W212 Aux Battery Replacement Howto - Mercedes-Benz Forum
post #1 of 2 (permalink) Unread 05-22-2019, 10:17 AM Thread Starter
Date registered: Oct 2009
Quoted: 21 Post(s)
Quick howto using an alternate battery:
Time, this is about a 15 minute job. 1 on a scale of 1-5.
Parts Needed
A0009829308 - Facotry battery $160 or more at your stealer, or
Yuasa YUAM6RH4H YTX14H-BS ~$70 shipped via Amazon prime.
or a gerneric YXT14-BS/CTX14/14-BS size battery ~$50 from Amazon.
Tools needed
10mm wrench
Drill and Bits if using Yuasa Battery or non vented alternative
-Open trunk, lift up floor
-Remove vent tube from battery
-Unscrew 10mm negative bolt and remove negative battery terminal, tuck to the size
-Remove battery cage bolt
-Lift cage up
-Remove positive terminal cap (lifts up)
-Unscrew 10mm positive terminal bolt and cover lead with rubber glove or plastic baggy and rubber band
-Remove battery
-If the replacement battery does not have a vent, you can drill one, this is your call, I personally prefer to vent hydrogen gas rather than keeping it pressurized. The manufactures obviously recommend against this, but the factory AGM is vented for obvious reasons.
-Replace in reverse order.
-The factory bolts work in the Yuasa but are a bit hard to start, I used a bit of the cardboard to lift the nuts in the terminals up for them to catch.
Two weeks later all works great and wallet is $90 heavier than getting the OEM battery. Yuasa batteries are made in the USA and are shipped dry. They are a good quality alternative and are not stale from sitting around.
yakky is offline
post #2 of 2 (permalink) Unread 05-23-2019, 10:45 AM
Kajtek1's Avatar
Quoted: 1957 Post(s)
I paid $111 for MB battery with lifetime guarantee from fcpeuro.com
Those batteries don't last more than 4 years, so I think I will use the warranty at least once.
Kajtek1 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W212 E-Class
