P0123 CODE Throttle pedal position sensor - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 09-14-2018, 07:04 AM Thread Starter
Date registered: Oct 2014
Vehicle: 2003 E500 V8, 1988 560SL
Quoted: 22 Post(s)
2003 mercedes E500
Came to stop light, hit the accelerator and it did nothing. Floored it....nothing.....eventually started to go.
Pulled over, shut the car off and on. Cleared the issue, like it never happened.
Came home plugged in the ODBII tester and it gave me P0123. Throttle pedal position sensor.
The part I only found was the whole assembly for the accelerator. Has anyone ever replaced this? Seems like just a part swap...
nzvlnr is online now
post #2 of 8 (permalink) Old 09-14-2018, 02:52 PM
noetico's Avatar
Date registered: Feb 2015
Vehicle: 2002 Mercedes ML320, Mercedes 190E 2.3L (sold), 2001 Mercedes c320(gone)
Quoted: 220 Post(s)
Yes, according to WIS; accelerator pedal position B37 is part of the throttle assembly.
Kent
noetico is offline
post #3 of 8 (permalink) Old 09-14-2018, 05:29 PM Thread Starter
Quoted: 22 Post(s)
post #4 of 8 (permalink) Old 01-11-2019, 05:51 PM
Date registered: Jun 2017
Vehicle: 2004 e500
I just started having the exact same issues with my 2004 e500. Did replacing the pedal assembly fix the problem? I have been researching this issue and have found that known causes of this issue can be the accelerator pedal assembly, the TPS sensor at the throttle body (or somewhere near the brake master cylinder), a worn cable harness, or carbonated throttle body.
Thank you.
ponderingnugget is offline
post #5 of 8 (permalink) Old 01-12-2019, 06:30 AM Thread Starter
Quoted: 22 Post(s)
Yes, simple to replace as well. I replaced it...no problems since!!
post #6 of 8 (permalink) Old 01-12-2019, 07:19 AM
Date registered: Jan 2017
Vehicle: 1981 280 SLC, 1986 190 E
I have the same issue as well:
code reads:
P20DD-1 B37
APPS: Signal 1
Short cirquit to Battery
Potentiometer above maximum value (P0123)
So replace Pedal Position Sensor? I'm confused by the mention of a short cirquit!
Lauritz is offline
post #7 of 8 (permalink) Old 01-12-2019, 03:35 PM
Vehicle: 2004 e500
Thanks for the reply. So you didn't bother checking anything else, just went straight in and replaced the pedal assembly? Can you offer any advice for the part swap? Anything to watch out for, no programming with star diagnostic necessary? I just like to get all the information I can before changing parts. Thanks again for sharing.
post #8 of 8 (permalink) Old 01-14-2019, 05:50 AM Thread Starter
Quoted: 22 Post(s)
No, just unbolt and replace. I thought there may be some time of synchronization/ calibrating ....but it was that simple, replace the unit and test drive. Problem solved. Dealer would have probably been over 300!!
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > W211 E55 AMG, E63 AMG
