S & CL Class Recall - ABC High Pressure Distribution Hose - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-16-2007, 04:41 PM Thread Starter
MBS430's Avatar
Date registered: Oct 2005
Vehicle: S550, S430
Quoted: 2 Post(s)
Exclamation S & CL Class Recall - ABC High Pressure Distribution Hose
NHTSA ODI - Recalls
NHTSA Recall Campaign Number: 07V263000
Component: ENGINE AND ENGINE COOLING
Details: ON CERTAIN VEHICLES, CORROSION MAY OCCUR IN THE INNER STEEL PORTIONS OF THE ACTIVE BODY CONTROL'S (ABC) HIGH PRESSURE DISTRIBUTION HOSE DUE TO EXTENSIVE EXPOSURE TO HUMIDITY CAUSING DETERIORATION OF THE HOSE.
Consequence: THIS MAY RESULT IN ABC HYDRAULIC FLUID LEAKAGE NEAR THE CATALYTIC CONVERTER. LEAKING FLUID MAY COME IN CONTACT WITH HOT ENGINE COMPONENTS AND LEAD TO A POSSIBLE FIRE.
Corrective Action: DEALERS WILL INSTALL NEW CORROSION RESISTANT ABC HIGH PRESSURE DISTRIBUTION HOSE. THE RECALL IS EXPECTED TO BEGIN ON OR ABOUT JULY 2, 2007. OWNERS MAY CONTACT MERCEDES-BENZ AT 1-800-367-6372.
Units Potentially Affected: 19924
Recall Initiated By: MFR
Date added to NHTSA datbase: 06/25/2007
MBS430 is offline
ABC High Presure Hose Recall-CL 500's Jud Chapin C215 CL-Class 28 08-03-2007 11:08 AM
High Pressure hose replacement? AlanS W124 E,CE,D,TD Class 1 04-25-2007 06:43 AM
Where can I get the high pressure hose for the hydraulic fluid? hookedup4door W123 E,CE,D,CD,TD,TE Class 8 05-13-2006 03:56 AM
ABC Hose Crushed????? CLMartini C215 CL-Class 5 12-19-2005 04:33 AM
2001 and 2002 S and CL with ABC recall Guest (MBNZ) W220 S-Class 0 08-20-2001 07:05 PM
