How to remove the Side Mirror Housing (with electric folding mirrors). - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 09-20-2009, 12:42 AM Thread Starter
Date registered: Aug 2009
Vehicle: W107 W113
Quoted: 91 Post(s)
Hello:
I have read many of the posts on this forum and the mbworld, but its all very confusing.
Some people say its wrong/right.
I think the reason is that they are confusing the electrical with non-electrical folding mirrors.
These are the posts I have:
2000-2002 S500 Side Mirror Led Light Upgrade Before And After Picts - MBWorld.org Forums
I dont understand where the clip is located to release the housing and in which direction to move it...
R107
S320L1999 is offline
post #2 of 11 (permalink) Old 09-20-2009, 01:27 AM Thread Starter
Vehicle: W107 W113
Quoted: 91 Post(s)
Here
R107
post #3 of 11 (permalink) Old 09-20-2009, 01:35 AM
Outstanding Contributor Always Remembered RIP
eric242340's Avatar
Quoted: 334 Post(s)
^^^That is the clip, but not sure which way to push it.
ERIC.
This definition tells you all you need to know about 'PC'
PC, aka, Political Correctness, is a doctrine, fostered by a delusional, illogical minority (Liberals/Socialists) and promoted by the mainstream media, which holds forth the proposition that it is possible to pick up faeces by the clean end.
eric242340 is offline
post #4 of 11 (permalink) Old 09-20-2009, 01:40 AM Thread Starter
Vehicle: W107 W113
Quoted: 91 Post(s)
post #5 of 11 (permalink) Old 09-20-2009, 02:01 AM Thread Starter
Vehicle: W107 W113
Quoted: 91 Post(s)
Just when he unclips the "clip" the camera is aimed away from it...I still dont understand in which direction I should push the clip....
R107
post #6 of 11 (permalink) Old 09-20-2009, 02:08 AM
eric242340's Avatar
Quoted: 334 Post(s)
Why not try pushing up and then down and see which is the most effective.
ERIC.
post #7 of 11 (permalink) Old 09-20-2009, 02:50 AM Thread Starter
Vehicle: W107 W113
Quoted: 91 Post(s)
I got it off!
These are the steps:
1. Set the mirror ALL the way to the UP position.
2. Using a strong falshlight, aim to the LOWER RIGHT corner of the mirror, you will see the clip indicated in this post.
3. With a flat blade screw driver, push the clip UPWARDS, this will free the mirror housing.
4. Now, set the mirror in the "middle position (UP-DOWN) and the ALL the way INWARDS.
5. Then slide the mirror housing out! (using both hands).
Thanks to all.
R107
post #8 of 11 (permalink) Old 09-20-2009, 02:57 AM
eric242340's Avatar
Quoted: 334 Post(s)
Obviously up was the most effective
ERIC.
post #9 of 11 (permalink) Old 06-17-2017, 03:35 PM
Date registered: Jul 2015
Vehicle: ML 320 (1998 year model) - W163
Quoted: 6 Post(s)
Send a message via Skype™ to Epatias
Hello there...just did the same at driver's side mirror and work perfect but the RIGHT side mirror won't move...any idea?
Epatias is offline
post #10 of 11 (permalink) Old 06-19-2017, 07:12 AM
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2013 S550
Quoted: 444 Post(s)
I take it you had selected the right side mirror with the control at the driver's door? If so and it still won't move, I would suspect a wiring problem - which, unfortunately, could be anywhere from the driver's Door Control Module; or at the point where the wiring harness gets flexed regularly by opening and closing the passenger door; or at the mirror assembly itself.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
Electric folding mirror fault?? iimms W203 C-Class 10 07-09-2013 03:09 AM
2003 E320 - REMOVE RIGHT SIDE MIRROR HOUSING allana83 W211 E-Class 3 01-14-2009 07:41 AM
facelift door mirrors w/o electric folding option Alex L W163 M-Class 2 03-03-2007 07:38 AM
Need to remove folding mirrors to sale sellingmybenz W203 C-Class 3 08-04-2006 08:25 AM
Those of you who did not order electric folding door mirrors... ianx, manchester R171 SLK-Class 3 08-01-2004 12:48 AM
