Tire Pressure Experiments, Anyone? - Mercedes-Benz Forum
LinkBack Thread Tools
Old 07-12-2019, 05:40 AM Thread Starter
Date registered: Oct 2015
Vehicle: 2006 E320 CDI
Quoted: 66 Post(s)
I've pretty much stuck with rated pressure of 28F 30R, maybe increasing by a pound or two. Stock wheels. Going to try to bump it up for economy and handling....will start with 32F 36R and see what I think. What have the rest of you discovered?
Rossafuss's comments in a recent thread on fuel economy got me thinking....
06 E320 CDI "Benson", Platinum Blue, 175k mi
06 E320 CDI "Rutherford", Black, 145k mi
91 300D "Otis", Smoke Silver, 129k mi
98 E300 "Murray", Silver, 129k mi, Stage 2 Rocketchip chip tuned, under son's care
Eleven other MB's owned and sold
2002 Honda Odyssey 255k mi (want to name it "Homer," wife won't let me)
1961 Very Tolerant Wife
shertex is offline
Old 07-12-2019, 07:45 AM
tjts1's Avatar
Date registered: Apr 2009
Vehicle: 87 300D 5 speed
Quoted: 691 Post(s)
It depends on wheel size you have.
Triggering religious fanatics since 1969
tjts1 is online now
Old 07-12-2019, 11:19 AM
Date registered: Jul 2010
Vehicle: 2006 e320 CDI
Quoted: 65 Post(s)
I run 34 all around just to maximize tire life. Seems to work for me!
Mike T.
mtrevelino is offline
Old 07-13-2019, 03:14 AM
Purple Moderator
Date registered: Jul 2005
Quoted: 1513 Post(s)
34 front and 36 rear. The Nokian WR G3 tires seem to be best on the wagon at those pressures.
Noodles is offline
Old 07-15-2019, 08:46 AM
ps2cho's Avatar
Date registered: Oct 2006
Vehicle: 2008 E350 4M, 1988 300TE
Quoted: 347 Post(s)
A couple psi difference is negligible. Better to spend the money on making sure fluids, filters and tires are replaced on schedule.
ps2cho is offline
Old 07-15-2019, 10:12 AM
Rossafuss's Avatar
Date registered: Oct 2013
Vehicle: 2005 E320 CDI *black on black with nearly every option*
Quoted: 195 Post(s)
Hes not spending ony money, he's playing around with tire pressures. lol
2-3 PSI difference doesn't make much of a noticeable difference, but 5-8 PSI? 10 PSI?
A firmer tire absolutely changes handling and ride quality characteristics, and makes a noticeable difference in fuel economy. But over inflating the tire can cause uneven wear on the tires as well as harsher than desired ride quality.
When my tires (stock size on the CDI) fall below 30PSI, i notice much more loftiness in the handling of the car, as well as a harsher reaction from the suspension on rough road.
_______________________________________
"Concentrated power is not rendered harmless by the good intentions of those who create it."
2005 CLK320 - Wifes DD
2005 E320 CDI - Black on Black 450K+miles - MY current DD
2006 E320 CDI - Dads DD
2007 E320 Bluetec - Sisters DD
2008 ML320 CDI - Mothers DD
Gone:
83 300SD
86 190D 2.5
91 300D
95 C280
97 C280
99 E300D
Rossafuss is offline
Old 07-15-2019, 10:16 AM
Rossafuss's Avatar
Quoted: 195 Post(s)
i've also found that if you live in an area with REALLY rough roads like i do, over inflating your tires just a liiiiiiiiiitle bit lowers the risk of damaging tires (specifically the sidewalls/belting) on potholes.
Gone:
83 300SD
86 190D 2.5
91 300D
95 C280
97 C280
99 E300D
Old 07-15-2019, 06:51 PM
ps2cho's Avatar
Quoted: 347 Post(s)
Inflating by 10psi is so incredibly stupid. You want to pick up 0.3mpg at the most, to risk your life, and others in an event you need to swerve, or its wet and you lose traction.
Sounds stupid and irresponsible to me. Not to mention once you go beyond 5psi, you'll begin losing tread life because its no longer evenly distributed across the pattern.
Run them at stock specs, or a couple PSI higher and move on.
2016 Monsoon Gray Audi Allroad - 26k
2008 Black Mercedes E350 4Matic Sport P1 - 140k
2014 Jeep Wranger Unlimited Sahara - 90k
2003 Silver ML350 - 135k
ps2cho is offline
Old 07-15-2019, 07:30 PM
Rossafuss's Avatar
Quoted: 195 Post(s)
Running a Tire at 6PSI below the max rated pressure is not "incredibly stupid." I've been running THESE specific tires at 36-38psi for over 30k miles, the tread wear is perfect, so is my ride quality and handling. Maybe your one size fits all approach to tire pressures in the wide range of tire choices available maybe isn't accurate? MY original post OP is referring to specifically refers to the fact that every tire will have its own sweet spot for where it behaves at its best. Some tires may like lower tire pressures than others, and i specifically stated to be careful not to OVER INFLATE your tires to prevent harsh ride and uneven tire wear.
Here's the post, in-case you were at all curious as to what were talking about here.
https://www.benzworld.org/forums/w21...l#post17837370
Old 07-15-2019, 11:54 PM
tjts1's Avatar
Quoted: 691 Post(s)
You should tell those clowns in Stuttgart how incredibly stupid they are.
tjts1 is online now
