2007 E63 Stumbling on acceleration when cold - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 01-29-2019, 07:07 PM Thread Starter
Date registered: Dec 2008
Quoted: 2 Post(s)
Just noticed this in the last 3 months.
What is the suggested testing and service?
I am not the original owner and I did not get the service records with the car.
What should I check and replace first?
1.....Fuel Filter
2....Spark Plugs??
3...??
Car has 89k miles.
Love this as a daily driver. 500HP no turbos to worry about.
sker66 is offline
post #2 of 6 (permalink) Old 01-30-2019, 01:09 PM
noetico's Avatar
Date registered: Feb 2015
Vehicle: 2002 Mercedes ML320, Mercedes 190E 2.3L (sold), 2001 Mercedes c320(gone)
Quoted: 220 Post(s)
Add MAF check, EGR valve and tube cleanup(if fitted). Check for any vacuum leaks also, especially the small tubes at the front end of engine; for sec air system, map sensor and intake flaps. Read o2 sensor activity as well.
Kent
noetico is offline
post #3 of 6 (permalink) Old 01-30-2019, 01:49 PM Thread Starter
Quoted: 2 Post(s)
Thanks noetico. I'll put those on my checklist. Thanks a lot for responding.
sker66 is offline
post #4 of 6 (permalink) Old 01-30-2019, 01:58 PM
noetico's Avatar
Quoted: 220 Post(s)
No problem... I forgot; err... As a side thingy... You can also give it a blast of seafoam through the intake, you can put the straw through the hose of the secondary air valve actuator. Check YouTube for videos on how to use seafoam. It just cleans things up for you especially as you've had this kind of rough combustion probably for a while.
Kent
noetico is offline
post #5 of 6 (permalink) Old 01-30-2019, 04:37 PM Thread Starter
Quoted: 2 Post(s)
Cool noetico......I'm adding that to my list. I'll let you know how I make out. Thanks for takeing the time to answer my Thred! This site has been a lifesaver owning older Mercs!
sker66 is offline
post #6 of 6 (permalink) Old 04-24-2019, 11:05 PM
Date registered: Jun 2008
You have a leak unmetered air would be the most common before anything do a throttle reset see if it changes
bdragomir is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > W211 E55 AMG, E63 AMG
ML320 rough idle on cold and nearly stalls on acceleration Whitenoise W163 M-Class 11 02-04-2017 08:28 AM
Un-Pimp My Ride GoldDragon R/C107 SL/SLC Class 60 03-21-2015 08:40 AM
2007 Mercedes Benz E63 AMG WAGON Estate [1 of 67] SUPER RARE TheGoodGuy For Sale/Wanted/Trade/Giveaway 6 03-05-2014 09:07 PM
Crappy Stumbling When Cold Started Reichsrundfunk R/C107 SL/SLC Class 15 07-30-2013 01:16 PM
FS 2007 E63 Wagon, 3rd Row, tons of recent work, $38k vs70 For Sale/Wanted/Trade/Giveaway 1 11-25-2012 01:34 PM
