Cannot get rid of vibration - please help - Page 3 - Mercedes-Benz Forum
post #21 of 21 (permalink) Old 06-10-2019, 03:56 AM
jnash's Avatar
Date registered: Apr 2005
Vehicle: 2003 S55 AMG
Quoted: 31 Post(s)
yes correct, on the flat surface of the hub that the wheel mates to, there is a round lip on the circumference of the hole in the middle, just fold the extra unused width of the PVC tape into the center hole. Clean it with a wire brush and brake cleaner and let dry before applying tape. Also, when I had my drive drive rebuilt, they marked with arrows each half to align the spline that separates both drive shaft halves and also threaded in a hex grub screw to ensure once the drive shaft was fully installed, and tightened there was no play in the center spline bearing. Those spline pin bearings where the two halves meet (in front of the universal joint) were also replaced.
2003 S55
K&Ns, 80mm TB, NPI headers, X-pipe / 3in pipes, Kleemann Cams & 168mm Pulley, ECU & TCU tune. 550cc injectors, Meziere WP136S SC pump. UPD SC pulley & SC belt wrap, Alum idler pulley set. Fuel rail loop, LFR7AIX plugs, NPI heat exchanger, -10C mod, shift paddles, TeleAid removed.
Lowering links (1.5" front, 1" rear), 18x9.5+35 offset rims, clear side markers, KG Key retrofit, H/W Valentine1, BT phone, BT AUX, laser jam, upgraded fans in seat backs, inline ABC mag filter.
jnash is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
why get rid of this...? dbs600 W140 S-Class 7 10-19-2009 05:46 AM
GETTING RID guv C215 CL-Class 1 04-07-2009 02:13 PM
How to get rid of old Sh*t ? Kajtek1 Off-Topic 3 01-06-2008 03:58 PM
get rid of that ad! bennyndjets R/C107 SL/SLC Class 5 07-29-2006 01:24 PM
getting rid of my slk32 Brian Acosta R170 SLK-Class 7 03-25-2002 12:13 AM
