Check Coolant Level - Coolant Color is brown - Mercedes-Benz Forum
post #1 of 26 (permalink) Old 05-12-2019, 11:12 AM Thread Starter
Date registered: Jan 2016
Vehicle: 2011 E350
Quoted: 2 Post(s)
Car is 2011 E350 base model with 95,750 miles.
Last night I got the warning to 'Check Coolant Level See Operator's Manual'. I waited until this morning when the engine was cold to check. The fluid inside the reservoir was a light brown/greenish color. The level was nearly to the top so I'm not sure I actually needed to add more fluid but clearly there is something wrong with the fluid that's already inside.
The gauge in the dash of the car hovers above 80 C now but not close to the red 120C area. The warning light for overheating has never come on either.
Just got an oil change last week. Seems like oil and coolant is getting mixed somewhere. Hoping I don't blow any head gaskets or cause serious damage. Any ideas or recommendations before taking it to the mechanic??
2011E350 is offline
post #2 of 26 (permalink) Old 05-12-2019, 12:03 PM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 775 Post(s)
Twist paper towel sheet into a wick. Dip it for few seconds then lay it flat on something not absorbent. Take a picture.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #3 of 26 (permalink) Old 05-12-2019, 12:22 PM
Date registered: Jul 2010
Vehicle: '85 300D Turbo, '91 420SEL, '92 190E 2.6, '09 C350, '12 E63 Wagon
Quoted: 581 Post(s)
My friendís Ď14 smelled bad, warm. Have the coolant changed, was my suggestion. Not sure if he had it done...
rorypff likes this.
jzchen is online now
post #4 of 26 (permalink) Old 05-12-2019, 12:27 PM Thread Starter
Vehicle: 2011 E350
Quoted: 2 Post(s)
Left side of paper towel is from coolant reservoir. Right side is oil from oil dipstick. 2nd pic is coolant reservoir when engine is cold
ID:	2512070   Click image for larger version
2011E350 is offline
post #5 of 26 (permalink) Old 05-12-2019, 12:50 PM
Kajtek1's Avatar
Quoted: 1935 Post(s)
Your ATF heat exchanger broke inside radiator.
Stop driving the car as you have coolant in your transmission.
Once you get new radiator, you can flush ATF.
jzchen likes this.
Kajtek1 is offline
post #6 of 26 (permalink) Old 05-12-2019, 12:57 PM
Witek_M's Avatar
Vehicle: 1972
Quoted: 775 Post(s)
It does not look like you have any oil contamination. Just nasty old stuff. Possible someone added non compatible coolant. Flush it with distilled water. Use coolant from sheet 325.0 in 50/50 mix.
https://bevo.mercedes-benz.com/bevolisten/325.0_en.html
rorypff and jzchen like this.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #7 of 26 (permalink) Old 05-12-2019, 01:42 PM Thread Starter
Vehicle: 2011 E350
Quoted: 2 Post(s)
Thanks...would you say tow it or drive 5 miles to the mechanic?
2011E350 is offline
post #8 of 26 (permalink) Old 05-12-2019, 03:10 PM
Quoted: 581 Post(s)
Miami doesnít get cold. (Hmmm). Ever bring it somewhere it gets freezing cold? (Thanks for updating your location)!
post #9 of 26 (permalink) Old 05-12-2019, 04:25 PM
Witek_M's Avatar
Vehicle: 1972
Quoted: 775 Post(s)
Since possible ATF contamination was thrown in the gears. Tow it. I do not see any evidence of it, but better save then sorry.
jzchen likes this.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #10 of 26 (permalink) Old 05-13-2019, 04:49 AM
Quoted: 581 Post(s)
When it happened to our W201, the independent shop who diagnosed and fixed the issue mentioned that the transmission fluid goes into the coolant, and not the other way. (This kind of made sense to me, I guess one system is run at higher pressure than the other, so I tried to take the advice to heart).
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W212 E-Class
Coolant flush and change.... my method Paul Mellerowicz W210 E-Class 14 09-30-2012 10:55 AM
98 C280 Coolant Level Light Tofuti W202 C-Class 1 06-25-2012 07:02 AM
Correct Coolant Level Strongislander C209/A209 CLK-Class 3 01-23-2012 12:44 PM
Check Coolant Level = RIP chem1441 C208/A208 CLK-Class 18 08-21-2011 04:08 PM
Check Coolant Level Msg omegga W164 M-Class 7 02-12-2007 04:30 PM
