Idle Air Control Valve - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-14-2015, 08:00 PM Thread Starter
E55AMGpilot's Avatar
Date registered: Sep 2010
Vehicle: 2005 W211 E55 AMG
On three occasions in the last 2 weeks the check engine light came on. A check with the code reader gave same Code everytime P0505 Idle Air Control Valve. My attempt to view the offender via google images was a fail. Can anyone post an image of the EXACT Idle Air Control Valve as well as its EXACT location on the W211 E55 engine? Any DIY help, instructions, hints, tip out there? Ive tried searching for youtube videos but found none. Does anyone know the EXACT part number and approximate price?
Thanks for any assistance.
E55AMGpilot is offline
post #2 of 4 (permalink) Old 06-23-2015, 03:33 AM
Date registered: Nov 2008
Vehicle: 2001 c240
mine was doing the same thing. there is a hose on the drivers side near the firewall that connects to a meta line on one end and throttle body on the other end. i had to throw some hose clamps on it and no more engine lights. pressure had it coming unhooked i guess.
tommygunz is offline
post #3 of 4 (permalink) Old 06-24-2015, 07:55 PM Thread Starter
Yeah I found that hose it's small about 1/4" in diameter. I reconnected it and no error codes have appeared. But I also noticed that on that same side there's connection on the big air intake hose its after the filter and before the throttle body at about 1/2"+diameter. There's nothing connected to it. I've looked all around the back of the engine bay trying to find a disconnected hose but found nothing. I sealed it with plastic and electrical tape to keep unclean air out. Do you know what this hose is or where I can find it
post #4 of 4 (permalink) Old 05-18-2018, 08:51 AM
Kropf's Avatar
Date registered: Jun 2007
Vehicle: 2005 E55 Black, 2007 GL450 Red
Send a message via AIM to Kropf Send a message via Yahoo to Kropf
Originally Posted by E55AMGpilot View Post
... But I also noticed that on that same side there's connection on the big air intake hose its after the filter and before the throttle body at about 1/2"+diameter. There's nothing connected to it. I've looked all around the back of the engine bay trying to find a disconnected hose but found nothing. I sealed it with plastic and electrical tape to keep unclean air out. Do you know what this hose is or where I can find it
There should be another hose (or two if they're both missing) that connects that plastic union in the end of your pictured hose, to the LH Valve Cover breather. My photo shows two hoses (with another plastic union between them) that is routed under the fuel rail connection).
Kropf is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > W211 E55 AMG, E63 AMG
