55 amg low compression ratio - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 04-10-2019, 06:30 AM Thread Starter
Date registered: Apr 2019
Hi guys, i recently bought cls 55 amg 2006 year, i did compression test after oil change was done 1000 km ago and sparks also. My readings are not good at all and im really confused 4 cylinders have around 120-130 psi ot 8.5:1 4 other hahe 100 psi ot 6.5:1 intresting is that the car doesnt smoke at all when do full throttle, the car was sold to me with catalyic converters removed thr car now hahe 2 errors for the 2 cats, can they cause this compression ratio? The car is brutal fast my last car was 400 hp diesel with less weight and now my amg is definetly faster than the diesel. However when i check the oil throught the sensor i got add 1 litrr after 1k km which is quite strange the readings on diagnostic tool was 61mm i have filled 1.1 liternoil and on the next morning the readings from sensor are still 61 i dont know if the car really burn oil or sensor is faulty, as i said no leaks trom car and when full throttle no smoke. I got no problem to revision the engine but want to know what may I expect
Regards
Nikola Lefterov is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > W211 E55 AMG, E63 AMG
Maintenance Manuals Merc-S600 W140 S-Class 214 08-12-2018 01:58 PM
IS MY CAR AN AMG popeyeuk0 General AMG 14 03-18-2011 07:47 AM
We Need A Permanent Sticky for Error Codes Hary Gahtoe C208/A208 CLK-Class 22 01-22-2010 12:11 PM
AMG info and the 6.3 engine dsb R171 SLK-Class 1 01-12-2006 08:13 AM
Long sucess history Zé Bocaina G-Class 3 05-27-2005 01:19 PM
