How do I direct wire the radiator fan? - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 02-26-2011, 07:13 PM Thread Starter
Date registered: Feb 2011
I've got an 2003 s600 that I'd like to be able to turn the radiator fan on and off at will. I like to turn it on when I'm in the staging lanes at the dragstrip. Is there a way to bypass the fan control module? There are 4 black wires going from the fan control module to the fan motor itself? Does anyone have a schematic of what each of these 4 wires does?
Silverstallion is offline
post #2 of 13 (permalink) Old 02-27-2011, 04:57 AM
Date registered: Dec 2009
Vehicle: s320 white
you said it yourself, its a control module that controls the fan, so even if you will disconnect the supply to it- you will only be able to switch it off. But its not up to yo then to switch it on at the moment. The controller switching it on. unless you want to cut it all off and have simple positive negative to it. Doesnt make sense to me, but if thats what you wanna do...
jurka is offline
post #3 of 13 (permalink) Old 02-27-2011, 07:01 AM
dlynch4008's Avatar
Date registered: Apr 2008
Vehicle: 2000 MB S500 and a 2009 Kia Optima
Unless you use the car on the track exclusively, I can't even imagine why you would want to bypass the fan. The first time you get stuck in a Summer traffic jam, you have other things on your mind, and you forget to "flip the switch". Doesn't take long for an overheat to destroy an engine...
Have you put the car on a Dyno to see how much BHP you are actually losing when the fan kicks on? With an electric fan, it should be absolutely minimal...
dlynch4008 is offline
post #4 of 13 (permalink) Old 05-11-2019, 02:20 PM
Date registered: May 2019
I have a Mercedes-Benz A0999063902 Rad Fan and I am trying to wire in but not having any luck. It has 4pin wire coming out of motor 2 10 gauge and 2 16 gauge wire and it is variable speed. trying to wire it in to 54 pickup. Please HELP me.
Tim Beausoliel is offline
post #5 of 13 (permalink) Old 05-12-2019, 09:47 PM
Date registered: Jan 2019
Vehicle: 2004 Mercedes S430 4Matic
Quoted: 16 Post(s)
It shouldnt be hard to find out on your own.
I understand why you would want that baby on high
right on the ling when your staging.
What I would do is just probe it when its hot or force it on
like turning on the A/C and find out which one lights it up and just set up a different
wiring hooked up to a switch inside somewhere with the plug unplugged so when ur at
the strip next time you can force it on
Or it might just be throwing grounds from the coolant temp switch or lowering or rising resistance from cold to hot and that might be the slick way to
power it up on the line
I know its thrown on with the reading from the coolant switch thu the engine control module
I think from the one on the back of the cyl head
Ill look into it and let ya know a little later on if no one tell ya a simple way to hot wire/override ur fan
And tell me whats ur 60 foot times and ET's and MPH ??????
and ya have a videos you care to share????
cudamax is offline
post #6 of 13 (permalink) Old 05-12-2019, 09:56 PM
Quoted: 16 Post(s)
Wait let me look up a cooling fan relay and coolant temp switch
It would be easier to bypass a relay. Let me see and Ill get back to ya
cudamax is offline
post #7 of 13 (permalink) Old 05-12-2019, 11:55 PM
Dave2302's Avatar
Date registered: Nov 2013
Vehicle: V220 Ambiente S500 W220 SLK320 R170 C200 CDI W203 Peugeot Expert Van
Quoted: 670 Post(s)
W220 Cooling Fan Controller is Hard Wired to Permanent + and -
It receives a PWM Signal from ME ECU and as the Pulse Width varies based upon Engine Temp Data so the Fan Speed varies.
Why anyone would want to mess with it is beyond me, and if your looking to install this Fan in something other than a W220 then there are far better aftermarket alternatives available.
Dave
Dave2302 is offline
post #8 of 13 (permalink) Old 05-13-2019, 01:03 AM
Date registered: Feb 2008
Vehicle: Too many to list
Quoted: 1478 Post(s)
Sounds like he is trying to install it in a 1954 pickup . Probably got it cheap at the junkyard .
Dave2302 likes this.
tusabes is offline
post #9 of 13 (permalink) Old 05-13-2019, 03:03 AM
Dave2302's Avatar
Quoted: 670 Post(s)
Just needs a regular Car type 12V Fan and a Relay, I'd also use a Thermostatic Switch that fits in the Cooling System, less chance of forgetting to switch it on then
Dave
Dave2302 is offline
post #10 of 13 (permalink) Old 05-13-2019, 05:01 AM
Quoted: 16 Post(s)
Come on Everyone Dont Bash em because you have never been at the Strip
cudamax is offline
Direct wire radar my1stbenze Audio & Telematics Forum 0 06-16-2010 11:34 AM
Radar detector direct wire carreracup03 X164 GL-Class 11 01-12-2009 07:38 AM
Valentine One Direct Wire Installation for 2002 CL500 toodeep C215 CL-Class 0 01-03-2007 06:45 PM
Direct wire for Escort 8500 X50 - Problem finding "key-on" circuit. ddd269 C219 CLS-Class 1 11-29-2005 08:34 PM
Direct wire for Escort 8500 X50 - Problem finding "key-on" circuit. ddd269 Audio & Telematics Forum 3 10-04-2005 10:31 PM
