Rear Air Suspension - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-15-2019, 07:05 PM Thread Starter
Date registered: May 2013
Vehicle: 2004 E320 Wagon
Rear Air Suspension
All,
I need a little help diagnosing the air suspension on my 04' E320 base wagon. I only have air suspension for the rear. I had the light that the car was "TOO LOW" come on in red and it got to the point that it would not pump up. I found that the pump had a broken hose and was full of water. Replaced the pump and it pumped up and stayed up until I drove it. It now seems to have two positions that it likes to sit. When I start the car the pump comes on and it pumps up and sits at ~26" from the top of the wheel arch to the ground (looks good). The other position is at ~24". This is usually after it's been driven at bit. If it's at 24" and I stop and restart the car it will rise up to 26" and stay there until driven again. The red "Too Low" light has never come on since I replaced the pump. I don't believe the air bags are leaking as it stays up. But the behavior doesn't seem right. Does it depressurize when stopped? Any help would be appreciated.
Thanks
Paul
PMarrack is offline
post #2 of 5 (permalink) Old 07-16-2019, 06:49 AM
konigstiger's Avatar
Date registered: Jan 2007
Vehicle: '71 Pinto
Quoted: 389 Post(s)
Revisit compressor install per attachment. If you have not already done so replace air filter. Check for leaks. No leaks problem persists, since water was found you may need to blow out air lines with compressed air note however, if system does not recover itself afterward STAR may be required to discharge/recharge.
konigstiger is offline
post #3 of 5 (permalink) Old 07-16-2019, 08:31 AM
tjts1's Avatar
Date registered: Apr 2009
Vehicle: 87 300D 5 speed
Quoted: 696 Post(s)
Originally Posted by PMarrack View Post
All,
Thanks
Paul
You do have a leak but it's a slow leak.
tjts1 is offline
post #4 of 5 (permalink) Old 07-17-2019, 05:03 PM Thread Starter
Thanks to both for the replies and the files of where to look. I'll check for leaks. Although, I'm still puzzled that it only leaks when driven and to the same height.
Paul
PMarrack is offline
post #5 of 5 (permalink) Old 07-20-2019, 05:50 AM
Sleeper Benz's Avatar
Date registered: May 2017
Vehicle: W211 2005 E500 4-Matic Estate/Wagon & W212 E350 2012 4-Matic Estate/Wagon
Quoted: 24 Post(s)
Our wagon depressurizes/lowers slightly via automatic solenoid activations in both the front and rear when it is turned off. Kinda cool if you ask me. The rear Arnott replacement air springs do not appear to have as much ride height adjustment as the factory units did IMO.
Sleeper Benz is offline
