983 380SEL 1st Benz!
1989 420SEL
1989 190E 87K Miles
1998 E300 Turbo Diesel
1992 400E 189K
1995 C220 Died
1986 260E
JB380SEL is offline
