Upper Control Arm replacement steps? - Mercedes-Benz Forum
post #1 of 55 (permalink) Old 07-12-2011, 08:17 PM Thread Starter
Date registered: Jan 2007
Vehicle: 1982 240D, 1986 560SL, 1987 560SEC, 1990 300SE, 2002 E320, 2002 SA 500SL, 2005 S500, and others
Quoted: 7 Post(s)
My new to me 2005 S500 4Matic has a front right suspension rattle that I have diagnosed as a bad upper ball joint. The boot is torn, and I can induce play with a pry bar, so it needs to be replaced.
The car has only 56,000 on it, and the remainder of the front suspension seems fine, so I just want to do this one part.
I have not had a chance to purchase a shop manual yet and with 3 other MB’s in the garage, normally I can make do with my knowledge base and other manuals, but this suspension is entirely new to me. I have searched the forum, but most of the posts relate to the lower arm and ball joint.
The work looks very strait forward and accessible but some pointers would be helpful. I believe the inner bolts are removed from the engine side and the upper bolt simply removed and the ball joint separated. Then be careful to make sure that the ride height sensor is put back correctly
Do I need to release the air on this side before starting? Any other points to remember?
The car will be on a hoist for this work.
If there is any interest I can post some pictures on this procedure.
Thanks,
John
jwells is offline
post #2 of 55 (permalink) Old 07-13-2011, 09:31 PM
Date registered: Feb 2009
Vehicle: 2002 S500, 1993 Nissan 300zx
Quoted: 2 Post(s)
It's actually pretty easy.
Put it on a hoist, and remove the tire for that area. Let the shock hang fully extended. Undo the air connector on top of the shock very slowly...you will hear air hiss out.
Two bolts on the control arm that connect it to the body.
One bolt on the arm that connects it to the hub/spindle.
Use a pickle fork to help split the joint - pickle forks are know for destroying ball joint boots, but since yours is torn anyways, I would not worry about it.
By the way, with stubborn ball joints, I use 2 pickle forks at the same time - one on top of the other.
You can also use a small sledge hammer to smack the tip of the joint.
It can be slow going, but it will go.
Put back together in reverse order. Should take under an hour.
leerandallstewart is offline
post #3 of 55 (permalink) Old 07-14-2011, 07:47 AM
mjd
mjd's Avatar
Date registered: Aug 2008
Vehicle: 94 E320 Sportline sedan 86 190E 2.3 16V sedan 04 S430 Sport
Quoted: 2 Post(s)
My only suggestion to add is to use the proper joint seperator tool for the upper ball joint...
Mercedes Benz/BMW/VW Ball Joint Separator Removal Tool | eBay
Less risk of a "hammer swing & a miss" damage to other components. Also pickle forks and alloy suspension parts usually result in damage.... older cars that had iron suspension parts can take the abuse of a pickle fork... but you can nick and scare up the alloy arms very easily... especially if you were planning on reusing them.
Just a suggestion.
mjd is offline
post #4 of 55 (permalink) Old 07-15-2011, 10:20 AM Thread Starter
Quoted: 7 Post(s)
Ok thanks for the help. I've got pickle forks, but I have some other pending suspension work on the W124 and my Suburban, so I am going to pick up a set of separators for suspension work. One of the kits with 4 or 5 separators like the ones by OTC.
I will take some shots of the work when I get to it next month.
Thanks again.
John
jwells is offline
post #5 of 55 (permalink) Old 07-15-2011, 11:07 PM
Bexar80's Avatar
Date registered: Aug 2009
Vehicle: S500
I had a torn boot also and just replaced the boot from one I cannibalize at a local salvage yard. Luckily I did not have any play in the joint and it gave me a chance to pump some new grease in the joint which I also did to the other side.
I would recommend this style ball joint separator. My joint came loose very easy but a northern car may need a few hours or a day prior treatment of penetrating oil. I agree that a pickle fork is way to barbaric and can easily cause collateral damage.
The upper control arm needs to be torqued on the frame under load, ie vehicle curb height. This will be difficult to properly achieve. Because of this I would avoid releasing air from the struts if it at all possible. Once you install the control arm loosely at the frame and the ball joint is torqued to the spindle, place a jack under the suspension and raise it until the car is slightly lifted off the jack stand. The suspension will be under load, not really full curb height load but close enough. Then torque the arm at the frame and repeat on the other side. I have used this method many times with great success on my BMWs and my w220's lower control arm replacements.
Ying / Yang
Bexar80 is offline
post #6 of 55 (permalink) Old 07-21-2011, 10:27 PM Thread Starter
Quoted: 7 Post(s)
Thanks for all the tips. This job is on the agenda for next month.
I am still wondering though why releasing the air is such an issue. I would rather deal with the suspension with the pressure out of the struts and I do not understanding the suggestion to not release the air.
I would assume that after the new arm is in place “finger tight”, you would retighten the air connection, start the car and slowly lower the car on the hoist until it is fully resting on the suspension then torque the bolts.
Is there an issue here I am missing?
Thanks,
John
PS: I really like the 220 interior.
jwells is offline
post #7 of 55 (permalink) Old 07-21-2011, 10:52 PM
Bexar80's Avatar
Vehicle: S500
I just feel that unless the airmatic system needs service there is no reason to open the lines. I worry of contaminates getting into the system, even the smallest piece of dirt. I would be livid if I had a complication arise in the air system from an unnecessary disconnect.
Also I think deflating the strut is an unnecessary step in the upper arm service anyway. Unless the whole strut needs to be removed for access to the upper control arm bolts.
Which ever method works, just remember you won't be able to access the bolts with the wheels mounted. Best of luck however you get it done.
Yep that is a good picture.
Ying / Yang
Bexar80 is offline
post #8 of 55 (permalink) Old 07-22-2011, 06:41 AM
mrelbe's Avatar
Date registered: Jul 2004
Vehicle: 2005 SLK350, 91 300SL with Pano Top, 04 S500, 2015 Tesla Model S
Quoted: 102 Post(s)
John, when you are ready to tackle this job I would be interested to observe/help if possible. I'll bring the beer.
91 300SL with Pano Top, 2005 SLK 350, 2014 Tesla Model S P85D Ludicrous
formerly 1980 450SL, 1990 560SEL, 2004 S500
Black Fuzzy Dice Gang Member
mrelbe is offline
post #9 of 55 (permalink) Old 11-30-2011, 07:28 PM Thread Starter
Quoted: 7 Post(s)
Well, after much delay I finally got around to this job (sorry mrelbe for the lack of notice).
It is a very straightforward job, rating maybe a 3 on a scale of 1 to 10.
I used the following procedure:
1. Raise the car and remove the wheel.
2. Remove the small nut for the airmatic ride height sensor and remove it from the arm.
3. Remove the two main nuts holding the arm to the body, and the nut on the ball joint.
4. Using a separator release the ball joint from the top of the spindle. The first picture shows the type of separator I used. It came apart very easily. You can ignore the clamp which you see in the picture. I was unsure of the various forces that may have been present after the ball joint separation since I did not deflate the strut, but there were none.
5. Remove the bolts and the arm. The arrows in the second picture show the rear bolt being removed, and the height sensor disconnected.
6. Put the new arm in place and just lightly snug the main bolts, then tighten the ball joint nut and replace the height sensor.
7. Finally I jacked up the strut from directly below to simulate normal ride conditions and then fully tightened the main bolts with the wheel still off.
All done with a nice tight ride, and I don't believe any alignment points were affected, so I have not scheduled an alignment which was done only 6 months ago.
Thanks for the help.
By the way the oily looking strut is the winter rust treatment I just had done.
John
ID:	412928   Click image for larger version
ID:	412929   Click image for larger version
2sl0w likes this.
jwells is offline
post #10 of 55 (permalink) Old 11-30-2011, 10:41 PM
Date registered: Oct 2011
Vehicle: 2006 Mercedes S55 AMG
Send a message via AIM to cmpcpro Send a message via Yahoo to cmpcpro
Nice! How much play did you have in your joints? I will try to crawl under my car and see what all is new and what looks old.. Was it bad enough to have play in the tire?
cmpcpro is offline
Upper Control Arm Bushing Replacement marshcat R/C107 SL/SLC Class 7 06-22-2011 07:16 PM
Upper control arm replacement for 4matic IFS W210 E-Class 10 11-19-2010 11:02 AM
Upper Control Arm Replacement woernert R/C107 SL/SLC Class 1 07-17-2010 05:42 PM
Upper Control Arm Replacement MBZ_300D W123 E,CE,D,CD,TD,TE Class 13 02-23-2010 11:11 AM
C280 Upper Control Arm Replacement Procedure shekarg W202 C-Class 3 08-29-2009 11:25 PM
