Dynamic Select=Air Body Control? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-09-2019, 07:40 AM Thread Starter
Sleeper Benz's Avatar
Date registered: May 2017
Vehicle: W211 2005 E500 4-Matic Estate/Wagon & W212 E350 2012 4-Matic Estate/Wagon
Quoted: 23 Post(s)
Been looking at some E400 Wagons and noticed a few are clearly marked that they come with Air Body Control suspensions (an option that I know as Airmatic) and a few that only mention they come with "Dynamic Select" A toggle switch labeled "Dynamic" with up/down arrows is shown to the right of the shifter in the photos.
Without being able to look directly under the vehicle to confirm, does having Dynamic Select mean the vehicle has an Air Body Control suspension? Several MB related sites are not clear on this issue. Some say it only adjusts the shift points on a standard steel coil spring suspension & others say you need Air Body Control in order to have or get Dynamic Select as a option? I assume Dynamic Select would adjust the suspension ride quality. Are there any other clues to suggest the vehicle comes with Air Body Control suspension even though it's not listed in the ad?
Our current E500 wagon has Airmatic with ride height control, transmission mode control and ride mode control. I would prefer that same capability in a newer E Class wagon if possible. Thanks.
Sleeper Benz is offline
post #2 of 2 (permalink) Old 03-02-2019, 03:31 PM Thread Starter
Quoted: 23 Post(s)
FYI there will be a Ride Height Selector Button just under the "Dynamic" switch that would tip you off if the vehicle has air ride. It has a small picture of a vehicle with an ^arrow on it.
I think the option code is still 489 for air body control (with self leveling.)
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W213 E-Class
Got Codes? Check this list Check Codes W210 E-Class 80 06-12-2017 09:00 PM
Check engine light e320 cc238 W210 E-Class 16 06-26-2009 05:47 AM
test Jillian80 Test 5 06-09-2008 11:28 AM
Error Codes A Plenty.... TheOgre W163 M-Class 2 01-18-2006 06:52 PM
