Rear brake lines. - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-23-2019, 11:34 AM Thread Starter
Date registered: Jun 2019
Rear brake lines.
Hi everyone!
Are rear brake lines goes all the way up from the hose by the wheel to the pump or are they joined somewhere in the middle?
EPC shows they are split and joined by a spacer but I can't locate it..
Any suggestions where is that spacer?
Thanks
Rafal Koziol is offline
post #2 of 7 (permalink) Old 06-23-2019, 12:15 PM
konigstiger's Avatar
Date registered: Jan 2007
Vehicle: '71 Pinto
Quoted: 376 Post(s)
Post VIN I'll see what I can dig up in WIS sometime tomorrow 6/24.
konigstiger is offline
post #3 of 7 (permalink) Old 06-23-2019, 02:04 PM Thread Starter
WDD2120051A488954
post #4 of 7 (permalink) Old 06-24-2019, 12:07 PM
Vehicle: '71 Pinto
Quoted: 376 Post(s)
See attachment.
File Type: pdf Perform visual check of brake lines.pdf (1.45 MB, 13 views)
post #5 of 7 (permalink) Old 06-25-2019, 02:21 AM Thread Starter
I checked WIS myself. Looks like in case of rust damage, brake lines needs to be cut, flare on the car and then joined by the spacer with the replaced piece of lines. Than's what I'm gonna do. I'm changing rear axle brackets so it's a great opportunity to do so.
Thanks!
post #6 of 7 (permalink) Old 06-28-2019, 09:33 AM
Date registered: Feb 2007
Vehicle: 2001 ML430
Quoted: 48 Post(s)
Originally Posted by Rafal Koziol View Post
Hi everyone!
Thanks
Don't tell me you've got rear brake line rust already... something made in 2010 shouldn't be rusting!
First Benz! First SUV! 2001 ML430
Jetpilot718 is offline
post #7 of 7 (permalink) Old 06-29-2019, 02:04 AM Thread Starter
Bergen, Norway - between November and April the roads are white from salt, everything rusts here 4 times quicker.
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W212 E-Class
